Home » Eclipse Projects » GEF » Standard actions problem
Standard actions problem [message #61069] Fri, 31 January 2003 16:42
Kirill Paliy is currently offline Kirill PaliyFriend
I downloaded latest GEF in the morning and it seems that standard actions
don't work. I used subclass of ActionBarContributor, now undo/redo icons are
disabled all the time. I meant even if action.isEnabled returns true, redo
action is disabled on toolbar and in popup menu ( I use subclass of
ContextMenuProvider). At the same time undo action is disabled on toolbar
and enabled in menu. I tried to trace when isEnabled is called by framework,
but it looks like this happens only when editor is activated. Any hints
would be greatly appreciated.
WBR Kir
Previous Topic:Please tell me if this is doable
Next Topic:Selection problem
Current Time: Fri Nov 08 22:54:03 GMT 2024
Powered by FUDForum. Page generated in 0.02571 seconds
