Re: Files lost from context [message #59414 is a reply to message #59141] |
Sat, 04 October 2008 18:58 |
Originally posted by: steffen.pingel.eclipse.org
It is likely that the JavaScript file has a lower interest and decay causes
it drop out of the context on task activation. This comment summarizes the
problems that were fixed in the latest weekly build:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=245234#c14
It would be great if you could try the latest build and report back if that
fixes the problem you are seeing:
http://www.eclipse.org/mylyn/downloads/#weekly
Steffen
> Hi Steffen,
> It does seem to have some resemblance, except for the fact that I have a
> different reproduction path. I'm running Eclipse 3.4 on Ubuntu Hardy and
> only use Maven2 from the terminal (so no m2eclipse that generates files).
> Here's my way to reproduce:
> I activate a new task. I then open a java file and a javascript file. My
> PackageExplorer only shows me these two files and I can work clutter free.
> I then deactivate the task and go for some coffee. When I come back I
> reactive the same task and Mylyn will open the 2 files again (java and
> javascript editor) but, only the Java file shows up in the
> PackageExplorer.
> Spike
FUDForum. Page generated in 0.03622 seconds
