Re: DateChooser [message #5685 is a reply to message #5354] |
Mon, 12 March 2007 17:48   |
Originally posted by: jkrause.innoopract.com
Hi Roberto,
It is possible to integrate existing qooxdoo widgets (and other
JavaScript) into RAP. There is a brief description on how to do that in
principle in our EclipseCon tutorial (p23-p25):
slides: http://eclipsezilla.eclipsecon.org/attachment.cgi?id=468
A few explanations:
You need to implement
- a Java class representing the widget (e.g. Calendar)
- a Java class that maps the widget API to the client side JavaScript
(this is called a LifeCylcleAdapter - LCA), creating the widget and
receiving values from and transmitting values to the client side
- in case you need additional functionality on the client side you also
need to provide a JavaScript file
Maybe you should start by having a look at the GMap component project:
http://eclipsezilla.eclipsecon.org/attachment.cgi?id=515
This integrates an external JS, but gives a simple example of how to
create your custom widget.
Another good example is the Group widget, the GroupLCA and the Group.js
that you find in the RAP org.eclipse.rap.rwt project. If you want to
transmit data from the client-side to the server side (which neither
GMap nor Group do) you need to implement the readData method in the LCA,
see the SpinnerLCA as an example.
It is not easy, but it can be done ;-)
Hope that helps,
Jochen
Roberto wrote:
> Hello, I need a DateChooser (or Calendar) in my app. There is a
> DataChooser in qooxdoo Controls, you can see it in:
> http://demo.qooxdoo.org/current/sample/html/example/DateChoo ser_1.html
> AFAIK RAP Widget controls are based in qooxdoo Controls (see
> http://wiki.eclipse.org/index.php/WidgetToolkit), Is there any way to
> use "new" qooxdoo controls in RAP ? How ?
> Thanks in advance.
> Roberto.
Re: DateChooser [message #5811 is a reply to message #5685] |
Tue, 13 March 2007 03:24  |
Originally posted by: roberto.sanchez.autonomind.com
Thank you very much Jochen! Very useful info. :-)
I'm going try it ASAP.
I'll send feedback of my progress to the newsgroup.
Cheers.
Roberto
Jochen Krause wrote:
> Hi Roberto,
> A few explanations:
> Hope that helps,
> Jochen
>> Thanks in advance.
>> Roberto.
FUDForum. Page generated in 0.03662 seconds
