Home » Modeling » TMF (Xtext) » [Xtext] Bidirectional properties handled incorrectly?
| [Xtext] Bidirectional properties handled incorrectly? [message #61030] |
Mon, 20 July 2009 06:35  |
We use an existing ecore metamodel with Xtext. In the metamodel we make
use of bidirectional references. When either doing validation checks using
Checks, or generating using Xpand the opposite side of references remains
null.
Sofar I have two different cases:
1. If an opposite points to its owner, things are ok.
2. If an opposite does not point to its owner, it is never set. Only the
side that is mentioned in the Xtext grammar rule, is set, but the opposite
remains empty.
I have encountered this while migrating Mod4j, and can reproduce this in a
small example. I can send the corresponding files, but don't know how to
add them in this newsgroup.
Is this a known problem that anyone has seen before? I can't find
anything on this newsgroup.
Regards, Jos Warmer
| Re: [Xtext] Bidirectional properties handled incorrectly? [message #61106 is a reply to message #61030] |
Mon, 20 July 2009 07:57   |
Hi Jos,
this is a know bug.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=282486
Sebastian
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Am 20.07.2009 12:35 Uhr, schrieb Jos Warmer:
> using Checks, or generating using Xpand the opposite side of references
> remains null.
> opposite remains empty.
> a small example. I can send the corresponding files, but don't know how
> to add them in this newsgroup.
> Regards, Jos Warmer
| Re: [Xtext] Bidirectional properties handled incorrectly? [message #61375 is a reply to message #61254] |
Mon, 20 July 2009 11:07   |
Hi Knut,
Thanks for the advice. I see the overriding of the createProxy()
operation, and found the xtext LazyLinking class that I should override.
protected EObject createProxy(EObject obj, AbstractNode abstractNode,
EReference eRef) {
EReference eOpposite = ((Internal) eRef).getEOpposite();
if (eOpposite != null) {
List<EObject> linkedObjects =
MyLinkingService.INSTANCE
.getLinkedObjects(obj, eRef,
abstractNode);
if (linkedObjects.size() == 1)
return linkedObjects.get(0);
return super.createProxy(obj, abstractNode, eRef);
What I cannot see is which "MyLinkingService.INSTANCE" the code is
referring to. Should I also change the default XTextLinkingService ?
I think I like the first resolution (set the resolveProxies ...) better,
but I dopn't know where I can get into the Xtext processing to change
these properties. Do you have a pointer for me?
Jos
Knut Wannheden wrote:
> Hi Jos,
> Also note the documented workarounds: Either set the resolveProxies
> property to "false" on the EReferences set by the Xtext parser or
> override the LazyLinker implementation for these references as outlined
> in the bug description.
> --knut
> Jos Warmer wrote:
| Re: [Xtext] Bidirectional properties handled incorrectly? [message #61423 is a reply to message #61375] |
Mon, 20 July 2009 11:24   |
Hi Jos,
Jos Warmer wrote:
> Hi Knut,
> @Override
> EReference eRef) {
> abstractNode);
The method createProxy can actually be overridden in a simpler way. I
think this should work (not tested):
abstractNode, EReference eRef) {
final EObject proxy = super.createProxy(obj, abstractNode, eRef);
if (eRef.getEOpposite() != null) {
return EcoreUtil.resolve(proxy, obj);
return proxy;
As you have references with opposites I assumed your Ecore model already
existed and wasn't inferred by Xtext. If that's the case you can set the
resolveProxies attribute in the Ecore file.
Keep in mind that both these approaches are workarounds only.
--knut
| Re: [Xtext] Bidirectional properties handled incorrectly? [message #61602 is a reply to message #61553] |
Mon, 20 July 2009 14:57  |
Hi Jos,
Jos Warmer wrote:
> Your new createProxy() method works fine for both the example and for the
> larger languages.
> The resolve proxies in the ecore file are all "true" already. It seems
> that this does not solve the problem.
You actually would have to set it to "false" for those references. Of
course you would have to check that doesn't cause problems for other
usages and consumers of the meta model. But it probably wouldn't.
--knut
Current Time: Thu Nov 06 17:30:20 EST 2025
Powered by FUDForum. Page generated in 0.05599 seconds
