disable menu bar [message #61296] |
Tue, 03 June 2003 15:10  |
Originally posted by: bella_voldman.yahoo.com
I was wondering if there is a way to disable the menu bar in the eclipse
application itself. I have found a way to remove the tool bar (thanks to
Don Estbergs post Apr 29 2003 18:40:46 in eclipse.tools) using
org.eclipse.ui.workbench/SHOW_TOOL_BAR=false. But I couldnt find a
similar property for the menu bar.
Also, is there a way to lock the perspective, i.e. prevent the user from
opening/closing views?
Thank you in advance
Bella
Re: disable menu bar [message #62526 is a reply to message #61421] |
Wed, 04 June 2003 11:45  |
Originally posted by: simon.ibm.oti.lab
Beside "hacking" the eclipse code, there is nothing else I can think of. You
may want to keep an eye on the work for the rich client platform.
Simon :-)
"Bella" <bella_voldman@yahoo.com> wrote in message
news:bbiu64$9ug$1@rogue.oti.com...
> I wanted to use Eclipse's editor, and so I am launching Eclipse from my
> swing based application. But, for example, the navigator view will
> conflict with the tree I have in my application. I have figured out a way
> to have the initial perspective display only the editor. But I would like
> to prevent the user from accidentally (or purposefully) opening other
> views, like the navigator.
> Any suggestions will be appreciated
> Bella
> Simon Arsenault wrote:
> > There is no support to disable the menu bar. There is also no support
for
> > locking the perspective.
> > Maybe you could provide more information about what you are trying to
do.
> > Are you building a plugin that will run in Eclipse? Or are you simply
using
> > part of Eclipse to write some standalone application
> > Simon :-)
> > news:bbirrn$7th$1@rogue.oti.com...
> > > Hello,
eclipse
to
> > > Don Estberg's post Apr 29 2003 18:40:46 in eclipse.tools) using
> > > org.eclipse.ui.workbench/SHOW_TOOL_BAR=false. But I couldn't find a
> > > Also, is there a way to "lock" the perspective, i.e. prevent the user
from
> > > Bella
FUDForum. Page generated in 0.07710 seconds
