| InPath jar is not used in real time compling [message #60977] |
Tue, 17 January 2006 01:02   |
Eclipse User  |
   I find that for those jars in InPath, I still have to include it in
build path, otherwise the real time compiling will have error for not
finding the types in the jars in Inpath. But if I have jars included in
build  path, then there will two places including the same classes. One
is the included jar, the other is classes out directory. So, I think the
reasonable arrangement is to have the real time compiler not to ignore
the jars in InPath.
Rice
| Re: InPath jar is not used in real time compling [message #61004 is a reply to message #60977] |
Tue, 17 January 2006 05:26   |
Eclipse User  |
Hi Rice,
Are you getting some kind of error or is there something that you are
trying to do that you can't?  I believe that the inpath is only made
available to the compiler at the weaving stage and not at the
compilation stage, so that if you have classes in a source folder that
refer to classes on the inpath you will need to also add it to the
classpath.  However we do have an enhancement that addresses this in
AJDT - https://bugs.eclipse.org/bugs/show_bug.cgi?id=92441
Sian
Rice Yeh wrote:
> the jars in InPath.
> Rice
| Re: InPath jar is not used in real time compling [message #591841 is a reply to message #60977] |
Eclipse User  |
Hi Rice,
Sian
Rice Yeh wrote:
> the jars in InPath.
> Rice
FUDForum. Page generated in 0.03128 seconds
