Home » Archived » XML Schema Definition (XSD) » Problems with generating list types
Re: Problems with generating list types [message #60519 is a reply to message #60495] |
Tue, 03 May 2005 14:30 |
Klaas,
Your sample is a simpler version of initializeFancyListTypeDefinition
from XSDPrototypical schema. (Yes, you need to set the anonymous base
type by adding it to simpleType.getContents() in addition to setting it
as the base type.)
Klaas Dellschaft wrote:
>Hi,
>I want to create the following list type programatically:
><xs:simpleType name="myType">
> <xs:restriction>
> <xs:simpleType>
> <xs:list itemType="xs:integer"/>
> </xs:simpleType>
> <xs:length value="4"/>
> </xs:restriction>
></xs:simpleType>
>I create the list type with the following code:
>XSDSimpleTypeDefinition simpleType = XSDFactory.eINSTANCE
> .createXSDSimpleTypeDefinition();
>simpleType.setItemTypeDefinition(itemType);
>xsdSchema.getContents().add(simpleType);
>If I query simpleType.getValidFacets() I get length, maxLength, minLength,
>whiteSpace, enumeration and pattern as valid facets of this type so I
>presumed that I can add the length-facet directly to the new list type. But
>when I serialize it to a file I get
><xs:simpleType>
> <xs:list itemType="xs:integer">
> </xs:list>
></xs:simpleType>
>What have I done wrong? Or am I mislead by the list of valid facets and I
>have to create an anonymous list type which is added as the base type of
>"myType" and there it is possible to set the facets?
>Cheers
>Klaas
Re: Problems with generating list types [message #60965 is a reply to message #60536] |
Thu, 05 May 2005 11:15 |
--------------030802040009090005000101
Klaas,
Asking the valid facets is really a question about what facets are
allowed in any derived class based on that type, it's not a question
about what syntactically I can do with the type definition itself. The
contents can really be one of three different things depending on the
nature of the simple type:
* Returns the value of the '<em><b>Contents</b></em>' containment
reference list.
* The list contents are of type {@link
org.eclipse.xsd.XSDSimpleTypeDefinition}.
* <!-- begin-user-doc -->
* <p>
* This concrete reference list represents the anonymous simple
type definition content of a
* <a
href="http://www.w3.org/TR/xmlschema-2/#element-restriction">restriction</a>,
* <a
href="http://www.w3.org/TR/xmlschema-2/#element-list">list</a>, or
* <a
href="http://www.w3.org/TR/xmlschema-2/#element-union">union</a>
element.
* </p>
* <!-- end-user-doc -->
* @return the value of the '<em>Contents</em>' containment
reference list.
* @see
org.eclipse.xsd.XSDPackage#getXSDSimpleTypeDefinition_Conten ts()
* @model type="org.eclipse.xsd.XSDSimpleTypeDefinition"
containment="true"
* @generated
EList getContents();
I believe that a simple test to know if it's syntactically valid to add
facets to a given simple type is to test if the variety of the base type
is the same as the variety of the type itself.
>>Your sample is a simpler version of initializeFancyListTypeDefinition from
>>XSDPrototypical schema. (Yes, you need to set the anonymous base type by
>>adding it to simpleType.getContents() in addition to setting it as the
>>base type.)
>OK, I will do that. But why do I get a list of valid facets for the
>simpleType if it isn't allowed to attach facets to it? This prevents me from
>generically allowing editing the facets of types. Instead I have to ask
>whether I edit a list-, union- or atomic-type and only then I know whether I
>can trust the information given by getValidFacets().
>This is also a problem in the Eclipse plugin: If you create a new list type
>and the right click on it -> New Child. There you will see that it allows to
>add facets directly to the type which will also result in a wrong serialized
>type.
>Klaas
<html>
<head>
<title></title>
</head>
Klaas,<br>
<br>
nature of the simple type:<br>
<blockquote><small> /**<br>
'<em><b>Contents</b&g t;</em>' containment
reference list.<br>
org.eclipse.xsd.XSDSimpleTypeDefinition}.<br>
* <!-- begin-user-doc --><br>
* <p><br>
* This concrete reference list represents the anonymous simple type
definition content of a<br>
* <a
href=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/TR/xmlschema-2/#element-restriction">"http://www.w3.org/TR/xmlschema-2/#element-restriction"</a>>restriction</a>,<br>
* <a
href=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/TR/xmlschema-2/#element-list">"http://www.w3.org/TR/xmlschema-2/#element-list"</a>>list</a>,
or<br>
* <a
href=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/TR/xmlschema-2/#element-union">"http://www.w3.org/TR/xmlschema-2/#element-union"</a>>union</a>
element.<br>
* </p><br>
* <!-- end-user-doc --><br>
containment reference list.<br>
* @see
org.eclipse.xsd.XSDPackage#getXSDSimpleTypeDefinition_Conten ts() <br>
containment="true"<br>
* @generated<br>
*/<br>
EList getContents();</small><br>
</blockquote>
type is the same as the variety of the type itself. <br>
<br>
<br>
<blockquote cite="midd59so6$909$1@news.eclipse.org" type="cite">
<blockquote type="cite">
<pre wrap="">Your sample is a simpler version of initializeFancyListTypeDefinition from
base type.)
</pre>
</blockquote>
<pre wrap=""><!---->
type.
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
--------------030802040009090005000101--
Re: Problems with generating list types [message #61085 is a reply to message #61062] |
Mon, 09 May 2005 13:32 |
--------------010009010700000307060604
Klaas,
There's always a base type definition, even if it is just
anyType/anySimpleType.
Some of these scenarios are tricky to enforce because setting one thing
may invalidate something you've already set. For example, I could add a
simple type definition to the contents of a simple type definition and
then set it as the base type, item type, or member type after, so you
kind of need to know what you are doing. (The editor should do a better
job, but we don't have the resource to make the editor really nice.)
Validation should diagnose any errors in how things are set up.
>I think a better test would be whether getBaseTypeDefinition() returns null
>or not. Only if it returns a concrete reference the current type is a
>restriction of another type. The base type might be an atomic, list or union
>type.
>Should the XSD plugin be comfortable enough that it is impossible to create
>invalid schemas or does the user have to know what he's doing? If it should
>be impossible to create invalid schema instances then you have to add the
>test into the plugin, too.
>Cheers
>Klaas
<html>
<head>
</head>
Klaas,<br>
<br>
anyType/anySimpleType.<br>
<br>
a simple type definition to the contents of a simple type definition
and then set it as the base type, item type, or member type after, so
you kind of need to know what you are doing. (The editor should do a
better job, but we don't have the resource to make the editor really
nice.) Validation should diagnose any errors in how things are set up.<br>
<br>
<br>
<blockquote cite="midd5nndk$u4b$1@news.eclipse.org" type="cite">
<pre wrap="">I believe that a simple test to know if it's syntactically valid to add
</pre>
</blockquote>
type.
Cheers
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
--------------010009010700000307060604--
Re: Problems with generating list types [message #595355 is a reply to message #60495] |
Ed Merks Messages: 33224 Registered: July 2009 |
Klaas,
as the base type.)
>Hi,
> <xs:restriction>
> <xs:simpleType>
> </xs:simpleType>
> </xs:restriction>
></xs:simpleType>
><xs:simpleType>
> </xs:list>
></xs:simpleType>
>Cheers
>Klaas
Ed Merks
Re: Problems with generating list types [message #595410 is a reply to message #60536] |
Klaas,
reference list.
* <p>
* <a
* <a
* <a
element.
* </p>
reference list.
* @see
containment="true"
* @generated
>>base type.)
>type.
>Klaas
<html>
<head>
<title></title>
</head>
Klaas,<br>
<br>
reference list.<br>
* <p><br>
* <a
* <a
or<br>
* <a
element.<br>
* </p><br>
* @see
* @generated<br>
*/<br>
</blockquote>
<br>
<br>
base type.)
</pre>
</blockquote>
type.
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: Problems with generating list types [message #595453 is a reply to message #61062] |
Klaas,
>type.
>Cheers
>Klaas
<html>
<head>
</head>
Klaas,<br>
<br>
<br>
<br>
<br>
</pre>
</blockquote>
type.
Cheers
Klaas
</pre>
</blockquote>
<br>
</body>
</html>
Ed Merks
Current Time: Sun Oct 06 07:24:14 GMT 2024
Powered by FUDForum. Page generated in 0.04177 seconds
