Home » Modeling » OCL » how to detect cycle in OCL
how to detect cycle in OCL [message #58162] |
Wed, 11 June 2008 03:32 |
Originally posted by: asma.charfi.com
I want to code in OCL a constraint that detect a cycle in a component.
a cycle is a path that contains the same parts twice or more.
I use component and part part
connection between part is done used port
port have direction IN or Out
a part 1 is connected with part 2 , means that there is a connecotor linking
one Out port of part 1 with an IN Port of part 2
I tried to divide my constraint as follows.
- recover ports of direction IN in the main component :
Contexte component
self.ownedPort->select(let p : GCM::FlowPort =
getStereotypeApplication(getAppliedStereotype('GCM::FlowPort ')).oclAsType
(GCM::FlowPort) in p.direction <> GCM::DirectionKind::out)
- recover part directly linked to this component (there is a connector that
connects the port INof the component with a port IN of the part) :
Contexte Port (direction IN)
self.end-> select(e|e.owner.owner=self.owner).owner.oclAsType(Connector ).end- >
select(p|not (p.oclAsType(ConnectorEnd).partWithPort.oclIsUndefined())).
partWithPort.type
I want now to get all parts in connection with my part (to check if the list
of parts contains double)
did so have an idea about how to get list of parts that are connected ?
thank you
Re: how to detect cycle in OCL [message #58187 is a reply to message #58162] |
Wed, 11 June 2008 02:16 |
Originally posted by: cdamus.zeligsoft.com
--=-Aw8Knelv38k0oqiggDu2
Content-Type: text/plain
Hi, Asma,
Which version of the MDT OCL component are you using? If 1.1or greater,
you should be able to use the UML metamodel binding's capability of
navigating non-navigable association ends to more concisely express
constraints involving stereotypes.
context Component
def: inPorts : Collection(Port) = self.ownedPort->select(p : Port |
p.extension_FlowPort <> null and
p.extension_FlowPort.direction <> GCM::DirectionKind::out) in
Regarding finding all parts connected to some part, you may find MDT
OCL's custom closure() iterator to be of use. For example, to find all
of the supertypes of a classifier (pretending that
Classifier::allParents() query doesn't exist):
context Classifier
def: allSupers() : Collection(Classifier) = general->closure(general)
or, the closure of all associated classifiers to which a classifier can
navigate via associations:
context Classifier
def: reachable() : Collection(Classifier) =
self->closure(ownedAttribute->select(association <> null).type)
Your component-model scenario is just too complex for my little
brain ;-)
HTH,
Christian
On Tue, 2008-06-10 at 20:32 -0700, charfi asma wrote:
> Contexte component
> partWithPort.type
> thank you
Content-Type: text/html; charset=utf-8
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 TRANSITIONAL//EN">
<HTML>
<HEAD>
<META HTTP-EQUIV="Content-Type" CONTENT="text/html; CHARSET=UTF-8">
<META NAME="GENERATOR" CONTENT="GtkHTML/3.16.0">
</HEAD>
<BODY>
Hi, Asma,<BR>
<BR>
Which version of the MDT OCL component are you using? If 1.1or greater, you should be able to use the UML metamodel binding's capability of navigating non-navigable association ends to more concisely express constraints involving stereotypes.<BR>
<BR>
context Component<BR>
def: inPorts : Collection(Port) = self.ownedPort->select(p : Port |<BR>
p.extension_FlowPort <> null and<BR>
p.extension_FlowPort.direction <> GCM::DirectionKind::out) in<BR>
<BR>
Regarding finding all parts connected to some part, you may find MDT OCL's custom closure() iterator to be of use. For example, to find all of the supertypes of a classifier (pretending that Classifier::allParents() query doesn't exist):<BR>
<BR>
context Classifier<BR>
def: allSupers() : Collection(Classifier) = general->closure(general)<BR>
<BR>
or, the closure of all associated classifiers to which a classifier can navigate via associations:<BR>
<BR>
def: reachable() : Collection(Classifier) =<BR>
self->closure(ownedAttribute->select(associati on <> null).type)<BR>
<BR>
Your component-model scenario is just too complex for my little brain ;-)<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BLOCKQUOTE TYPE=CITE>
<PRE>
<FONT COLOR="#000000">Hi,</FONT>
<FONT COLOR="#000000">I want to code in OCL a constraint that detect a cycle in a component.</FONT>
<FONT COLOR="#000000">a cycle is a path that contains the same parts twice or more.</FONT>
<FONT COLOR="#000000">I use component and part part</FONT>
<FONT COLOR="#000000">connection between part is done used port</FONT>
<FONT COLOR="#000000">port have direction IN or Out</FONT>
<FONT COLOR="#000000">a part 1 is connected with part 2 , means that there is a connecotor linking </FONT>
<FONT COLOR="#000000">one Out port of part 1 with an IN Port of part 2</FONT>
<FONT COLOR="#000000">I tried to divide my constraint as follows.</FONT>
<FONT COLOR="#000000">- recover ports of direction IN in the main component :</FONT>
<FONT COLOR="#000000">Contexte component</FONT>
<FONT COLOR="#000000">self.ownedPort->select(let p : GCM::FlowPort = </FONT>
<FONT COLOR="#000000"> getStereotypeApplication(getAppliedStereotype('GCM::FlowPort ')).oclAsType </FONT>
<FONT COLOR="#000000">(GCM::FlowPort) in p.direction <> GCM::DirectionKind::out)</FONT>
<FONT COLOR="#000000">- recover part directly linked to this component (there is a connector that </FONT>
<FONT COLOR="#000000">connects the port INof the component with a port IN of the part) :</FONT>
<FONT COLOR="#000000">Contexte Port (direction IN)</FONT>
<FONT COLOR="#000000"> self.end->select(e|e.owner.owner=self.owner).owner.oc lAsType(Connector).end-> </FONT>
<FONT COLOR="#000000">select(p|not (p.oclAsType(ConnectorEnd).partWithPort.oclIsUndefined())). </FONT>
<FONT COLOR="#000000">partWithPort.type</FONT>
<FONT COLOR="#000000">I want now to get all parts in connection with my part (to check if the list </FONT>
<FONT COLOR="#000000">of parts contains double)</FONT>
<FONT COLOR="#000000">did so have an idea about how to get list of parts that are connected ?</FONT>
<FONT COLOR="#000000">thank you </FONT>
</PRE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-Aw8Knelv38k0oqiggDu2--
Re: how to detect cycle in OCL [message #58212 is a reply to message #58187] |
Wed, 11 June 2008 19:42 |
------=_NextPart_000_000D_01C8CBC0.A558D1C0
Content-Type: text/plain;
charset="utf-8"
thank you christian.
custom closure() iterator seems to be usefull, but I did not understand =
its meannig
can you explain more your example (using closure instead of allparents() =
to get all classifer) ?
your constraint is too difficult to understand :)
( def: allSupers() : Collection(Classifier) =3D =
general->closure(general))
I tried to use closure to get parts that are connected with one (any()) =
but it always return all the parts=20
closure(exp: OclExpression) what should we put as oclExpression ?
I understand that when we write self->closure() the type of exp must be =
the same as self
thank you for your help=20
Asma
"Christian W. Damus" <cdamus@zeligsoft.com> a =C3=A9crit dans le =
message de news: 1213150614.7176.21.camel@cwdlappy...
Hi, Asma,
Which version of the MDT OCL component are you using? If 1.1or =
greater, you should be able to use the UML metamodel binding's =
capability of navigating non-navigable association ends to more =
context Component
def: inPorts : Collection(Port) =3D self.ownedPort->select(p : Port |
Regarding finding all parts connected to some part, you may find MDT =
OCL's custom closure() iterator to be of use. For example, to find all =
of the supertypes of a classifier (pretending that =
context Classifier
or, the closure of all associated classifiers to which a classifier =
context Classifier
def: reachable() : Collection(Classifier) =3D
Your component-model scenario is just too complex for my little brain =
HTH,
Christian
On Tue, 2008-06-10 at 20:32 -0700, charfi asma wrote:=20
a part 1 is connected with part 2 , means that there is a connecotor =
linking=20
Contexte component
self.ownedPort->select(let p : GCM::FlowPort =3D=20
getStereotypeApplication(getAppliedStereotype('GCM::FlowPort ')).oclAsType=
=20
- recover part directly linked to this component (there is a connector =
that=20
self.end-> select(e|e.owner.owner=3Dself.owner).owner.oclAsType(Connect or)=
..end->=20
select(p|not (p.oclAsType(ConnectorEnd).partWithPort.oclIsUndefined())). =
partWithPort.type
I want now to get all parts in connection with my part (to check if the =
list=20
thank you=20
charset="utf-8"
=EF=BB=BF<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<HTML><HEAD>
<META http-equiv=3DContent-Type content=3D"text/html; CHARSET=3DUTF-8">
<META content=3D"MSHTML 6.00.6000.20772" name=3DGENERATOR>
<STYLE></STYLE>
</HEAD>
<BODY bgColor=3D#ffffff>
<DIV><FONT face=3DArial size=3D2>thank you christian.</FONT></DIV>
<DIV>custom closure() iterator seems to be usefull, but I did not =
understand its=20
meannig</DIV>
<DIV><FONT face=3DArial size=3D2>can you explain more your example =
(using closure=20
instead of allparents() to get all classifer) ?</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>your constraint is too difficult to =
understand=20
:)</FONT></DIV>
<DIV><FONT face=3DArial size=3D2>( <FONT face=3D"Times New Roman" =
size=3D3>def:=20
allSupers() : Collection(Classifier) =3D=20
general->closure(general))</FONT></FONT></DIV>
<DIV><FONT face=3DArial size=3D2><FONT face=3D"Times New Roman" =
size=3D3>I tried to use=20
closure to get parts that are connected with one (any()) but it always =
return=20
all the parts </FONT></FONT></DIV>
size=3D3><FONT=20
size=3D1>closure(exp: OclExpression) what should we put as oclExpression =
?</FONT></FONT></FONT></DIV>
size=3D3><FONT size=3D1>I=20
the=20
same as self</FONT></FONT></FONT></DIV>
size=3D3><FONT=20
size=3D1></FONT></FONT></FONT> </DIV>
size=3D3><FONT=20
size=3D1><FONT face=3DArial size=3D2>thank you for your help=20
</FONT></FONT></FONT></FONT></DIV>
size=3D3><FONT=20
size=3D1><FONT face=3DArial =
size=3D2></FONT></FONT></FONT></FONT> </DIV>
size=3D3><FONT=20
size=3D2>Asma</FONT></DIV></FONT></FONT></FONT>
<DIV> </DIV>
size=3D3></FONT><FONT=20
face=3D"Times New Roman" size=3D3></FONT><BR> </DIV></FONT>
<DIV><FONT face=3DArial size=3D2></FONT> </DIV>
<BLOCKQUOTE dir=3Dltr=20
<DIV>"Christian W. Damus" <<A=20
href=3D"mailto:cdamus@zeligsoft.com">cdamus@zeligsoft.com</A>> a =
=C3=A9crit dans=20
le message de news: <A=20
href=3D"mailto:1213150614.7176.21.camel@cwdlappy">1213150614.7176.21.came=
l@cwdlappy</A>...</DIV>Hi,=20
Asma,<BR><BR>Which version of the MDT OCL component are you =
using? If=20
1.1or greater, you should be able to use the UML metamodel binding's=20
concisely=20
express constraints involving stereotypes.<BR><BR>context=20
Component<BR>def: inPorts : Collection(Port) =3D=20
self.ownedPort->select(p : Port=20
|<BR> p.extension_FlowPort =
<>=20
null and<BR> =20
p.extension_FlowPort.direction <> GCM::DirectionKind::out)=20
in<BR><BR>Regarding finding all parts connected to some part, you may =
find MDT=20
of the=20
supertypes of a classifier (pretending that Classifier::allParents() =
query=20
doesn't exist):<BR><BR>context Classifier<BR>def: allSupers() :=20
Collection(Classifier) =3D general->closure(general)<BR><BR>or, the =
closure=20
of all associated classifiers to which a classifier can navigate via=20
associations:<BR><BR>context Classifier<BR>def: reachable() :=20
Collection(Classifier) =3D<BR> =20
self->closure(ownedAttribute->select(associati on <>=20
null).type)<BR><BR>Your component-model scenario is just too complex =
for my=20
little brain ;-)<BR><BR>HTH,<BR><BR>Christian<BR><BR>On Tue, =
2008-06-10 at=20
<BLOCKQUOTE TYPE=3D"CITE"><PRE><FONT color=3D#000000>Hi,</FONT>
<FONT color=3D#000000>I want to code in OCL a constraint that detect a =
<FONT color=3D#000000>a cycle is a path that contains the same parts =
<FONT color=3D#000000>I use component and part part</FONT>
<FONT color=3D#000000>connection between part is done used port</FONT>
<FONT color=3D#000000>port have direction IN or Out</FONT>
<FONT color=3D#000000>a part 1 is connected with part 2 , means that =
<FONT color=3D#000000>one Out port of part 1 with an IN Port of part =
2</FONT>
<FONT color=3D#000000>I tried to divide my constraint as follows.</FONT>
<FONT color=3D#000000>- recover ports of direction IN in the main =
component :</FONT>
<FONT color=3D#000000>Contexte component</FONT>
<FONT color=3D#000000>self.ownedPort->select(let p : GCM::FlowPort =
=3D </FONT>
<FONT =
color=3D#000000>getStereotypeApplication(getAppliedStereotype('GCM::FlowP=
ort')).oclAsType </FONT>
<FONT color=3D#000000>(GCM::FlowPort) in p.direction <> =
<FONT color=3D#000000>- recover part directly linked to this component =
<FONT color=3D#000000>connects the port INof the component with a port =
<FONT color=3D#000000>Contexte Port (direction IN)</FONT>
<FONT =
color=3D#000000> self.end->select(e|e.owner.owner=3Dself.owner).owner. o=
clAsType(Connector).end-> </FONT>
<FONT color=3D#000000>select(p|not =
<FONT color=3D#000000>partWithPort.type</FONT>
<FONT color=3D#000000>I want now to get all parts in connection with my =
<FONT color=3D#000000>of parts contains double)</FONT>
<FONT color=3D#000000>did so have an idea about how to get list of parts =
<FONT color=3D#000000>thank you </FONT>
</PRE></BLOCKQUOTE></BLOCKQUOTE></BODY></HTML>
------=_NextPart_000_000D_01C8CBC0.A558D1C0--
Re: how to detect cycle in OCL [message #58288 is a reply to message #58212] |
Wed, 11 June 2008 13:25 |
--=-y5BM7FaYjASHPYv+MmJO
Content-Type: text/plain; charset=UTF-8
Hi, Asma,
Yes, the closure body expression type must conform to the source
collection type. This is because the body expression is recursively
evaluated on its own results until no more results are obtained, taking
care to account for cycles.
Thus, my example expression finds the closure of classifiers that are
connected by the "general" property, navigating in the direction from
specific to general classifier. It really is intended to be a
directed-graph closure.
HTH,
Christian
On Wed, 2008-06-11 at 12:42 -0700, charfi asma wrote:
> =EF=BB=BF=20
>=20
> understand its meannig
> (any()) but it always return all the parts=20
> be the same as self
> =20
> =20
> Asma
> =20
>=20
> =20
> =20
> =20
> Hi, Asma,
> =20
> stereotypes.
> =20
> context Component
> Port |
> =20
> exist):
> =20
> context Classifier
> =20
> =20
> context Classifier
> null).type)
> =20
> little brain ;-)
> =20
> HTH,
> =20
> Christian
> =20
> =20
> > Hi,
> > I want to code in OCL a constraint that detect a cycle in a com=
ponent.
> > a part 1 is connected with part 2 , means that there is a conne=
cotor linking=20
> >=20
> >=20
> > Contexte component
> > getStereotypeApplication(getAppliedStereotype('GCM::FlowPort '))=
..oclAsType=20
> >=20
> >=20
> > - recover part directly linked to this component (there is a co=
nnector that=20
> > connects the port INof the component with a port IN of the part=
> >=20
> >=20
> >=20
> >=20
> > self.end->select(e|e.owner.owner=3Dself.owner).owner.oclAsType(=
Connector).end->=20
> > select(p|not (p.oclAsType(ConnectorEnd).partWithPort.oclIsUndef=
ined())).=20
> > partWithPort.type
> >=20
> >=20
> >=20
> >=20
> > I want now to get all parts in connection with my part (to chec=
k if the list=20
> >=20
> >=20
> > did so have an idea about how to get list of parts that are con=
nected ?
> >=20
> > thank you=20
> >=20
> >=20
<HTML>
<HEAD>
</HEAD>
<BODY BGCOLOR="#ffffff">
Hi, Asma,<BR>
<BR>
Yes, the closure body expression type must conform to the source collection type. This is because the body expression is recursively evaluated on its own results until no more results are obtained, taking care to account for cycles.<BR>
<BR>
Thus, my example expression finds the closure of classifiers that are connected by the "general" property, navigating in the direction from specific to general classifier. It really is intended to be a directed-graph closure.<BR>
<BR>
HTH,<BR>
<BR>
Christian<BR>
<BR>
<BR>
On Wed, 2008-06-11 at 12:42 -0700, charfi asma wrote:<BR>
<FONT COLOR="#000000"> </FONT>
</BLOCKQUOTE>
<FONT SIZE="2"><FONT COLOR="#000000">thank you christian.</FONT></FONT>
</BLOCKQUOTE>
<FONT COLOR="#000000">custom closure() iterator seems to be usefull, but I did not understand its meannig</FONT>
</BLOCKQUOTE>
<FONT SIZE="2"><FONT COLOR="#000000">can you explain more your example (using closure instead of allparents() to get all classifer) ?</FONT></FONT>
</BLOCKQUOTE>
<FONT SIZE="2"><FONT COLOR="#000000">your constraint is too difficult to understand :)</FONT></FONT>
</BLOCKQUOTE>
<FONT SIZE="2"><FONT COLOR="#000000">( </FONT></FONT><FONT COLOR="#000000">def: allSupers() : Collection(Classifier) = general->closure(general))</FONT>
</BLOCKQUOTE>
<FONT COLOR="#000000">I tried to use closure to get parts that are connected with one (any()) but it always return all the parts </FONT>
</BLOCKQUOTE>
<FONT SIZE="1"><FONT COLOR="#000000">closure(exp: OclExpression) what should we put as oclExpression ?</FONT></FONT>
</BLOCKQUOTE>
<FONT SIZE="1"><FONT COLOR="#000000">I understand that when we write self->closure() the type of exp must be the same as self</FONT></FONT>
</BLOCKQUOTE>
</BLOCKQUOTE>
<FONT SIZE="2"><FONT COLOR="#000000">thank you for your help </FONT></FONT>
</BLOCKQUOTE>
</BLOCKQUOTE>
<FONT SIZE="2"><FONT COLOR="#000000">Asma</FONT></FONT>
</BLOCKQUOTE>
</BLOCKQUOTE>
<BR>
<FONT SIZE="2"><FONT COLOR="#000000"> </FONT></FONT>
</BLOCKQUOTE>
</BLOCKQUOTE>
<BLOCKQUOTE>
<FONT COLOR="#000000">"Christian W. Damus" <<A HREF="mailto:cdamus@zeligsoft.com">cdamus@zeligsoft.com</A>> a écrit dans le message de news: <A HREF="mailto:1213150614.7176.21.camel@cwdlappy">1213150614.7176.21.camel@cwdlappy</A>...</FONT>
</BLOCKQUOTE>
</BLOCKQUOTE>
<BLOCKQUOTE>
<FONT COLOR="#000000">Hi, Asma,</FONT><BR>
<BR>
<FONT COLOR="#000000">Which version of the MDT OCL component are you using? If 1.1or greater, you should be able to use the UML metamodel binding's capability of navigating non-navigable association ends to more concisely express constraints involving stereotypes.</FONT><BR>
<BR>
<FONT COLOR="#000000">context Component</FONT><BR>
<FONT COLOR="#000000">def: inPorts : Collection(Port) = self.ownedPort->select(p : Port |</FONT><BR>
<FONT COLOR="#000000"> p.extension_FlowPort <> null and</FONT><BR>
<FONT COLOR="#000000"> p.extension_FlowPort.direction <> GCM::DirectionKind::out) in</FONT><BR>
<BR>
<FONT COLOR="#000000">Regarding finding all parts connected to some part, you may find MDT OCL's custom closure() iterator to be of use. For example, to find all of the supertypes of a classifier (pretending that Classifier::allParents() query doesn't exist):</FONT><BR>
<BR>
<FONT COLOR="#000000">context Classifier</FONT><BR>
<FONT COLOR="#000000">def: allSupers() : Collection(Classifier) = general->closure(general)</FONT><BR>
<BR>
<FONT COLOR="#000000">or, the closure of all associated classifiers to which a classifier can navigate via associations:</FONT><BR>
<BR>
<FONT COLOR="#000000">def: reachable() : Collection(Classifier) =</FONT><BR>
<FONT COLOR="#000000"> self->closure(ownedAttribute->select(associati on <> null).type)</FONT><BR>
<BR>
<FONT COLOR="#000000">Your component-model scenario is just too complex for my little brain ;-)</FONT><BR>
<BR>
<FONT COLOR="#000000">HTH,</FONT><BR>
<BR>
<FONT COLOR="#000000">Christian</FONT><BR>
<BR>
<FONT COLOR="#000000">On Tue, 2008-06-10 at 20:32 -0700, charfi asma wrote: </FONT>
<PRE>
</PRE>
</BLOCKQUOTE>
</BLOCKQUOTE>
</BLOCKQUOTE>
</BODY>
</HTML>
--=-y5BM7FaYjASHPYv+MmJO--
Current Time: Wed Sep 18 17:06:26 GMT 2024
Powered by FUDForum. Page generated in 0.03151 seconds
