AspectJ/Java Editor does not work [message #58362] |
Sat, 12 November 2005 15:08 |
Originally posted by: mg.schwarz.de
i've just installed the latest version of AJDT...
when i try to open a *.aj-file with the aspectj-editor, i only get a gray
empty window...
the ADJT-event-trace window shows nothing unusual...
Thanks in Advance
Markus
Eclipse-Version:
Version: 3.1.0
Build id: I20050923-1000
AspectJ-Version:
Version: 1.3.0
Build id: 20051111104438
AspectJ version: 1.5.0.20051107153637
Re: AspectJ/Java Editor does not work [message #58536 is a reply to message #58362] |
Sun, 13 November 2005 00:23 |
Matt Chapman Messages: 429 Registered: July 2009 |
Hi Markus,
I don't recognise that build of eclipse - we use 3.1.1, which has an ID
of M20050929-0840. Also, if you do Window > Show View > Error Log, are
there any errors shown there?
Matt.
On Sat, 12 Nov 2005 15:08:48 +0000, Markus Grill wrote:
> empty window...
> Thanks in Advance
> Markus
> Eclipse-Version:
> Version: 3.1.0
> AspectJ-Version:
> Version: 1.3.0
Re: AspectJ/Java Editor does not work [message #60186 is a reply to message #58536] |
Fri, 06 January 2006 02:03 |
Originally posted by: e-bz.163.com
I got the same problem when I tried to open a *.aj file with AspectJ/Java
Editor, here's the error log:
class
org.eclipse.ajdt.internal.ui.editor.contentassist.AJCompleti onProcessor
overrides final method .
Re: AspectJ/Java Editor does not work [message #60910 is a reply to message #60305] |
Fri, 13 January 2006 05:32 |
>> class
> I believe this error is caused by a mismatch between AJDT and Eclipse
> versions. Please make sure you are using a supported configuration, such
> as Eclipse 3.1.1 and AJDT 1.3. See the AJDT download page for more
> information: http://www.eclipse.org/ajdt/downloads/
> Matt.
Thanks for your reply, I have upgraded my Eclipse to 3.2, but still using
AJDT 1.3. -_-!
I've downloaded AJDT 1.4.0, everything is Ok, thanks again!
Re: AspectJ/Java Editor does not work [message #590885 is a reply to message #58362] |
Hi Markus,
Matt.
> empty window...
> Thanks in Advance
> Markus
> Eclipse-Version:
> Version: 3.1.0
> AspectJ-Version:
> Version: 1.3.0
Re: AspectJ/Java Editor does not work [message #591614 is a reply to message #58536] |
class
Re: AspectJ/Java Editor does not work [message #591813 is a reply to message #60305] |
>> class
> Matt.
AJDT 1.3. -_-!
FUDForum. Page generated in 0.04142 seconds
