Trac problems with certificates [message #60054] |
Thu, 16 October 2008 09:38 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: alexander.lex.gmx.at
I have problems connecting to a trac server that uses a certificate.
When I try to download eg a task, then I get the following error message:
The certificate is not trusted because the issuer certificate is unknown.
(Error code: sec_error_unknown_issuer)
I had a similar issue with firefox, but this has been resolved somehow. The
certificate is certainly valid and the issuer is known to both firefox and
opera.
The certificiate is a Cybertrust Educational, a somewhat related discussion
is here:
http://www.nabble.com/About-the-Cybertrust-Educational-CA-ce rtificate-td19513129.html
I used to ignore the warnings in Firefox (which does not seem to be possible
in Mylyn) but don't get any warnings in Firefox any more (and I have not
added an exception in Firefox)
What can I do to make mylyn work with that trac repository?
Alex
Re: Trac problems with certificates [message #60126 is a reply to message #60078] |
Fri, 17 October 2008 09:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Great! Worked perfectly!
Thx!
Alex
Steffen Pingel wrote:
> Try following the steps outlined here:
http://wiki.eclipse.org/Mylyn/FAQ#Why_do_I_get_an_error_when _accessing_secured_web_sites.3F
> I am not sure if this still works with current versions of the internal
> browser.
> Steffen
> Alexander Lex wrote:
>> The certificate is certainly valid and the issuer is known to both
>> firefox and opera.
>> discussion is here:
>> possible in Mylyn) but don't get any warnings in Firefox any more (and I
>> have not added an exception in Firefox)
>> Thanks,
>> Alex
FUDForum. Page generated in 0.05032 seconds
