Re: running serverside OSGI in mutlipe web container [message #58639 is a reply to message #58589] |
Fri, 27 January 2006 01:49 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: skaegi.sympatico.ca
Hi Jim,
Yep, sounds like the problem in bug 121472 (and also 105851 if you're not
running off of HEAD)
I'm working on it right now.
....maybe an early patch this weekend we'll see.
-Simon
"Jim D'Anjou" <danjou@us.ibm.com> wrote in message
news:6be2b2910a351da8d3d4a08acfded63e$1@www.eclipse.org...
> I tried installing two serverside bridge.war files each with their own
> path and context to see if more than one web container could run
> serverside OSGI (on the assumptions that two different applications wanted
> to use this on the same server).
> The first war to be deployed (under Tomcat) OK. The second had some
> exceptions thrown. I think I ended up with OSGI running in each container
> but one was crippled. It was hard to tell because you only have access to
> a single console. My URL's for each container could run the sp_* contro
> URL's. The sample extension servlet ran OK in the WAR that deployed
> successfully but got a 404 in the other.
> Is this a result of the issues described in bug 121472? Is so, is there an
> outlook for availability of a fix?
> Thanks...Jim
FUDForum. Page generated in 0.02956 seconds
