Re: Out of memory when building PHP project [message #59073 is a reply to message #58970] |
Thu, 18 October 2007 23:46 |
Originally posted by: eclipsenews.20.epm.spamgourmet.com
Hi Bogdan,
This is a frequent and serious problem for me also. I've raised a bug:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=206109
I am surprised you get it on a project with so few files, but I think it
is just a memory leak somewhere, maybe something in one of your files is
triggering it. I did notice a php file in the YUI library with a 1.5mb
string which can single handedly kill PDT for me.
You can sort of work around it by turning off 'Build Automatically' from
the Project menu... but as you mentioned, if a project fails to build
then code completion, find declaration, outlines, and most of the other
stuff that make an IDE useful stop working.
Go add your vote!
Cheers
Tom
Bogdan Ribic wrote:
> Hi All,
> Every time I open a PHP project (around 50 PHP files total) I get out
> of memory error and occasionaly eclipse freezes for a time while
> 'building' the PHP project.
> Anyway, I tried increasing all VM parameters as much as jvm would
> allow me (on a 2GB machine), eclipse.ini looks like this:
> -showsplash
> org.eclipse.platform
> --launcher.XXMaxPermSize
> 256m
> -vmargs
> -XX:MaxPermSize=256m
> -Xms512m
> -Xmx512m
> But I still keep getting this:
> !ENTRY org.eclipse.core.jobs 4 2 2007-10-18 11:42:06.984
> !MESSAGE An internal error occurred during: "Building PHP projects ...".
> !STACK 0
> java.lang.OutOfMemoryError: Java heap space
> at
> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeFunctionsParameterArray(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeFunctionData(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeFunctionDataArray(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeClassData(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizeClassDataArray(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPFileData(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.SerializationUtil.deseria lizePHPFileDataArray(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.DefaultCacheManager.inner LoadModel(Unknown
> Source)
> at
> org.eclipse.php.internal.core.util.DefaultCacheManager.load( Unknown Source)
> at
> org.eclipse.php.internal.core.phpModel.parser.PHPUserModelMa nager. <init>(Unknown
> Source)
> at
> org.eclipse.php.internal.core.phpModel.parser.PHPUserModel.i nitialize(Unknown
> Source)
> at
> org.eclipse.php.internal.core.phpModel.parser.PHPProjectMode l.initialize(Unknown
> Source)
> at
> org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.putModel(Unknown
> Source)
> at
> org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager.getModelForProject(Unknown
> Source)
> at
> org.eclipse.php.internal.core.project.build.FullPhpProjectBu ildVisitor.handle(Unknown
> Source)
> at
> org.eclipse.php.internal.core.project.build.FullPhpProjectBu ildVisitor.visit(Unknown
> Source)
> at
> org.eclipse.core.internal.resources.Resource$2.visit(Resourc e.java:105)
> at
> org.eclipse.core.internal.resources.Resource$1.visitElement( Resource.java:57)
> at
> org.eclipse.core.internal.watson.ElementTreeIterator.doItera tion(ElementTreeIterator.java:81)
> at
> org.eclipse.core.internal.watson.ElementTreeIterator.iterate (ElementTreeIterator.java:126)
> at
> org.eclipse.core.internal.resources.Resource.accept(Resource .java:67)
> at
> org.eclipse.core.internal.resources.Resource.accept(Resource .java:103)
> at
> org.eclipse.core.internal.resources.Resource.accept(Resource .java:87)
> at
> org.eclipse.php.internal.core.phpModel.parser.PHPWorkspaceMo delManager$3.runInWorkspace(Unknown
> Source)
> at
> org.eclipse.core.internal.resources.InternalWorkspaceJob.run (InternalWorkspaceJob.java:38)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
Re: Out of memory when building PHP project [message #59098 is a reply to message #58970] |
Thu, 18 October 2007 23:49 |
Also, your stack trace looks a little different to mine, you should post
that to the ticket also.
I think the build process is particularly flaky and can break in several
ways.
Bogdan Ribic wrote:
> Hi All,
> -showsplash
> 256m
> -vmargs
> -Xms512m
> -Xmx512m
> !STACK 0
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
Re: Out of memory when building PHP project [message #59145 is a reply to message #58970] |
Fri, 19 October 2007 09:05 |
Originally posted by: news.kasimir-k.fi
Bogdan Ribic scribeva in 18/10/2007 9:44:
> -showsplash
> 256m
> -vmargs
> -Xms512m
> -Xmx512m
You are setting MaxPermSize twice there - probably not a problem but
anyway.
I've got a 2GB machine too, and my eclipse.ini looks like:
-showsplash
-vmargs
-Xms256m
-Xmx1024m
which seems to have gotten rid of out-of-memories. What could be
happening is that your MaxPermSize is too close to -Xmx, so that the
heap runs out of memory.
How about either
- increasing -Xmx to 1024
- reducing MaxPermSize to 128m (which I believe should be well enough
for perm)
..k
Re: Out of memory when building PHP project [message #59266 is a reply to message #59073] |
Sat, 20 October 2007 16:20 |
Bogdan Ribic Messages: 13 Registered: July 2009 |
Junior Member |
Hi Tom,
I tried lots of hacks, finaly deleted /.cache/model.dat (or something
like that, don't remember anymore) and after restarting eclipse all
worked. Though it might have been anything else I tried before that :)
Boban.
Tom Walter wrote:
> Hi Bogdan,
> Go add your vote!
> Cheers
> Tom
Re: Out of memory when building PHP project [message #59532 is a reply to message #59266] |
Wed, 24 October 2007 11:47 |
Originally posted by: lmanic-unwanted.gmx.de
Hi Bogdan,
that worked for me too, thanks a million for that hint!! :)
The file was named /.cache/.dataModel btw.
Markus
Bogdan Ribic schrieb:
> Hi Tom,
> Boban.
Re: Out of memory when building PHP project [message #61718 is a reply to message #58970] |
Tue, 27 November 2007 22:47 |
Originally posted by: sangala.seznam.cz
Solution (helpful for me):
1.step
identify trouble project in workspace
start eclipse (ignore errors ... no close)
Close all projects
shut down eclipse
start eclipse
Open each projects (one after another)
on error stop (it is THE BAD PROJECT)
Close 'THE BAD PROJECT'
Delete 'THE BAD PROJECT' !!!!! DO NOT DELETE CONTENT !!!!!
shut down eclipse
2.step
increase memory limits
For 2Gb Ram is good idea something like:
-showsplash
-vmargs
-Xms256m
-Xmx1024m
3.step
delete from project folder these files (all project setting !!!):
cache
project
settings
4.step
start eclipse
5.step
import THE BAD --GOOD FOR NOW-- PROJECT as PHP Project
FUDForum. Page generated in 0.05141 seconds
