Problem with Visual Editor 1.0 - create new VisualClass [message #60675] |
Wed, 22 September 2004 08:05  |
Originally posted by: hendriklenz.gmx.de
i will use the Visual Editor 1.0 with Eclipse 3.0.1. I have intsalled
all needed Plugins (GEF and EMF). When i create an new Java Project and
a new VisualClass i get this error:
#### begin of error ####
An internal error occurred during: "Setup Java Visual Editor".
java.lang.NoClassDefFoundError:
org/eclipse/jem/internal/plugin/JavaEMFNature
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initializeForProject(JavaVisualEditorPart.jav a:1691)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.initialize(JavaVisualEditorPart.java:1586)
org.eclipse.ve.internal.java.codegen.editorpart.JavaVisualEd itorPart$Setup.run(JavaVisualEditorPart.java:1396)
org.eclipse.core.internal.jobs.Worker.run(Worker.java:66)
#### end of error ####
What do i wrong? Has anyone some Hints for me?
Thanks Hendrik
Re: Problem with Visual Editor 1.0 - create new VisualClass [message #60692 is a reply to message #60679] |
Wed, 22 September 2004 12:18  |
Rich Kulp wrote:
> That's weird because if you got that far, JavaEMFNature should be there.
> Do you have anything else installed besides GEF and EMF?
> Also, is it GEF 3.0.1 and EMF 2.0.1, the released versions that just
> came out on Monday? Is the released version of VE that came out on
> Monday? Is the released version of Eclipse 3.0.1 that came out on Monday?
thanks thants it i have use the GEF 3.0.0 and EMF 2.0.0 i install now
the x.x.1 release of both and it works.
Thank you
Hendrik
Re: Problem with Visual Editor 1.0 - create new VisualClass [message #598798 is a reply to message #60675] |
Wed, 22 September 2004 10:37  |
Thanks, Rich Kulp
Re: Problem with Visual Editor 1.0 - create new VisualClass [message #598886 is a reply to message #60679] |
Thank you
Hendrik
FUDForum. Page generated in 0.03927 seconds
