HELP: java.lang.IllegalStateException: Workspace is closed. [message #60777] |
Tue, 03 May 2005 19:22 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: a.b.c
Hi all,
I'm writing a plugin, and I'm blocked on a strange behavior. My plugin
contains a wizard, and as soon as I start a debug session for it and try
to open the wizard I get the following message on the console:
Unhandled event loop exception
Reason:
In the .log file, I find the exception shown at the end of this
messasge. I'm running Eclipse 3.1 M6. I've tried to debug the problem,
and here is what I'm seeing. The exception happens because when
ResourcesPlugin.getWorkspace() is called ResourcesPlugin.workspace is
null. The filed is set to null only in two places: at static
initialization (when the class is loaded), and in the shutdown() method.
I've placed a Watch on the workspace variable, and I do see it being
initialized with a valid instance before the debugged Workbench shows
up. However, when I try to open my wizard, I end up in the exception
without seing any more assignment to the workspace variable.
Can someone give me a hint? I'm totally lost!
Thank you,
Federica
org.eclipse.core.resources.ResourcesPlugin.getWorkspace(Reso urcesPlugin.java:320)
org.eclipse.ui.internal.ide.misc.ContainerSelectionGroup.cre ateTreeViewer(ContainerSelectionGroup.java:255)
org.eclipse.ui.internal.ide.misc.ContainerSelectionGroup.cre ateContents(ContainerSelectionGroup.java:205)
org.eclipse.ui.internal.ide.misc.ContainerSelectionGroup.<init >(ContainerSelectionGroup.java:142)
org.eclipse.ui.internal.ide.misc.ResourceAndContainerGroup.c reateContents(ResourceAndContainerGroup.java:174)
org.eclipse.ui.internal.ide.misc.ResourceAndContainerGroup.<init >(ResourceAndContainerGroup.java:135)
org.eclipse.ui.dialogs.WizardNewFileCreationPage.createContr ol(WizardNewFileCreationPage.java:189)
teja.TejaViewerCreationWizard$CreationPage.createControl(Tej aViewerCreationWizard.java:60)
org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1020)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1013)
at org.eclipse.jface.wizard.WizardDialog$4.run(WizardDialog.jav a:1003)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1001)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:753)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:345)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:89)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:842)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2894)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2527)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:803 )
at org.eclipse.jface.window.Window.open(Window.java:781)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1570)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1534)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:306)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:228)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:344)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:156)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:315 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:268)
at org.eclipse.core.launcher.Main.run(Main.java:942)
at org.eclipse.core.launcher.Main.main(Main.java:926)
Re: java.lang.IllegalStateException: Workspace is closed. [message #60781 is a reply to message #60777] |
Tue, 03 May 2005 19:59 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Pratik Shah![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ppshah%40us.ibm.com) Messages: 1077 Registered: July 2009 |
Wrong newsgroup.
"Federica" <a@b.c> wrote in message news:d58jd6$u5q$1@news.eclipse.org...
> Hi all,
> Reason:
> Thank you,
> Federica
> at
:320)
> at
> at
> at
> at
> at
> at
> at
izard.java:60)
> at
> at
> at
> at
> at
> at
tem.java:488)
> at
tionItem.java:400)
> at
> at
java:228)
> at
> at
> at
> at
..java:25)
Re: java.lang.IllegalStateException: Workspace is closed. [message #60782 is a reply to message #60781] |
Tue, 03 May 2005 20:22 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Pratik Shah wrote:
> Wrong newsgroup.
>>Hi all,
>>Reason:
>> Thank you,
>> Federica
>>at
> :320)
>>at
>>at
>>at
>>at
>>at
>>at
>>at
> izard.java:60)
>>at
>>at
>>at
>>at
>>at
>>at
> tem.java:488)
>>at
> tionItem.java:400)
>>at
>>at
> java:228)
>>at
>>at
>>at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>>at
>>at
> .java:25)
can you suggest the newsgruop where to post it?
thank you
Federica
FUDForum. Page generated in 0.07945 seconds
