Home » Archived » XML Schema Definition (XSD) » Problems with <redefine>
Problems with <redefine> [message #59031] Thu, 07 April 2005 02:07 Go to next message
Originally posted by: lgardner.tycoint.com
Hi all,
I'm trying to access a schema containing a <redefine> section and am
getting unexpected results.
I have a basic schema (test,xsd):
<schema xmlns="http://www.w3.org/2001/XMLSchema"
targetNamespace="http://test.com" xmlns:sdk="http://test.com">
<element name="toplevel">
<annotation sdk:caption="TOP LEVEL"/>
<complexType>
<sequence>
<element ref="sdk:base" />
</sequence>
</complexType>
</element>
<complexType name="base-type">
<attribute name="attr1" type="string" />
</complexType>
<element name="base" type="sdk:base-type" />
</schema>
which I can use with the following instance document (test.xml):
<toplevel xmlns="http://test.com"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://test.com file:c:/Temp/test.xsd">
<base attr1="Attribute 1"/>
</toplevel>
If I load and query the schema:
XSDResourceImpl xsdResource = (XSDResourceImpl)
resourceSet.getResource(uri, true);
XSDSchema schema = xsdResource.getSchema();
XSDAnnotation annotation =
schema.resolveElementDeclaration("http://test.com",
"toplevel").getAnnotation();
then my annotation contains (as expected) the 'sdk:caption' attribute.
I then perform exactly the same steps again but now using a redefined
schema (redefined.xsd):
<redefine schemaLocation="file:c:/temp/test.xsd">
<complexContent>
<extension base="sdk:base-type">
<attribute name="added" type="string" />
</extension>
</complexContent>
</complexType>
</redefine>
</schema>
with the extended instance document (redefined.xml):
xsi:schemaLocation="http://test.com file:c:/Temp/redefined.xsd">
<base attr1="Attribute 1" added="Added"/>
</toplevel>
When I load and query the schema (exactly as before) the 'toplevel'
annotation element now has 0 attributes.
Have I stumbled over a bug or is this not the way redefines are supposed
to work?
Thanks in advance,
Lewis Gardner
Re: Problems with <redefine> [message #59057 is a reply to message #59031] Thu, 07 April 2005 11:17 Go to previous message
--------------000503080402080601000208
Lewis,
This sounds like:
88092 <https://bugs.eclipse.org/bugs/show_bug.cgi?id=88092>
Lewis Gardner wrote:
> Hi all,
> <complexType>
> <sequence>
> </sequence>
> </complexType>
> </element>
> </complexType>
> </schema>
> </toplevel>
> <complexContent>
> </extension>
> </complexContent>
> </complexType>
> </redefine>
> </schema>
> </toplevel>
> supposed to work?
> Thanks in advance,
> Lewis Gardner
<html>
<head>
http-equiv="Content-Type">
<title></title>
</head>
Lewis,<br>
<br>
This sounds like:<br>
<blockquote><a
href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=88092">88092</a><br>
</blockquote>
<br>
<blockquote cite="mid8b2713a91687217a5ccf43b6e41ef6ad$1@www.eclipse.org"
type="cite">Hi all,
<br>
<br>
I'm trying to access a schema containing a &lt;redefine&gt; section and
am getting unexpected results.
<br>
<br>
<br>
<br>
&lt;schema xmlns=<a class="moz-txt-link-rfc2396E" href="http://www.w3.org/2001/XMLSchema">"http://www.w3.org/2001/XMLSchema"</a>
<br>
Re: Problems with <redefine> [message #594687 is a reply to message #59031] Thu, 07 April 2005 11:17 Go to previous message
Lewis,
This sounds like:
> Hi all,
> <complexType>
> <sequence>
> </sequence>
> </complexType>
> </element>
> </complexType>
> </schema>
> </toplevel>
> <complexContent>
> </extension>
> </complexContent>
> </complexType>
> </redefine>
> </schema>
> </toplevel>
> supposed to work?
> Thanks in advance,
> Lewis Gardner
<html>
<head>
<title></title>
</head>
Lewis,<br>
<br>
<blockquote><a
</blockquote>
<br>
type="cite">Hi all,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Ed Merks
Previous Topic:Problems with <redefine>
Next Topic:Determining if an <include>'d schema has a defined target namespace
Current Time: Sun Jul 07 06:40:17 GMT 2024
Powered by FUDForum. Page generated in 0.03540 seconds
