Home » Newcomers » Newcomers » Can't start debugger
Can't start debugger [message #60336] Mon, 02 May 2005 00:19 Go to next message
Originally posted by: dah.forefront-nw.com
I have been having no luck getting the eclipse debugger to start. Every
time I try, I get a dialog stating it can't connect to the VM. The details
say java.net.SocketException: Connection reset. This happens even with a
"Hello World" console app. I have another box (a laptop) which works fine.
I have comapred all the security settings I can think of and the two boxes
are identical, as are all the java and eclipse settings. I must have
missed something relevant, though!
Both boxes are running Win XP Pro service pack 2, eclipse 3.0.2, and JRE
1.5.0_02-b09. All apps run fine, they just can not be debugged.
Does anyone have any ideas what I have missed?
Many thanks,
Dave Head
Re: Can't start debugger [message #60755 is a reply to message #60336] Mon, 02 May 2005 17:08 Go to previous messageGo to next message
Darin Swanson is currently offline Darin SwansonFriend
Sounds like your firewall is getting in the way of the local connection?
HTH
Darins
"Dave Head" <dah@forefront-nw.com> wrote in message
news:d663b34a0b98df939a9a6a9397d56f59$1@www.eclipse.org...
> Many thanks,
> Dave Head
Re: Can't start debugger [message #60803 is a reply to message #60755] Thu, 05 May 2005 05:23 Go to previous messageGo to next message
Firewall? What firewall? I assume the debugger is trying to connect via
localhost. I have disabled the SP2 firewall, although I wouldn't think it
should have anything to do with it. The other box (the laptop) has the
same firewall configuration as the desktop (and it works!).
Confused, but thanks for the pointer.
Dave
Re: Can't start debugger [message #60817 is a reply to message #60336] Thu, 05 May 2005 17:30 Go to previous message
Originally posted by: jaredburns.no.spam.acm.org
You need to use a JDK. The JRE doesn't include the libraries for
establishing the debug connection.
Previous Topic:c/c++-project build don't run
Next Topic:Problems & Tasks Don't Show Up
Current Time: Sat Nov 09 02:49:22 GMT 2024
Powered by FUDForum. Page generated in 0.07971 seconds
