Home » Eclipse Projects » Technology Project and PMC » [ANN] Eclipse Checkstyle v3.3 Released
[ANN] Eclipse Checkstyle v3.3 Released [message #60532] Mon, 12 January 2004 00:45 Go to next message
Originally posted by: NoSpam.atlas-sw.com
The Eclipse Checkstyle plug-in v3.3 is now available for download from the
project's SourceForge page at:
http://eclipse-cs.sourceforge.net/
Checkstyle is a very configurable Java code analyzer that can find and
report a number of potential problems in Java code. The current plug-in has
over 100 configurable rules to help you check your code.
Release notes for this release:
Bugs Resolved:
- 872279: Import Plugin Config produces duplicate entry
- 864322: empty block check doesn't work in 3.0M6
- 855057: configuration saved with wrong encoding
- 849075: Properties window is not long enough
- 820342: Property Variable Value Editor field length too short
- 787873: NPE in ArrayTypeStyleCheck
- 778321: Says Got a null pointer exception
- 773768: Cannot read hex numbers
- 773754: Exclude become Include
- 748678: Checkstyle fails to get class information for Exceptions
Other Items:
- Updated to include Checkstyle v3.3.
Enjoy, Dave
Re: [ANN] Eclipse Checkstyle v3.3 Released [message #60880 is a reply to message #60532] Tue, 13 January 2004 02:39 Go to previous message
I had to make a small update to the plugin.xml file for older Eclipse 2.0.x
and WSAD 5.0.x users. If you are using one of these older version please
download the updated release.
Dave
Re: [ANN] Eclipse Checkstyle v3.3 Released [message #596373 is a reply to message #60532] Tue, 13 January 2004 02:39 Go to previous message
David Schneider is currently offline David SchneiderFriend
Dave
Previous Topic:how to set eclipse for java Personal Profile development?
Next Topic:EclipseCon - Tutorials
Current Time: Fri Nov 08 22:18:48 GMT 2024
Powered by FUDForum. Page generated in 0.02872 seconds
