Query pattern for generic web connector template [message #58569] |
Mon, 29 September 2008 19:03 |
Menon![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=menonbugzilla%40gmail.com) Messages: 48 Registered: July 2009 |
Member |
I was finally able to connect to my web server by specifying adding the
host name to the "No proxy For" list from the Global Network conection
prefenerences settings. Also I added DOMAIN\username, password for http
authentication.
So for the repository/Advanced configuration "QueryURL", when I try to
open the, it shows me the web page.
So now I view the source for the web page and I add a query pattern,
exactly as shown in the source,"<a
href="/.../bug/default.aspx?bug_id=3772">3772</a>"
, But when I click on preview, it says, "No matching results. Check query
regexp". Can you tell me what is wrong with the above pattern? I also
tried to use "<a href="/.../bug/default.aspx?bug_id=(.+?)">(.+?)</a>".
This also gives me the no reult. "..." in the above pattern is a valid
path.( exactly as it is in the source )
Thanks for your help in advance
Sunanda
FUDForum. Page generated in 0.03110 seconds
