Re: Library aspectrt.jar with Internet Explorer JVM : compatible or not ? [message #58859 is a reply to message #58833] |
Thu, 24 November 2005 08:25 |
Originally posted by: clemas.uk.ibm.com
What kind of failure do you see? aspectjrt.jar is a Java 1.1 compliant
module - we don't do explicit testing with the JVMs in web browsers but
if it doesn't work then it sounds like a bug.
Andy.
Antoine Hugueney wrote:
> I tried and used aspectjrt.jar (eclipse 3.1) with Internet Explorer JVM
> (5.0.0.3810 / XP sp2). But it failed with a very simple pointcut (trace).
> The same worked with the Sun plug-in (JDK 1.5.0_05).
> So I guess that the bytecode produced by the AspectJ tools (built from
> 17/11/2005) are lacking some important compatibility with Internet Explorer
> JVM.
> But the documentation referenced at
> http://www.eclipse.org/aspectj/doc/next/devguide/compatibili ty.html#javaCompatibility
> says that it should run. So how could I manage to fix this in someway ?
> Thanks a lot in advance,
> Antoine Hugueney (Java programmer)
FUDForum. Page generated in 0.03231 seconds
