Home » Eclipse Projects » Eclipse Platform » A cycle was detected in the classpath of project: StarList
A cycle was detected in the classpath of project: StarList [message #59397] Mon, 02 June 2003 12:38 Go to next message
Originally posted by: dougr.rmsfinance.com
[1] Can someone tell me what I have done to create this error: "A cycle
was detected in the classpath of project: StarList" ? and
[2] How do I get rid of it?
regards,
Douglas Reames
Re: A cycle was detected in the classpath of project: StarList [message #59644 is a reply to message #59397] Mon, 02 June 2003 14:30 Go to previous message
Originally posted by: richkulp.NOSPAM.us.ibm.com
This means your project has another project as a required project, but
that other project, eventually, requires the first project. This is a
circle, and by default is not allowed.
This can be turned off for a project if the two projects really depend
upon each other, but if this happened without you realizing it, then it
probably is a mistaken dependency.
Rich
Previous Topic:Eclipse & RedHat 9 startup problem
Next Topic:HELP: trouble getting overrideActionId to work
Current Time: Fri Apr 25 01:39:10 EDT 2025
Powered by FUDForum. Page generated in 0.02077 seconds
