Re: Grammars without 'with' generate errors [message #59050 is a reply to message #59002] |
Wed, 15 July 2009 11:31 |
Sebastian Zarnekow Messages: 3118 Registered: July 2009 |
Hi Christophe,
this is a bug in Xtext. Please define your terminal rules at the end of
the file. A bugzilla is welcome ;-)
Sorry for inconvenience,
Sebastian
Am 15.07.2009 11:54 Uhr, schrieb Christophe Avare:
> I just tried to make a very simple Xtest grammar but get Java code errors.
> The error lies in the ui fragment inside
> org.xtext.example.contentassist.antlr.MyDslParser.getFollowE lements()
> where the InternalMyDslParser.entryRuleModel() is not found/generated.
> The test is quite simple: i moved all the terminals from the orginal
> grammar, copied the definitions in the current grammar and removed the
> 'with' keyword.
> My goal is to have 'autonomous' grammars, that is containing terminals
> and rules in the same file (they are very small, more like ASCII
> protocol decoding than DSLs for humans), as i did for years with ANTLR.
> What i'm doing wrong?
> (It is counter-intuitive to me to have to separate terminals and rules
> for even the most basic grammar.)
> [For reference, the xtext grammar):
> grammar org.xtext.example.MyDsl hidden(WS, ML_COMMENT, SL_COMMENT)
> import "http://www.eclipse.org/emf/2002/Ecore" as ecore
> generate myDsl "http://www.xtext.org/example/MyDsl"
> terminal ID : '^'?('a'..'z'|'A'..'Z'|'_')
> ('a'..'z'|'A'..'Z'|'_'|'0'..'9')* ;
> terminal INT returns ecore::EInt: ('0'..'9')+ ;
> terminal STRING : '"' ( '\\' ('b'|'t'|'n'|'f'|'r'|'"'|"'"|'\\') |
> "'" ( '\\' ('b'|'t'|'n'|'f'|'r'|'"'|"'"|'\\') | !('\\'|"'") )* "'";
> terminal ML_COMMENT : '/*' -> '*/' ;
> terminal SL_COMMENT : '//' !('\n'|'\r')* ('\r'? '\n')? ;
> terminal WS : (' '|'\t'|'\r'|'\n')+ ;
> terminal ANY_OTHER: . ;
> Model :
> (imports+=Import)*
> (elements+=Type)*;
> Import :
> 'import' importURI=STRING;
> Type:
> DataType | Class;
> DataType:
> 'datatype' name=ID ';'?;
> Class :
> 'class' name=ID ('extends' superClass=[Class])? '{'
> properties+=Property*
> Property:
> Attribute | Reference;
> Attribute:
> 'attr' name=ID ':' type=[DataType] ';'?;
> Reference:
> 'ref' name=ID ':' type=[Class] ';'?;
FUDForum. Page generated in 0.03729 seconds
