Re: Common Navigator Framework [message #5245] |
Tue, 03 June 2008 15:13 |
Francis Upton IV Messages: 472 Registered: July 2009 Location: Oakland, CA |
(Moving to PDE)
Not sure why this is happening. The extension points show up the in the
dialog to allow them to be selected? And as you said privately, you
have org.eclipse.ui.navigator as a plugin dependency.
What do you do exactly to get this error?
Francis
Joe Hutson wrote:
> I�m working through Michael Elder�s CNF tutorials as a second pass at
> gaining some experience with the CNF. I am having trouble getting the
> manifest editor to find extension point schema and definition for
> org.eclipse.ui.navigator.viewer and
> org.eclipse.ui.navigator.navigatorContent. The error message is
> 'Extension point schema org.eclipse.ui.navigator.viewer cannot be found.'
> Eclipse version 3.3.2
> org.eclipse.ui.navigator is configured as dependency for my plug-in
> Any suggestions?
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
Re: Common Navigator Framework [message #5759 is a reply to message #5690] |
Tue, 03 June 2008 21:43 |
Francis Upton (News) wrote:
> No, I'm wrong about the schema folder needing to be in *that* jar file.
> I found it in the source jar file (the one I was previously looking at
> was one I built myself).
> Do you have the _source plugin for the navigator?
> (I'm just guessing here, we really need someone who understands the PDE,
> I bet they could answer this in a second).
Even tough I've been using PDE on a daily basis for over a year, I don't
really "understand" it. ;-)
But, I do know that if the user did not install the SDK or Eclipse for
RCP/Plugin Developers package, he won't have the source plugins for PDE.
That is probably why the manifest/plugin editor can't find the schemas.
I'd advise to get one of those packages that are specially built for
plugin development.
Hope this helps,
Eric
> Joe Hutson wrote:
>> The schema folder is not there. The schema attribute in the
>> plugin.xml (below) seems to indicate that it should be? Jar Version:
>> org.eclipse.ui.navigator_3.3.2.M20080207-0800
>> <?xml version="1.0" encoding="UTF-8"?>
>> <?eclipse version="3.0"?>
>> <plugin>
>> <extension-point id="navigatorContent"
>> name="%ExtPoint_navigatorContent" schema="schema/navigatorContent.exsd"/>
>> <extension-point id="viewer" name="%ExtPoint_navigatorViewer"
>> schema="schema/viewer.exsd"/>
>> <extension-point id="linkHelper" name="%Link_Helper"
>> schema="schema/linkHelper.exsd"/>
>> <extension
>> point="org.eclipse.ui.dropActions">
>> <action
>> class=" org.eclipse.ui.internal.navigator.dnd.NavigatorPluginDropAct ion "
>> id="org.eclipse.ui.navigator.PluginDropAction">
>> </action>
>> </extension> </plugin>
Re: Common Navigator Framework [message #5876 is a reply to message #5309] |
Mon, 09 June 2008 19:19 |
Originally posted by: x_raajes.ugs.com
> The real issue is that because the schema isn't accessible there is no
> validation of sub-elements, right clicking on
> org.eclipse.ui.navigator.viewer presents the developer with the option to
> add a new Generic or new Extension and nothing else.
To fix this, you could do this (if you are using Eclipse 3.3):
- Copy the following folder from the Eclipse installation's "plugin" folder,
into your RCP application's "plugin" folder:
org.eclipse.platform.source_3.3.0.v20070612-_19UEkLEzwsdF9jS qQ-G
This folder contains the source and the schema definitions. You may have to
restart Eclipse, and then you will be able to right-click and see the
correct options when you add extensions.
Re: Common Navigator Framework [message #567915 is a reply to message #5309] |
Tue, 03 June 2008 15:50 |
I'm not a PDE guy, but can you check the .jar (in the plugins directory
of your installation) that contains the navigator,
org.eclipse.ui.navigator...jar. Make sure it has a schemas folder with
3 .exsd files.
Hopefully one of the PDE people can help answer this.
Joe Hutson wrote:
> In the manifest editor extensions tab right click on the extension and
> select Show Description or Open Schema which works for other extensions
> e.g. org.eclipse.ui.views
> to add a new Generic or new Extension and nothing else.
Re: Common Navigator Framework [message #567959 is a reply to message #5654] |
Tue, 03 June 2008 16:11 |
That's bad news, don't know how it got that way, but you should
reinstall and hopefully that will fix your problem.
Joe Hutson wrote:
> The schema folder is not there. The schema attribute in the plugin.xml
> Jar Version: org.eclipse.ui.navigator_3.3.2.M20080207-0800
> <plugin>
> <extension
> <action
> </action>
Re: Common Navigator Framework [message #567983 is a reply to message #5654] |
Tue, 03 June 2008 16:16 |
Francis
> <plugin>
> <extension
> <action
> </action>
Re: Common Navigator Framework [message #568468 is a reply to message #5309] |
FUDForum. Page generated in 0.04946 seconds
