Layout on tabforms [message #61202] |
Sun, 26 September 2004 20:20 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: wim.nospam.org
Hi all,
If i create a composite on a tab form, i cannot change the layout of this
composite to say FillLayout. If i add the code manually, it is accepted by
VE and the panel shows correct layout beheaviour. The properties show the
new layout, but the properties window again does not allow changing or
removing.
Any thoughts?
*** Date: 9/26/04 10:12 PM
*** Platform Details:
*** System properties:
awt.toolkit=sun.awt.windows.WToolkit
catalina.base=/c:/eclipse/plugins/org.eclipse.tomcat_4.1.30/
catalina.home=/c:/eclipse/plugins/org.eclipse.tomcat_4.1.30/
catalina.useNaming=true
eclipse.application=org.eclipse.ui.ide.workbench
eclipse.buildId=I200406251208
eclipse.commands=-os
win32
-ws
win32
-arch
x86
-showsplash
C:\eclipse\eclipse.exe -showsplash 600
-exitdata
C:\eclipse\eclipse.exe -exitdata c20_38
-clean
-vm
C:\WINDOWS\system32\javaw.exe
eclipse.product=org.eclipse.platform.ide
eclipse.startTime=1096212908305
eclipse.vm=C:\WINDOWS\system32\javaw.exe
eclipse.vmargs=-cp
C:\eclipse\startup.jar
org.eclipse.core.launcher.Main
eof=eof
file.encoding=Cp1252
file.encoding.pkg=sun.io
file.separator=\
java.awt.graphicsenv=sun.awt.Win32GraphicsEnvironment
java.awt.printerjob=sun.awt.windows.WPrinterJob
java.class.path=C:\eclipse\startup.jar
java.class.version=48.0
java.endorsed.dirs=C:\Program Files\Java\j2re1.4.2_05\lib\endorsed
java.ext.dirs=C:\Program Files\Java\j2re1.4.2_05\lib\ext
java.home=C:\Program Files\Java\j2re1.4.2_05
java.io.tmpdir=C:\DOCUME~1\jongw\LOCALS~1\Temp\
java.library.path=C:\WINDOWS\system32;.;C:\WINDOWS\system32; C:\WINDOWS;C:\ibmdebug\bin;C:\WDSC;C:\WINDOWS\system32;C:\WI NDOWS;C:\WINDOWS\System32\Wbem;C:\Program
Files\ATI Technologies\ATI Control Panel;C:\Program Files\Common Files\Roxio
Shared\DLLShared;C:\IMNNQ_XP;C:\Program
Files\Java\j2re1.4.2_05\bin;C:\PROGRA~1\IBM\CLIENT~1;C:\PROG RA~1\IBM\CLIENT~1\Shared;C:\PROGRA~1\IBM\CLIENT~1\Emulator;C :\Program
Files\WinMerge;;C:\Program Files\Sybase\SQL Anywhere 7\win32;C:\Program
Files\Sybase\Shared\win32;C:\Program Files\Sybase\Shared\Sybase Central
4.0\java
java.naming.factory.initial=org.apache.naming.java.javaURLCo ntextFactory
java.naming.factory.url.pkgs=org.apache.naming
java.runtime.name=Java(TM) 2 Runtime Environment, Standard Edition
java.runtime.version=1.4.2_05-b04
java.specification.name=Java Platform API Specification
java.specification.vendor=Sun Microsystems Inc.
java.specification.version=1.4
java.util.prefs.PreferencesFactory=java.util.prefs.WindowsPr eferencesFactory
java.vendor.url=http://java.sun.com/
java.vendor.url.bug=http://java.sun.com/cgi-bin/bugreport.cgi
java.version=1.4.2_05
java.vm.info=mixed mode
java.vm.name=Java HotSpot(TM) Client VM
java.vm.specification.name=Java Virtual Machine Specification
java.vm.specification.vendor=Sun Microsystems Inc.
java.vm.specification.version=1.0
java.vm.vendor=Sun Microsystems Inc.
java.vm.version=1.4.2_05-b04
line.separator=
org.eclipse.jdt.debug.ui.scrapbookActive=false
org.osgi.framework.executionenvironment=
org.osgi.framework.language=en
org.osgi.framework.os.name=WindowsXP
org.osgi.framework.os.version=5.1
org.osgi.framework.processor=x86
org.osgi.framework.vendor=Eclipse
org.osgi.framework.version=1.2.0
org.xml.sax.driver=org.apache.crimson.parser.XMLReaderImpl
os.arch=x86
os.name=Windows XP
os.version=5.1
osgi.arch=x86
osgi.bundles=org.eclipse.core.runtime@2:start,
org.eclipse.update.configurator@3:start
osgi.bundles.defaultStartLevel=4
osgi.bundlestore=c:\eclipse\configuration\org.eclipse.osgi\b undles
osgi.clean=true
osgi.configuration.area=file:/c:/eclipse/configuration/
osgi.framework=file:/c:/eclipse/plugins/org.eclipse.osgi_3.0 .1/
osgi.framework.beginningstartlevel=1
osgi.framework.version=3.0.0
osgi.frameworkClassPath=core.jar, console.jar, osgi.jar, resolver.jar,
defaultAdaptor.jar, eclipseAdaptor.jar
osgi.install.area=file:/c:/eclipse/
osgi.instance.area=file:/C:/eclipse/workspace/
osgi.logfile=C:\eclipse\workspace\.metadata\.log
osgi.manifest.cache=c:\eclipse\configuration\org.eclipse.osg i\manifests
osgi.nl=en_US
osgi.os=win32
osgi.splashLocation=c:\eclipse\plugins\org.eclipse.platform_ 3.0.1\splash.bmp
osgi.splashPath=platform:/base/plugins/org.eclipse.platform
osgi.ws=win32
path.separator=;
sun.arch.data.model=32
sun.boot.class.path=C:\Program Files\Java\j2re1.4.2_05\lib\rt.jar;C:\Program
Files\Java\j2re1.4.2_05\lib\i18n.jar;C:\Program
Files\Java\j2re1.4.2_05\lib\sunrsasign.jar;C:\Program
Files\Java\j2re1.4.2_05\lib\jsse.jar;C:\Program
Files\Java\j2re1.4.2_05\lib\jce.jar;C:\Program
Files\Java\j2re1.4.2_05\lib\charsets.jar;C:\Program
Files\Java\j2re1.4.2_05\classes
sun.boot.library.path=C:\Program Files\Java\j2re1.4.2_05\bin
sun.cpu.endian=little
sun.cpu.isalist=pentium i486 i386
sun.io.unicode.encoding=UnicodeLittle
sun.java2d.fontpath=
sun.os.patch.level=Service Pack 2
user.country=US
user.dir=C:\eclipse
user.home=C:\Documents and Settings\jongw
user.language=en
user.name=jongw
user.timezone=Europe/Berlin
user.variant=
vendor=Apache Software Foundation
vendor-url=http://xml.apache.org/xalan-j
version=2.4.1
*** Features:
org.eclipse.emf (2.0.1.R200409171617) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.doc (2.0.1.R200409171617) "Eclipse Modeling Framework (EMF)
Programmers Guide"
org.eclipse.emf.ecore.sdo (2.0.1.R200409171617) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.ecore.sdo.doc (2.0.0.R200409171617) "EMF Service Data
Objects (SDO) Programmers Guide"
org.eclipse.emf.ecore.sdo.source (2.0.1.R200409171617) "EMF Service Data
Objects (SDO) Source"
org.eclipse.emf.examples (2.0.1.R200409171617) "Examples for Eclipse
org.eclipse.emf.source (2.0.1.R200409171617) "Eclipse Modeling Framework
(EMF) Source"
org.eclipse.gef (3.0.1) "Graphical Editing Framework"
org.eclipse.gef.examples (3.0.1) "GEF Examples"
org.eclipse.gef.sdk (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.gef.source (3.0.1) "Graphical Editing Framework Developer
Resources"
org.eclipse.jdt (3.0.1) "Eclipse Java Development Tools"
org.eclipse.jdt.source (3.0.1) "Eclipse Java Development Tools SDK"
org.eclipse.jem (1.0.1) "Java EMF Model"
org.eclipse.jem.sdk (1.0.1) "Java EMF Model SDK"
org.eclipse.jem.source (1.0.1) "Java EMF Model Source"
org.eclipse.pde (3.0.1) "Eclipse Plug-in Development Environment"
org.eclipse.pde.source (3.0.1) "Eclipse Plug-in Development Environment
Developer Resources"
org.eclipse.platform (3.0.1) "Eclipse Platform"
org.eclipse.platform.source (3.0.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk (3.0.1) "Eclipse Project SDK"
org.eclipse.sdk.examples (3.0.1) "Eclipse SDK Examples"
org.eclipse.team.extras (3.0.0) "Eclipse FTP and WebDAV Support"
org.eclipse.ve (1.0.1) "Visual Editor"
org.eclipse.ve.sdk (1.0.1) "Visual Editor SDK"
org.eclipse.ve.source (1.0.1) "Visual Editor Source"
org.eclipse.xsd (2.0.1.R200409171617) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.0.0.R200409171617) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.source (2.0.1.R200409171617) "XML Schema Infoset Model (XSD)
Source"
*** Plug-in Registry:
com.ibm.etools.emf.event (3.0.0.1) "Event Model"
com.ibm.wtp.common.util (1.0.1) "Logging Plug-in"
com.ibm.wtp.emf.workbench (1.0.1) "EMF Workbench"
nl.remain.Applications (1.0.0) "Applications Plug-in"
org.apache.ant (1.6.2) "Apache Ant"
org.apache.lucene (1.3.1) "Apache Lucene"
org.eclipse.ant.core (3.0.0) "Ant Build Tool Core"
org.eclipse.ant.ui (3.0.1) "Ant UI"
org.eclipse.compare (3.0.0) "Compare Support"
org.eclipse.compare.examples (3.0.0) "Compare Example"
org.eclipse.compare.examples.xml (3.0.0) "XML Compare Support"
org.eclipse.core.boot (3.0.0) "Core Boot"
org.eclipse.core.expressions (3.0.0) "Expression Language"
org.eclipse.core.filebuffers (3.0.1) "File Buffers"
org.eclipse.core.resources (3.0.1) "Core Resource Management"
org.eclipse.core.resources.win32 (3.0.0) "Core Resource Management Win32
Fragment"
org.eclipse.core.runtime (3.0.1) "Core Runtime"
org.eclipse.core.runtime.compatibility (3.0.0) "Core Runtime Plug-in
Compatibility"
org.eclipse.core.variables (3.0.0) "Core Variables"
org.eclipse.debug.core (3.0.1) "Debug Core"
org.eclipse.debug.ui (3.0.1) "Debug UI"
org.eclipse.draw2d (3.0.1) "Draw2d"
org.eclipse.draw2d.doc.isv (3.0.1) "Draw2D Documentation"
org.eclipse.emf (2.0.1.200409171617) "Eclipse Modeling Framework (EMF)"
org.eclipse.emf.activities (2.0.0.200409171617) "EMF Activities"
org.eclipse.emf.codegen (2.0.1.200409171617) "EMF Template Code Generator"
org.eclipse.emf.codegen.ecore (2.0.1.200409171617) "EMF Ecore Code
Generation"
org.eclipse.emf.codegen.ecore.ui (2.0.1.200409171617) "EMF Ecore Code
Generation UI"
org.eclipse.emf.codegen.ui (2.0.0.200409171617) "EMF Template Code Generator
UI"
org.eclipse.emf.common (2.0.1.200409171617) "EMF Common"
org.eclipse.emf.common.ui (2.0.1.200409171617) "EMF Common UI"
org.eclipse.emf.commonj.sdo (2.0.0.200409171617) "CommonJ SDO"
org.eclipse.emf.doc (2.0.1.200409171617) "Eclipse Modeling Framework (EMF)
Programmers Guide"
org.eclipse.emf.ecore (2.0.1.200409171617) "EMF Ecore"
org.eclipse.emf.ecore.change (2.0.1.200409171617) "EMF Ecore Change Model"
org.eclipse.emf.ecore.change.edit (2.0.0.200409171617) "EMF Ecore Change
Edit Support"
org.eclipse.emf.ecore.edit (2.0.0.200409171617) "EMF Ecore Edit Support"
org.eclipse.emf.ecore.editor (2.0.1.200409171617) "Sample Ecore Editor"
org.eclipse.emf.ecore.sdo (2.0.1.200409171617) "EMF Service Data Objects
(SDO)"
org.eclipse.emf.ecore.sdo.doc (2.0.0.200409171617) "EMF Service Data Objects
org.eclipse.emf.ecore.sdo.edit (2.0.0.200409171617) "EMF Service Data
Objects (SDO) Edit Support"
org.eclipse.emf.ecore.sdo.editor (2.0.0.200409171617) "EMF Service Data
Objects (SDO) Editor"
org.eclipse.emf.ecore.xmi (2.0.1.200409171617) "EMF XMI"
org.eclipse.emf.edit (2.0.1.200409171617) "EMF Edit"
org.eclipse.emf.edit.ui (2.0.1.200409171617) "EMF Edit UI"
org.eclipse.emf.examples (2.0.1.200409171617) "Examples for Eclipse Modeling
Framework (EMF)"
org.eclipse.emf.java (2.0.1.200409171617) "EMF Java"
org.eclipse.emf.java.edit (2.0.0.200409171617) "EMF Java Edit"
org.eclipse.emf.java.editor (2.0.1.200409171617) "EMF Java Editor"
org.eclipse.emf.mapping (2.0.1.200409171617) "EMF Mapping"
org.eclipse.emf.mapping.ecore2ecore (2.0.1.200409171617) "Ecore to Ecore
Mapping"
org.eclipse.emf.mapping.ecore2ecore.editor (2.0.1.200409171617) "Ecore to
Ecore Mapping Editor"
org.eclipse.emf.mapping.ui (2.0.0.200409171617) "EMF Mapping UI"
org.eclipse.emf.mapping.xsd2ecore (2.0.1.200409171617) "XSD to Ecore
Mapping"
org.eclipse.emf.mapping.xsd2ecore.editor (2.0.1.200409171617) "XSD to Ecore
Mapping Editor"
(EMF) Source"
org.eclipse.gef.doc.isv (3.0.1) "Graphical Editing Framework Documentation"
org.eclipse.gef.examples.flow (3.0.1) "GEF Flow Editor Example"
org.eclipse.gef.examples.logic (3.0.0) "GEF Logic Editor Example"
org.eclipse.gef.examples.source (3.0.1) "GEF Examples"
Resources"
org.eclipse.help (3.0.0) "Help System Core"
org.eclipse.help.appserver (3.0.0) "Help Application Server"
org.eclipse.help.base (3.0.1) "Help System Base"
org.eclipse.help.examples.ex1 (3.0.0) "Online Help Sample"
org.eclipse.help.ide (3.0.0) "Help System IDE"
org.eclipse.help.ui (3.0.0) "Help System UI"
org.eclipse.help.webapp (3.0.1) "Help System Webapp"
org.eclipse.jdt.core (3.0.1) "Java Development Tools Core"
org.eclipse.jdt.debug (3.0.1) "JDI Debug Model"
org.eclipse.jdt.debug.ui (3.0.1) "JDI Debug UI"
org.eclipse.jdt.doc.isv (3.0.1) "Eclipse JDT Plug-in Developer Guide"
org.eclipse.jdt.doc.user (3.0.1) "Eclipse Java Development User Guide"
org.eclipse.jdt.junit (3.0.1) "Java Development Tools JUnit support"
org.eclipse.jdt.junit.runtime (3.0.0) "Java Development Tools JUnit runtime
support"
org.eclipse.jdt.launching (3.0.1) "Java Development Tools Launching Support"
org.eclipse.jdt.ui (3.0.1) "Java Development Tools UI"
org.eclipse.jdt.ui.examples.projects (3.0.1) "Java Development Tools Example
Projects"
org.eclipse.jem.beaninfo (1.0.1) "Java EMF Model BeanInfo (Introspection)
Support"
org.eclipse.jem.proxy (1.0.1) "Java EMF Model Proxy Support"
org.eclipse.jem.ui (1.0.1) "Java EMF Model UI"
org.eclipse.jem.workbench (1.0.1) "Java EMF Model Workbench Support"
org.eclipse.jface (3.0.0) "JFace"
org.eclipse.jface.text (3.0.1) "JFace Text"
org.eclipse.ltk.core.refactoring (3.0.1) "Refactoring Core"
org.eclipse.ltk.ui.refactoring (3.0.1) "Refactoring UI"
org.eclipse.osgi (3.0.1) "OSGi System Bundle"
org.eclipse.osgi.services (3.0.0) "OSGi Release 3 Services"
org.eclipse.osgi.util (3.0.0) "OSGi R3 Utility Classes"
org.eclipse.pde.build (3.0.1) "Plug-in Development Environment Build
Support"
org.eclipse.pde.core (3.0.1) "Plug-in Development Core"
org.eclipse.pde.doc.user (3.0.0) "Eclipse Plug-in Development User Guide"
org.eclipse.pde.junit.runtime (3.0.0) "PDE JUnit Plug-in Test"
org.eclipse.pde.runtime (3.0.1) "Plug-in Development Environment Runtime"
org.eclipse.pde.ui (3.0.1) "Plug-in Development UI"
org.eclipse.platform.doc.isv (3.0.1) "Eclipse Platform Plug-in Developer
Guide"
org.eclipse.platform.doc.user (3.0.1) "Eclipse Workbench User Guide"
Resources"
org.eclipse.platform.source.win32.win32.x86 (3.0.1) "Eclipse Platform
Plug-in Developer Resources"
org.eclipse.sdk.examples.source (3.0.1) "Eclipse Platform Plug-in Developer
Resources"
org.eclipse.sdk.examples.source.win32.win32.x86 (3.0.1) "Eclipse Platform
org.eclipse.search (3.0.1) "Search Support"
org.eclipse.swt (3.0.1) "Standard Widget Toolkit"
org.eclipse.swt.examples (3.0.0) "SWT Standalone Examples Plugin"
org.eclipse.swt.examples.browser (3.0.0) "SWT Browser Example Plugin"
org.eclipse.swt.examples.controls (3.0.0) "SWT Controls Example Plugin"
org.eclipse.swt.examples.launcher (3.0.0) "SWT Launcher Example Plugin"
org.eclipse.swt.examples.layouts (3.0.0) "SWT Layout Example Plugin"
org.eclipse.swt.examples.ole.win32 (3.0.0) "SWT OLE Example Plugin (Win32)"
org.eclipse.swt.examples.paint (3.0.0) "SWT Paint Example Plugin"
org.eclipse.swt.win32 (3.0.1) "Standard Widget Toolkit for Windows"
org.eclipse.team.core (3.0.0) "Team Support Core"
org.eclipse.team.cvs.core (3.0.1) "CVS Team Provider Core"
org.eclipse.team.cvs.ssh (3.0.0) "CVS SSH Core"
org.eclipse.team.cvs.ssh2 (3.0.0) "CVS SSH2"
org.eclipse.team.cvs.ui (3.0.1) "CVS Team Provider UI"
org.eclipse.team.examples.filesystem (3.0.0) "Eclipse Team File System
Example"
org.eclipse.team.extras.source (3.0.0) "Eclipse Team Extras Plug-in
org.eclipse.team.ftp (3.0.0) "FTP Deployment Provider"
org.eclipse.team.ui (3.0.1) "Team Support UI"
org.eclipse.team.webdav (3.0.0) "WebDAV Team Provider"
org.eclipse.text (3.0.1) "Text"
org.eclipse.tomcat (4.1.30) "Tomcat Wrapper"
org.eclipse.ui (3.0.1) "Eclipse UI"
org.eclipse.ui.cheatsheets (3.0.1) "Cheat Sheets"
org.eclipse.ui.console (3.0.0) "Console"
org.eclipse.ui.editors (3.0.1) "Default Text Editor"
org.eclipse.ui.examples.javaeditor (3.0.0) "JFace Text Example"
org.eclipse.ui.examples.multipageeditor (2.1.0) "Multi-Page Editor Example"
org.eclipse.ui.examples.propertysheet (2.1.0) "User File Editor"
org.eclipse.ui.examples.readmetool (2.1.0) "Readme File Editing Tool"
org.eclipse.ui.externaltools (3.0.1) "External Tools"
org.eclipse.ui.forms (3.0.0) "Eclipse Forms"
org.eclipse.ui.ide (3.0.1) "Eclipse IDE UI"
org.eclipse.ui.intro (3.0.1) "Intro Plugin"
org.eclipse.ui.presentations.r21 (3.0.1) "R21 Presentation Plug-in"
org.eclipse.ui.views (3.0.0) "Views"
org.eclipse.ui.win32 (3.0.1) "Win32 fragment"
org.eclipse.ui.workbench (3.0.1) "Workbench"
org.eclipse.ui.workbench.compatibility (3.0.0) "Workbench Compatibility"
org.eclipse.ui.workbench.texteditor (3.0.1) "Text Editor Framework"
org.eclipse.update.configurator (3.0.0) "Install/Update Configurator"
org.eclipse.update.core (3.0.1) "Install/Update Core"
org.eclipse.update.core.win32 (3.0.0) "Install/Update Core for Windows"
org.eclipse.update.scheduler (3.0.0) "Automatic Updates Scheduler"
org.eclipse.update.ui (3.0.1) "Install/Update UI"
org.eclipse.ve.cde (1.0.1) "Visual Editor Common Data Editor"
org.eclipse.ve.doc (1.0.1) "Visual Editor User Guide"
org.eclipse.ve.java.core (1.0.1) "Visual Editor Java Core"
org.eclipse.ve.jfc (1.0.1) "Visual Editor for Java Foundation Classes"
org.eclipse.ve.propertysheet (1.0.1) "Visual Editor PropertySheet"
org.eclipse.ve.swt (1.0.1) "Visual Editor for Standard Widget Toolkit"
org.eclipse.webdav (3.0.0) "WebDAV Client"
org.eclipse.xsd (2.0.1.200409171617) "XML Schema Infoset Model (XSD)"
org.eclipse.xsd.doc (2.0.0.200409171617) "XML Schema Infoset Model (XSD)
Programmers Guide"
org.eclipse.xsd.edit (2.0.1.200409171617) "XML Schema Edit Framework"
org.eclipse.xsd.editor (2.0.1.200409171617) "XML Schema Editor"
Source"
org.eclipse.xsd.test (2.0.1.200409171617) "XML Schema Infoset Model Test"
org.junit (3.8.1) "JUnit Testing Framework"
*** User Preferences:
#Sun Sep 26 22:12:37 CEST 2004
/instance/org.eclipse.ve.cde/CUSTOMIZELAYOUTWINDOW_X=90
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Omgeving|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<classpath>\r\n<classpathentry
kind\="lib" path\="C\:/Program
Files/Java/j2re1.4.2_05/lib/rt.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/j2re1.4.2_05/lib/sunrsasign.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/j2re1.4.2_05/lib/jsse.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/jce.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.2_05/lib/charsets.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/j2re1.4.2_05/lib/ext/dnsns.jar"/>\r\n<classpathentry kind\="lib"
path\="C\:/Program
Files/Java/j2re1.4.2_05/lib/ext/ldapsec.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.2_05/lib/ext/localedata.jar"/>\r\n<classpathentry
Files/Java/j2re1.4.2_05/lib/ext/sunjce_provider.jar"/>\r\n </classpath>\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates/>
@org.eclipse.ui.ide=3.0.1
/instance/org.eclipse.jdt.launching/org.eclipse.jdt.launchin g.PREF_VM_XML= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<vmSettings
defaultVM\=" 57,org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType 1,0 "
defaultVMConnector\="">\r\n<vmType
id\="org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType ">\r\n<vm
id\="0" name\="j2re1.4.2_05" path\="C\:\\Program Files\\Java\\j2re1.4.2_05"
javadocURL\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</vmType>\r\n</vmSettings>\r\n
@org.eclipse.pde.core=3.0.1
/instance/org.eclipse.ve.java.core/VISUAL_CLASS_WIZARD_SELEC TED_ELEMENT_KEY=org.eclipse.ve.swt.cat-Application-java.lang .Object
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.code_te mplates_migrated=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.internal.ui.Pac kageExplorer.EmptyInnerPackageFilter=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Zwerm2|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
/instance/org.eclipse.jdt.ui/CustomFiltersActionGroup.org.ec lipse.jdt.ui.PackageExplorer.TAG_DUMMY_TO_TEST_EXISTENCE=sto redViewPreferences
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.nl.remain.Applications|org.eclipse.pde.core.requi redPlugins= <?xml
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.ui_3.0.1/uisrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.ui_3.0.1/ui.jar"/>\r\n <classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source.win32.win32. x86_3.0.1/src/org.eclipse.swt.win32_3.0.1/ws/win32/swtsrc.zi p "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.swt.win32_3.0.1/ws/win32/swt .jar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.jface_3.0.0/jfacesrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.jface_3.0.0/jface.jar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.ui.workbench_3.0.1/workbenchsrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.ui.workbench_3.0.1/workbench .jar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.core.runtime_3.0.1/runtimesrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime_3.0.1/runtime.j ar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.osgi_3.0.1/osgisrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.1/osgi.jar"/ >\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.osgi_3.0.1/coresrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.1/core.jar"/ >\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.osgi_3.0.1/resolversrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.1/resolver.jar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.osgi_3.0.1/defaultAdaptorsrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.osgi_3.0.1/defaultAdaptor.ja r "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.osgi_3.0.1/eclipseAdaptorsrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.osgi_3.0.1/eclipseAdaptor.ja r "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.1/src/or g.eclipse.osgi_3.0.1/consolesrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.1/console.jar "/>\r\n</classpath>\r\n
@org.eclipse.ve.cde=1.0.1
/instance/com.swtdesigner/<current\ platform>=<current platform>,null,null
@org.eclipse.jdt.ui=3.0.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Zwerm|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
@org.eclipse.core.resources=3.0.1
/instance/org.eclipse.ui/showIntro=false
/instance/org.eclipse.help.ui/browser.y=63
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplo rer.ImportDeclarationFilter=true
/instance/org.eclipse.help.ui/browser.x=204
/instance/org.eclipse.help.ui/browser.maximized=false
/instance/org.eclipse.help.ui/browser.w=1024
/instance/org.eclipse.pde.core/platform_path=c\:\\eclipse
/instance/org.eclipse.jdt.ui/tabWidthPropagated=true
@org.eclipse.ve.java.core=1.0.1
file_export_version=3.0
@org.eclipse.jdt.launching=3.0.1
/instance/org.eclipse.help.ui/browser.h=768
/instance/com.swtdesigner/createComponentsInBlocks=false
/instance/org.eclipse.jdt.ui/org.eclipse.jface.textfont=1|Co urier
New|10|0|WINDOWS|1|0|0|0|0|0|0|0|0|1|0|0|0|0|Courier New;
/instance/org.eclipse.ve.java.core/PALETTE_WIDTH=224
/instance/org.eclipse.team.ui/org.eclipse.team.ui.first_time =false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.nl.remain.favouites|org.eclipse.pde.core.required Plugins= <?xml
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.ui_3.0.0/uisrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.ui_3.0.0/ui.jar"/>\r\n <classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source.win32.win32. x86_3.0.0/src/org.eclipse.swt.win32_3.0.0/ws/win32/swtsrc.zi p "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.swt.win32_3.0.0/ws/win32/swt .jar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.jface_3.0.0/jfacesrc.zip "
kind\="lib"
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.ui.workbench_3.0.0/workbenchsrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.ui.workbench_3.0.0/workbench .jar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.core.runtime_3.0.0/runtimesrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.core.runtime_3.0.0/runtime.j ar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.osgi_3.0.0/osgisrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.0/osgi.jar"/ >\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.osgi_3.0.0/coresrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.0/core.jar"/ >\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.osgi_3.0.0/resolversrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.0/resolver.jar "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.osgi_3.0.0/defaultAdaptorsrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.osgi_3.0.0/defaultAdaptor.ja r "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.osgi_3.0.0/eclipseAdaptorsrc.zip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.osgi_3.0.0/eclipseAdaptor.ja r "/>\r\n<classpathentry
sourcepath\=" C\:/eclipse/plugins/org.eclipse.platform.source_3.0.0/src/or g.eclipse.osgi_3.0.0/consolesrc.zip "
kind\="lib"
path\="C\:/eclipse/plugins/org.eclipse.osgi_3.0.0/console.jar "/>\r\n</classpath>\r\n
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplo rer_patternFilterId_*$*.class=true
/instance/com.swtdesigner/createComponentsAsFields=true
/instance/com.swtdesigner/makeDeclarationsFinal=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.nl.remain.favouites|org.eclipse.jdt.launching.JRE _CONTAINER= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
/instance/org.eclipse.jdt.ui/Refactoring.savealleditors=true
/instance/org.eclipse.ve.java.core/PALETTE_STATE=4
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.codeComp lete.visibilityCheck=enabled
/instance/org.eclipse.core.resources/pathvariable.swt_dll=C\ :/eclipse/plugins/org.eclipse.swt.win32_3.0.0/os/win32/x86/s wt-win32-3062.dll
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JUNIT_HOME=c\:/eclipse/plugins/org.junit_3.8.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Chess|SWT_CONTAINER= <?xml
sourcepath\=" /c\:/eclipse/plugins/org.eclipse.platform.source.win32.win32 .x86_3.0.1/src/org.eclipse.swt.win32_3.0.1/ws/win32/swtsrc.z ip "
kind\="lib"
path\=" C\:/eclipse/plugins/org.eclipse.swt.win32_3.0.1/ws/win32/swt .jar "/>\r\n</classpath>\r\n
/instance/com.swtdesigner/createStubEventHandlerMethods=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_LIB=C\:/Program
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.formatterpro files.version=6
@org.eclipse.jdt.core=3.0.1
/instance/org.eclipse.jdt.ui/useAnnotationsPrefPage=true
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.templat es_migrated=true
/instance/org.eclipse.jdt.ui/useQuickDiffPrefPage=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.nl.remain.Applications|org.eclipse.jdt.launching. JRE_CONTAINER= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.javadoclocat ions= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<javadoclocation>\r\n<location_01
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/ext/dnsns.jar"
url\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n<location_01
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/sunrsasign.jar"
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/jsse.jar"
url\=" http\://download2.eclipse.org/downloads/documentation/2.0/ht ml/plugins/org.eclipse.platform.doc.isv/reference/api/"/>\r\n<location_01
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/rt.jar"
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/charsets.jar"
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/ext/ldapsec.jar"
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/ext/localedata.jar"
path\="C\:/Program Files/Java/j2re1.4.2_05/lib/ext/sunjce_provider.jar"
url\="http\://java.sun.com/j2se/1.4.2/docs/api"/>\r\n</javadoclocation>\r\n
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRCROOT=
@org.eclipse.jdt.debug.ui=3.0.1
/instance/org.eclipse.ve.java.core/DOCK_LOCATION=8
/instance/com.swtdesigner/includeComponentPrefix=true
/instance/org.eclipse.jdt.debug.ui/org.eclipse.debug.ui.Vari ableView.org.eclipse.jdt.debug.ui.show_null_entries=true
@org.eclipse.team.ui=3.0.1
/instance/com.swtdesigner/declarationStyle=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.nl.remain.favorites|org.eclipse.pde.core.required Plugins= <?xml
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
kind\="lib"
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.builder. resourceCopyExclusionFilter=*.launch
/instance/com.swtdesigner/shareVariablesIfPossible=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.nl.remain.favorites|org.eclipse.jdt.launching.JRE _CONTAINER= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplo rer_patternFilterId_.*=true
/instance/org.eclipse.jdt.ui/Refactoring.ErrorPage.severityT hreshold=2
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.JRE_SRC=
@org.eclipse.help.ui=3.0.0
/instance/org.eclipse.jdt.ui/lastRecentlyUsedFilters=org.ecl ipse.jdt.ui.PackageExplorer.ClosedProjectsFilter,
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.PackageExplo rer.PackageDeclarationFilter=true
/instance/org.eclipse.jdt.ui/fontPropagated=true
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Chess|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
/instance/org.eclipse.ui.ide/EXIT_PROMPT_ON_CLOSE_LAST_WINDO W=false
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hVariable.ECLIPSE_HOME=c\:/eclipse
@org.eclipse.ui=3.0.1
/instance/org.eclipse.jdt.core/org.eclipse.jdt.core.classpat hContainer.Zwermxx|org.eclipse.jdt.launching.JRE_CONTAINER= <?xml
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
path\="C\:/Program
/instance/org.eclipse.ve.cde/CUSTOMIZELAYOUTWINDOW_Y=88
/instance/org.eclipse.jdt.ui/org.eclipse.jdt.ui.text.custom_ code_templates= <?xml
version\="1.0" encoding\="UTF-8"?>\r\n<templates><template
id\="org.eclipse.jdt.ui.text.codetemplates.typecomment" name\="typecomment"
description\="Comment for created types" context\="typecomment_context"
enabled\="true" deleted\="false">/**\r\n * @author W.S. Jongman\r\n *
@author Copyright 2004 www.weltevree.com\r\n * \r\n * Project\:
\t${project_name}\r\n * Date\:\t\tdd month ${year}\r\n *
Description\:\t\t\r\n * \r\n * \r\n * ${todo} Enter text\r\n
*/</template></templates>
*** Update Manager Log:
Configuration=Wed Jul 07 00:02:03 CEST 2004
Is current configuration=false
Configuration=Thu Jul 15 00:16:22 CEST 2004
Configuration=Fri Sep 03 16:12:06 CEST 2004
Configuration=Fri Sep 03 16:33:11 CEST 2004
Configuration=Sun Sep 19 15:53:12 CEST 2004
Configuration=Sun Sep 26 08:38:17 CEST 2004
Configuration=Sun Sep 26 15:50:02 CEST 2004
Configuration=Sun Sep 26 16:23:15 CEST 2004
Configuration=Sun Sep 26 16:29:10 CEST 2004
Configuration=Sun Sep 26 16:37:07 CEST 2004
Is current configuration=true
FUDForum. Page generated in 0.03992 seconds
