Home » Modeling » OCL » UML and generate code
UML and generate code [message #59048] |
Fri, 04 July 2008 02:49  |
Originally posted by: pieter.martin.gmail.com
I am currently generating code from UML diagrams by importing the model
into the UML2 api and then using Jet templates.
I am not using emf generation.
I would like to generate OCL constaints and queries.
I have read the article Implementing Model Integrity in EMF with OCL and
it is exactly what I would like to do only using the UML2 api and not
with EMF.
Does OCL need the objects to be EObject(s) with all the associated
resources and registries?
The objects I generate are in general persisted with hibernate.
Can someone please provide me with some pointers.
Pieter
Re: UML and generate code [message #59121 is a reply to message #59097] |
Fri, 04 July 2008 09:45   |
Originally posted by: cdamus.zeligsoft.com
--=-c7sEf0FBKEIX1PTf2K1s
Content-Type: text/plain
Hi, Pieter,
Yes, the MDT OCL implementation requires model elements and run-time
elements, alike, to be EObjects. The meta-meta-model of this OCL
implementation is Ecore.
Christian
On Fri, 2008-07-04 at 15:29 +0200, pieter martin wrote:
> Ed Merks wrote:
> > Pieter,
> > Comments below.
> >> Hi,
> >> model into the UML2 api and then using Jet templates.
> > I wonder why not?
> >> and it is exactly what I would like to do only using the UML2 api and
> >> not with EMF.
> > You could use Teneo to do that with EMF-generated code.
> >> Thanks
> >> Pieter
> Thanks for the Teneo advise, I'll have a look at theie approach to
> customizing emf code generation.
> I am not using emf because I do not need to have such complicated
> objects and admittedly a lot of it I do not understand (yet). That also
> means that it is not really applicable to our domain.
> We make heavy use of profiles and find it very easy to generate domain
> specif stuff, custom annotations mostly, from the profile information.
> I do think it is more natural to generate directly from the UML model as
> that is the language that we model and think in.
> I also imagine that when we get more sophisticated in generation that it
> will be possible to generate code from State and Activity Diagrams. Not
> sure if emf generation will still be an option then.
> My main concern though is OCL constraints and queries.
> Cheers
> Pieter
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Pieter,<BR>
<BR>
Yes, the MDT OCL implementation requires model elements and run-time elements, alike, to be EObjects. The meta-meta-model of this OCL implementation is Ecore.<BR>
<BR>
Cheers,<BR>
<BR>
Christian<BR>
<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Ed Merks wrote:</FONT>
<FONT COLOR="#000000">> Pieter,</FONT>
<FONT COLOR="#000000">> </FONT>
<FONT COLOR="#000000">> Comments below.</FONT>
<FONT COLOR="#000000">> pieter martin wrote:</FONT>
<FONT COLOR="#000000">>> Hi,</FONT>
<FONT COLOR="#000000">>></FONT>
<FONT COLOR="#000000">>> I am currently generating code from UML diagrams by importing the </FONT>
<FONT COLOR="#000000">>> model into the UML2 api and then using Jet templates.</FONT>
<FONT COLOR="#000000">>> I am not using emf generation.</FONT>
<FONT COLOR="#000000">> I wonder why not?</FONT>
<FONT COLOR="#000000">>> I would like to generate OCL constaints and queries.</FONT>
<FONT COLOR="#000000">>> I have read the article Implementing Model Integrity in EMF with OCL </FONT>
<FONT COLOR="#000000">>> and it is exactly what I would like to do only using the UML2 api and </FONT>
<FONT COLOR="#000000">>> not with EMF.</FONT>
<FONT COLOR="#000000">>> Does OCL need the objects to be EObject(s) with all the associated </FONT>
<FONT COLOR="#000000">>> resources and registries?</FONT>
<FONT COLOR="#000000">>> The objects I generate are in general persisted with hibernate.</FONT>
<FONT COLOR="#000000">> You could use Teneo to do that with EMF-generated code.</FONT>
<FONT COLOR="#000000">>> Can someone please provide me with some pointers.</FONT>
<FONT COLOR="#000000">>> Thanks</FONT>
<FONT COLOR="#000000">>> Pieter</FONT>
<FONT COLOR="#000000">Hi,</FONT>
<FONT COLOR="#000000">Thanks for the Teneo advise, I'll have a look at theie approach to </FONT>
<FONT COLOR="#000000">customizing emf code generation.</FONT>
<FONT COLOR="#000000">I am not using emf because I do not need to have such complicated </FONT>
<FONT COLOR="#000000">objects and admittedly a lot of it I do not understand (yet). That also </FONT>
<FONT COLOR="#000000">means that it is not really applicable to our domain.</FONT>
<FONT COLOR="#000000">We make heavy use of profiles and find it very easy to generate domain </FONT>
<FONT COLOR="#000000">specif stuff, custom annotations mostly, from the profile information.</FONT>
<FONT COLOR="#000000">I do think it is more natural to generate directly from the UML model as </FONT>
<FONT COLOR="#000000">that is the language that we model and think in.</FONT>
<FONT COLOR="#000000">I also imagine that when we get more sophisticated in generation that it </FONT>
<FONT COLOR="#000000">will be possible to generate code from State and Activity Diagrams. Not </FONT>
<FONT COLOR="#000000">sure if emf generation will still be an option then.</FONT>
<FONT COLOR="#000000">My main concern though is OCL constraints and queries.</FONT>
<FONT COLOR="#000000">Does OCL need the objects to be EObject(s) with all the associated </FONT>
<FONT COLOR="#000000">resources and registries?</FONT>
<FONT COLOR="#000000">Cheers</FONT>
<FONT COLOR="#000000">Pieter</FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-c7sEf0FBKEIX1PTf2K1s--
Re: UML and generate code [message #59147 is a reply to message #59097] |
Fri, 04 July 2008 11:50   |
Pieter,
Comments below.
> Ed Merks wrote:
>> Pieter,
>> Comments below.
>>> Hi,
>> I wonder why not?
>>> and not with EMF.
>>> Thanks
>>> Pieter
Interestingly they really don't need to customize the code generation
since the mapping from the instances to the database can be specified
external to the generated code...
> also means that it is not really applicable to our domain.
So many folks start out assuming they don't need all this stuff, but of
course over time, their applications become more sophisticated and they
end up needing it.
I see, that's a pretty good reason. I'm not sure how much of the
profile information ends up being mapped to Ecore annotations...
> as that is the language that we model and think in.
That's a reasonable argument as well. Though Ecore is like a subset of
UML, and a much simpler one at that....
> it will be possible to generate code from State and Activity Diagrams.
> Not sure if emf generation will still be an option then.
No, Ecore only focuses on class structure, not all the other more
complex UML aspects.
As Christian says, yes, OCL relies heavily on the metadata that EMF
provides.
> Cheers
> Pieter
Re: UML and generate code [message #59171 is a reply to message #59147] |
Fri, 04 July 2008 12:29  |
Thanks for the responses et al!
Cheers
Pieter
Ed Merks wrote:
> Pieter,
> Comments below.
>> Ed Merks wrote:
>>> Pieter,
>>> Comments below.
>>>> Hi,
>>> I wonder why not?
>>>> and not with EMF.
>>>> Thanks
>>>> Pieter
> end up needing it.
> provides.
>> Cheers
>> Pieter
Current Time: Sun Oct 19 06:59:31 EDT 2025
Powered by FUDForum. Page generated in 0.05677 seconds
