Plugin directory configuration [message #58146] |
Sun, 01 June 2003 18:27 |
Originally posted by: roychous.cis.uab.edu
We want to add plugins to Eclipse IDE. But due to security restrictions we
dont have write permissions to the eclipse default plugins folder.
We need an alternative so that we can install the plugins in some temporary
folders like C:\temp\MyPlugins.This plugins should be automatically
identified while eclipse startup
just like any other plugins.So is there any way that we can configure the
location of the plugins directory?
-Suman
Re: Plugin directory configuration [message #62856 is a reply to message #61152] |
Wed, 04 June 2003 20:37 |
Well I also tried out the command line option -plugins or -configuration.
But this was not solving my purpose.
However I got the solution from one of the newsgroup members.Check the link
below.
http://eclipsewiki.swiki.net/131#four
-Suman
"David Saff" <saff@mit.edu> wrote in message
news:bbinev$3ec$1@rogue.oti.com...
we
temporary
the
> Would the -plugins or -configuration command-line options give you what
> you need? (See
http://127.0.0.1:3799/help/topic/org.eclipse.platform.doc.us er/tasks/running
_eclipse.htm
> when Eclipse is running)
> Share and Enjoy,
> David Saff
FUDForum. Page generated in 0.03889 seconds
