Re: epl-v10 Question [message #59424 is a reply to message #59400] |
Mon, 13 July 2009 15:29 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Bill Winspur![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=bwinspur%40wynnon.com) Messages: 180 Registered: July 2009 |
Ed Merks wrote:
> Bill,
> Ask your lawyer if you want legal advice. :-P
> My free non-legal advice is that as long as you make the source code of
> your modified variant publicly available, you're doing exactly what's
> required.
> Bill Winspur wrote:
>> I would like to create a (probably renamed) variant of Class
>> XMLMemento (and inteface IMemento) that is not dependent on package
>> org.eclipse.ui.internal, and would package the modified class as a jar
>> to be used:
>> 1. In junit test cases in launched from eclipse, but not running in the
>> plugin environment.
>> 2. In external tools launched from eclipse.
>> 3. In java applications completely separate from eclipse.
>> Can I acomplish this without violating the the terms of epl-v10, under
>> which XMLMemento is currently distributed?
>> Bill Winspur
Thanks Ed,
However, being a recluse by nature, I have never made code publicly
available. In all seriousness, could you suggest a low-cost way that I
could do that?
Bill
Re: epl-v10 Question [message #59448 is a reply to message #59424] |
Mon, 13 July 2009 16:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33201 Registered: July 2009 |
Bill,
Dump it in a zip file and have a link for it only any publicly
accessible website. Or open a bugzilla, and dump it there; even if it's
closed or rejected, it will still be recorded...
Bill Winspur wrote:
> Ed Merks wrote:
>> Bill,
>> of your modified variant publicly available, you're doing exactly
>> what's required.
>>> jar to be used:
>>> plugin environment.
>>> under which XMLMemento is currently distributed?
>>> Bill Winspur
> Thanks Ed,
> could do that?
> Bill
Ed Merks
Re: epl-v10 Question [message #59473 is a reply to message #59448] |
Mon, 13 July 2009 17:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks wrote:
> Bill,
> Bill Winspur wrote:
>> Ed Merks wrote:
>>> Bill,
>>> what's required.
>>>> jar to be used:
>>>> plugin environment.
>>>> Bill Winspur
>> Thanks Ed,
>> could do that?
>> Bill
Will do, one of those. Thanks, Bill.
FUDForum. Page generated in 0.03314 seconds
