Problem Installing VE plugin [message #58586] |
Thu, 02 September 2004 10:24 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mauro.morici.welcometechnology.it
Hi everybody.
I am having troubles installing the VE plugin. I am using Eclipse 3.0
(Build id: 200402122000 on a Win2K system) and I downloaded EMF 3.0, GMF
2.0 and VE 1.0M2.
After unzipping them to the plugin directory and launching eclipse the
Visual Class is not available in the new menu.
I know it's a newbie question but I couldn't find any topic about it in
help or the web.
TIA
Mauro
Re: Problem Installing VE plugin [message #58660 is a reply to message #58586] |
Fri, 03 September 2004 18:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: richkulp.NO.SPAM.us.ibm.com
IS Buildid 2004021222000 a typo? That build is so old it is not
supported anymore. To use 1.0M2 you should be using Eclipse 3.0 Release
version, GEF 3.0.0 released version, and EMF 2.0.0 released version.
Mauro wrote:
> Hi everybody.
> 2.0 and VE 1.0M2.
> help or the web.
> TIA
> Mauro
Thanks, Rich Kulp
Re: Problem Installing VE plugin [message #58684 is a reply to message #58660] |
Sat, 04 September 2004 14:40 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
No it should be a release version. By the way I don't know what is a typo.
Mauro
Re: Problem Installing VE plugin [message #58709 is a reply to message #58684] |
Sat, 04 September 2004 17:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> Mauro
a typo is a typing error. your build id 2004021222000 should be a year,
2004, followed by a month, 02 or February, followed by a day of the
month, 12, followed by the time in hhmm format, hours = 22 and minutes =
00, but you have another 0. which digit is the extra digit?
if you expect support, download and install the following:
Eclipse build eclipse-SDK-3.0
EMF Release Build 2.0.0 sometimes called build R200406280827
GEF Build 3.0
VE Stable Build: 1.0M2
norwood sisson
Re: Problem Installing VE plugin [message #58783 is a reply to message #58758] |
Mon, 06 September 2004 04:33 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Creatxr wrote:
> I've met the same problem.
> Is here anyone that has settled the problem?
after unzipping new plugins, start eclipse with the clean flag to make
it search for new plugins.
eclipse -clean
norwood sisson
Re: Problem Installing VE plugin [message #58858 is a reply to message #58783] |
Wed, 08 September 2004 09:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
> eclipse -clean
Hi, I had same Mauro's problems with same software
(win2k, Eclipse build 200406251208, EMF build R200406280827 and GEF 3.0,
VE1.0M2), resolved with the "-clean" flag.
Thanks.
Gianluca
Re: Problem Installing VE plugin [message #59601 is a reply to message #58858] |
Sat, 11 September 2004 11:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jeff.arnold.tesco.net
As a newbie and have just download the current versions of eclipse, VE and
the depenancies on the download page I too cannot get the visual class to
show itself.
I have even tried the
eclipse -clean option suggested.
Are there any other ideas on what to do as the docs seem to be sparse when
it comes to installing plugins etc.
The reported versions are
Eclipse Platform
Version: 3.0.0
Build id: 200406251208
Which was downloaded on 11th Sept 04.
Jeff.
> > eclipse -clean
> Thanks.
> Gianluca
Re: Problem Installing VE plugin [message #59721 is a reply to message #58783] |
Mon, 13 September 2004 13:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: huehne.dost-telecom.de
Hi, I got the same problem, with the same builds - also the -clean flag
doesŽnt help.
Alf Huehne
> eclipse -clean
> norwood sisson
Re: Problem Installing VE plugin [message #63853 is a reply to message #59721] |
Sat, 02 October 2004 12:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: frisey.interfree.it
Hi, I got the same problem with these builds:
emf-sdo-runtime-2.0.1 (R200409171617)
GEF-runtime-3.0.1 (200408311615)
eclipse-SDK-3.0.1-win32 (200409161125)
VE-runtime-1.0 (200409191449)
As described in the F.A.Q, I've unzipped into the eclipse directory the
downloaded files.
Then I start Eclipse using the -clean option, but I can't find any new
feature in the environment.
Can someone help me?
Thanks!
Nicola Basilico
"Alf Huehne" <huehne@dost-telecom.de> ha scritto nel messaggio
news:ci463t$t80$1@eclipse.org...
> does
Re: Problem Installing VE plugin [message #64162 is a reply to message #63853] |
Mon, 04 October 2004 15:06 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Originally posted by: richkulp.us.NO_SPAM.ibm.com
You don't unzip INTO the eclipse directory, you unzip into the directory
eclipse is in. I.e.
d:\xyz\eclipse
means you unzip into d:/xyz not into d:/xyz/eclipse
You can tell if you did it right because if it was done wrong you would
have an d:\xyz\eclipse\eclipse\plugins directory. Which is wrong.
Rich Kulp
Re: Problem Installing VE plugin [message #598138 is a reply to message #58586] |
Fri, 03 September 2004 18:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Mauro wrote:
> Hi everybody.
> 2.0 and VE 1.0M2.
> help or the web.
> TIA
> Mauro
Thanks, Rich Kulp
Re: Problem Installing VE plugin [message #598150 is a reply to message #58684] |
Sat, 04 September 2004 17:00 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
user![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=LeoBahia19%40hotmail.com) Messages: 296 Registered: July 2009 |
> Mauro
GEF Build 3.0
norwood sisson
Re: Problem Installing VE plugin [message #598177 is a reply to message #58783] |
Wed, 08 September 2004 09:52 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
> eclipse -clean
Thanks.
Gianluca
Re: Problem Installing VE plugin [message #598372 is a reply to message #58858] |
Sat, 11 September 2004 11:31 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
show itself.
Eclipse Platform
Version: 3.0.0
Jeff.
> > eclipse -clean
> Thanks.
> Gianluca
Re: Problem Installing VE plugin [message #598405 is a reply to message #58783] |
Mon, 13 September 2004 13:08 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
doesŽnt help.
Alf Huehne
> eclipse -clean
> norwood sisson
Re: Problem Installing VE plugin [message #600419 is a reply to message #59721] |
Sat, 02 October 2004 12:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
downloaded files.
Thanks!
Nicola Basilico
> does
Re: Problem Installing VE plugin [message #600571 is a reply to message #63853] |
eclipse is in. I.e.
d:\xyz\eclipse
Rich Kulp
FUDForum. Page generated in 0.05393 seconds
