Please help! [message #58501] |
Tue, 28 January 2003 01:15 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: jim.azeltine.indus.com
I am trying very hard to get a grip on GEF, but this is getting very
frustrating. I am unable to get some of the examples to work. The first is
the Shapes example. In the following:
import com.ibm.etools.gef.examples.shapes.model.Ellipse;
import com.ibm.etools.gef.examples.shapes.model.Rectangle;
import com.ibm.etools.gef.examples.shapes.model.RoundedRectangle;
import com.ibm.etools.gef.palette.*;
import com.ibm.etools.gef.requests.CreateRequest;
import com.ibm.etools.gef.tools.CreationTool;
I do not have the same packages in my Eclipse install of GEF. Instead of
com.ibm.etools.gef, I have org.eclipse.gef.
So once I change all the package names, I still have an error:
The method shown is undefined for type DefaultPaletteCategory:
category.setChildren(groups);
I think there is probably more. Is there any possibility of getting a
version of this that works without modification?
Re: Please help! [message #59046 is a reply to message #58501] |
Tue, 28 January 2003 22:42 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Please load the Logic example, the Hello example is not provided by the GEF
team.
"Jim Azeltine" <jim.azeltine@indus.com> wrote in message
news:b14lk3$vm8$1@rogue.oti.com...
Re: Please help! [message #59071 is a reply to message #59046] |
Tue, 28 January 2003 22:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
I was not referring to any Hello examples, they work fine. I was referring
to the Shapes example.
> team.
Re: Please help! [message #59275 is a reply to message #58501] |
Wed, 29 January 2003 11:51 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: marazik.holosofx.com
In ShapePlugin class
in createComponentsCategory() method
change both
to be
category.addAll(groups);
group.setChildren(entries);
to be
group.addAll(entries);
The reason for this is
category is an instance of DefaultPaletteCategory &
group is an instance of DefaultPaletteGroup
both of these classes inherit from DefaultPaletteContainer where addAll
seems to replace the setChildren
Also u will need to make another change at ShapeEditPolicy
DeleteRequest seems to be deprected also.
So u will need to change the parameter passed to the createDeleteCommand
method
to be GroupRequest (and of course import
org.eclipse.gef.requests.GroupRequest)
Notice that this parameter is never used inside the method.
I wish the previous will help u.
Re: Please help! [message #59929 is a reply to message #59275] |
Wed, 29 January 2003 21:39 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
You are exactly right. I had started to do what you said, but decided I
didn't have the time to mess with it. I contacted Eric Bordeau, and he
pointed me to an old version of gef and draw2d that would work, so I
installed this in an isolated version of eclipse, and got it working.
Jim
AbdElRazik wrote:
> change both
> to be
> to be
> method
FUDForum. Page generated in 0.02922 seconds
