| Singletons in RAP [message #58430] |
Wed, 07 November 2007 13:03  |
Originally posted by: andy.freenet.de
I have an Application which uses a Singleton "ServiceLocator".
This class extends "SessionSingletonBase", I read this is the
right way to handle Singletons in a RAP Environment.
Well, it seems that is isnŽt.
When I try to access the Singleton-Instance I get the Exception
java.lang.IllegalStateException: No context available outside of the
request service lifecycle.
Ok, I think the error is, that no session-context is available at the time
when I call it.
But how is this problem to be solved?
Best regards!
Andy
| Re: Singletons in RAP [message #58706 is a reply to message #58562] |
Thu, 08 November 2007 09:35  |
Originally posted by: fappel.innoopract.com
Hi Andy,
just a little excerpt of a discussion regarding the usage of session
singletons and background threads that may brings a little more light at
this:
[...]To describe it in modelling terms, the relationship from background
thread to UI (session) in RCP is an 1 to 1 relationship as in RAP it is an 1
to n. Handling this difference can not be done under the hood of RAP, since
the backround job cannot access implicitly the one and only UI-session as in
RCP (e.g. by calling Display#getDefault()). [...]
Ciao
Frank
"Andy" <andy@freenet.de> schrieb im Newsbeitrag
news:cb110d78474d19f18bd6c20ab96a114a$1@www.eclipse.org...
> Hi Andy,
> you were right, this was exactly the reason.
> Access to a SessionSingletonBase inside of a Job (or any Background-Thread
> running on the Server I suppose) gives a IllegalStateException.
> But what exactly is the reason for this?
> I dont get the Point at the moment, perhaps you could describe shortly or
> point me to the right direction?
> Thank you
> Andy
FUDForum. Page generated in 0.03367 seconds
