Re: Eclipse File System (EFS) and PDT -- Compatibility Problems [message #58828 is a reply to message #58779] |
Wed, 17 October 2007 04:52 |
Originally posted by: kevinjdoyle.rogers.com
Hi Bret,
The reason you are seeing this NPE is because WST Editors are not fully
EFS aware. Bug 196172 (
https://bugs.eclipse.org/bugs/show_bug.cgi?id=196172 ) is open for
tracking this issue. To fix this you can upgrade to WST 2.0.1. I
haven't had a chance to test it completely and since the bug is still
open it looks like WST isn't fully EFS aware still, but you can at least
open files with WST 2.0.1.
btw. You may want to check out the Target Management (
http://www.eclipse.org/dsdp/tm ) project. It's Remote System Explorer
EFS implementation supports sftp. This is what I am using.
Kevin Doyle
Bret Lester wrote:
> Hello, I'm writing a sftp remote filesystem browser for eclipse as an
> extension of EFS. I was hoping it would be compatible with PDT. Are
> there any known compatibility problems with EFS and anything in PDT? My
> plugin causes a NullPointerException when I try to open a file. Stack
> trace follows. Probably a shot in the dark but I'd appreciate any help.
> --Thanks, Bret
> java.lang.NullPointerException
> at
> org.eclipse.wst.sse.core.internal.FileBufferModelManager.cre ateURIResolver(FileBufferModelManager.java:419)
> at
> org.eclipse.wst.sse.core.internal.FileBufferModelManager.get Model(FileBufferModelManager.java:656)
> at
> org.eclipse.wst.sse.core.internal.model.ModelManagerImpl._ge tModelFor(ModelManagerImpl.java:393)
> at
> org.eclipse.wst.sse.core.internal.model.ModelManagerImpl.get ModelForEdit(ModelManagerImpl.java:1020)
> at
> org.eclipse.wst.sse.ui.StructuredTextEditor.doSetInput(Struc turedTextEditor.java:2113)
> at
> org.eclipse.php.internal.ui.editor.PHPStructuredEditor.doSet Input(Unknown
> Source)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor$19.run(Abstract TextEditor.java:2994)
> at
> org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:369)
> at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:313)
> at
> org.eclipse.jface.window.ApplicationWindow$1.run(Application Window.java:758)
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:67)
> at
> org.eclipse.jface.window.ApplicationWindow.run(ApplicationWi ndow.java:755)
> at
> org.eclipse.ui.internal.WorkbenchWindow.run(WorkbenchWindow. java:2451)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.internalInit(Ab stractTextEditor.java:3012)
> at
> org.eclipse.ui.texteditor.AbstractTextEditor.init(AbstractTe xtEditor.java:3039)
> at
> org.eclipse.wst.sse.ui.StructuredTextEditor.init(StructuredT extEditor.java:2615)
> at
> org.eclipse.php.internal.ui.editor.PHPStructuredEditor.init( Unknown Source)
> at
> org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:794)
> at
> org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:643)
> at
> org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:426)
> at
> org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:592)
> at
> org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:263)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2721)
> at
> org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2633)
> at
> org.eclipse.ui.internal.WorkbenchPage.access$12(WorkbenchPag e.java:2625)
> at
> org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2577)
> at
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2572)
> at
> org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2556)
> at
> org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:340)
> at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:328)
> at
> org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:190)
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
> at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:938)
> at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3682)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3293)
> at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2389)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2353)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 19)
> at org.eclipse.ui.internal.Workbench$4.run(Workbench.java:466)
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:289)
> at
> org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:461)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:106)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:153)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:106)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:76)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:363)
> at
> org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:176)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 504)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:443)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1169)
FUDForum. Page generated in 0.04014 seconds
