Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » Teneo : persistence of objects URI
Teneo : persistence of objects URI [message #58396] |
Fri, 20 October 2006 09:38 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mat.loo.gmail.com
Are we ensured that the URI of an object will remain the same during all
its life cycle ?
I mean, when I create a Marker on an EMF Object (that I identify with its
URI, as EMF does in general), am I sure this URI will remain the same the
next time I launch Eclipse ? When Teneo/Jpox builds EObjects while reading
database, will all URIs be unique for each object and the same as the last
time Teneo/Jpox read the database ?
Thx
Re: Teneo : persistence of objects URI [message #58435 is a reply to message #58396] |
Fri, 20 October 2006 10:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Mat,
URIs are how EMF references other objects in general so this is a more
general question. The URI consists of the <base>#<fragment> where the
base identifies the resource containing the object and the fragment
identifies the object within that resource. If you actually moved the
object to a new resource, then clearly the base could change. The
fragment might well be a fragment path, so if the object moved within
the tree structure of the resource, then that path could change. If the
fragment is just an ID/UUID, then it won't change no matter how the
object is moved around within its resource. The URI should generally
not change arbitrarily unless you move or change the object. I assume
this is the case for how Teneo uses URIs as well...
Mat Lo wrote:
> Hi
> all its life cycle ? I mean, when I create a Marker on an EMF Object
> (that I identify with its URI, as EMF does in general), am I sure this
> URI will remain the same the next time I launch Eclipse ? When
> Teneo/Jpox builds EObjects while reading database, will all URIs be
> unique for each object and the same as the last time Teneo/Jpox read
> the database ?
> Thx
Re: Teneo : persistence of objects URI [message #58449 is a reply to message #58435] |
Fri, 20 October 2006 10:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Martin Taal![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mtaal%40springsite.com) Messages: 5468 Registered: July 2009 |
Mat,
The relational database does not have a notion of resources. The way you read the objects in the
resource determines there ordering and therefore the uri, if the uri is based on position.
So it is a safer approach to use the concept of an EMF id. You can try to map the emf id notion to
the same efeature as the database id. However, afaik (please correct me Ed if I am wrong) an EMF id
is always a string while the database id can be something else (auto-increment long or something).
This can be workarounded pretty easily by having a separate EMF id and database id efeature and
keeping the EMF id in sync with the database id.
gr. Martin
Ed Merks wrote:
> Mat,
> Mat Lo wrote:
>> Hi
>> the database ?
>> Thx
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: Teneo : persistence of objects URI [message #58460 is a reply to message #58449] |
Fri, 20 October 2006 11:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
--------------000800040507010000000902
Martin,
EMF doesn't force the ID to be a string. As you can see in these
EcoreUtil methods, it will convert to and from a string representation
as necessary.
* Returns the value of the object's ID attribute as a String.
* If the object has no ID attribute or the ID attribute is not
set, it returns <code>null</code>.
* @param eObject the object in question.
* @return the value of the object's ID attribute as a String.
* @see org.eclipse.emf.ecore.EAttribute#isID
* @see org.eclipse.emf.ecore.EClass#getEIDAttribute
* @see #setID(EObject, String)
public static String getID(EObject eObject)
EClass eClass = eObject.eClass();
EAttribute eIDAttribute = eClass.getEIDAttribute();
return eIDAttribute == null || !eObject.eIsSet(eIDAttribute) ?
null : convertToString(
eIDAttribute.getEAttributeType(),
eObject.eGet(eIDAttribute));
* Sets the value of the object's ID attribute according to the
value represented by the String.
* A <code>null</code> ID will unset the attribute rather than
setting it to <code>null</code>.
* @param id the String value of the new ID.
* @throws IllegalArgumentException if the object has no ID attribute.
* @see #getID(EObject)
public static void setID(EObject eObject, String id)
if (eIDAttribute == null)
throw new IllegalArgumentException("The object doesn't have an
ID feature.");
else if (id == null)
eObject.eUnset(eIDAttribute);
else
eObject.eSet(eIDAttribute,
createFromString(eIDAttribute.getEAttributeType(), id));
Martin Taal wrote:
> Mat,
> you read the objects in the resource determines there ordering and
> to map the emf id notion to the same efeature as the database id.
> However, afaik (please correct me Ed if I am wrong) an EMF id is
> (auto-increment long or something). This can be workarounded pretty
> gr. Martin
> Ed Merks wrote:
>> Mat,
>> more general question. The URI consists of the <base>#<fragment>
>> where the base identifies the resource containing the object and the
>> fragment identifies the object within that resource. If you actually
>> moved the object to a new resource, then clearly the base could
>> change. The fragment might well be a fragment path, so if the object
>> moved within the tree structure of the resource, then that path could
>> change. If the fragment is just an ID/UUID, then it won't change no
>> matter how the object is moved around within its resource. The URI
>> should generally not change arbitrarily unless you move or change the
>> object. I assume this is the case for how Teneo uses URIs as well...
>> Mat Lo wrote:
>>> Hi
>>> this URI will remain the same the next time I launch Eclipse ? When
>>> the database ?
>>> Thx
<html>
<head>
http-equiv="Content-Type">
</head>
Martin,<br>
<br>
Re: Teneo : persistence of objects URI [message #59888 is a reply to message #58460] |
Thu, 02 November 2006 17:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Thanks for your answers.
I want to use Id automatically generated by Teneo (I don't want to add an
attribute to my eObjects and set it to "id").
Is there a way to access the id managed by Teneo (I saw it generates them
when no id is set in ECore model)
Thx again.
Re: Teneo : persistence of objects URI [message #59936 is a reply to message #59888] |
Thu, 02 November 2006 17:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Mat,
I assume that eObject.eResource().getURIFragment(eObject) will return
the ID managed by the resource that contains the eObject.
> an attribute to my eObjects and set it to "id").
> them when no id is set in ECore model)
> Thx again.
Re: Teneo : persistence of objects URI [message #594447 is a reply to message #58396] |
Fri, 20 October 2006 10:23 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33184 Registered: July 2009 |
Mat,
Mat Lo wrote:
> Hi
> the database ?
> Thx
Ed Merks
Re: Teneo : persistence of objects URI [message #594456 is a reply to message #58435] |
Fri, 20 October 2006 10:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Mat,
gr. Martin
Ed Merks wrote:
> Mat,
> Mat Lo wrote:
>> Hi
>> the database ?
>> Thx
The Netherlands
Re: Teneo : persistence of objects URI [message #594467 is a reply to message #58449] |
Fri, 20 October 2006 11:07 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Martin,
as necessary.
ID feature.");
else
Martin Taal wrote:
> Mat,
> gr. Martin
> Ed Merks wrote:
>> Mat,
>> Mat Lo wrote:
>>> Hi
>>> the database ?
>>> Thx
<html>
<head>
</head>
Martin,<br>
<br>
Ed Merks
Re: Teneo : persistence of objects URI [message #595087 is a reply to message #58460] |
Thu, 02 November 2006 17:02 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Thx again.
Re: Teneo : persistence of objects URI [message #595103 is a reply to message #59888] |
Thu, 02 November 2006 17:09 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Mat,
> Thx again.
Ed Merks
Current Time: Fri Jul 19 05:23:24 GMT 2024
Powered by FUDForum. Page generated in 0.04753 seconds
