Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58177 is a reply to message #58122] |
Thu, 19 October 2006 12:41 |
Hi, Marcin,
It looks to me as though the code snippet below is using the wrong command
stack to execute this command. I cannot see how the 'commandStack'
variable is initialized, but I don't think it's coming from the
'editingDomain' that was initialized just a few lines previous to the
execution of the command.
Use editingDomain.getCommandStack().execute(command) and all should be well.
It is the transactional editing domain's stack that creates the
transactions for you.
HTH,
Christian
ciukes wrote:
> I'm moving my editing code from AdapterFactoryEditingDomain to
> TransactionalEditingDomain. All my changes to the model were done with
> editing domain and it's stack. After switching to TransEdDomain I got
> such execptions:
> java.lang.IllegalStateException: Cannot modify resource set without a
> write transaction
> at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ssertWriting(TransactionChangeRecorder.java:295)
> at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.a ppendNotification(TransactionChangeRecorder.java:257)
> at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.p rocessObjectNotification(TransactionChangeRecorder.java:239)
> at
org.eclipse.emf.transaction.impl.TransactionChangeRecorder.n otifyChanged(TransactionChangeRecorder.java:195)
> at
org.eclipse.uml2.uml.internal.impl.ElementImpl.eNotify(Eleme ntImpl.java:821)
> at
org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(E coreEList.java:234)
> at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:452)
> at
org.eclipse.emf.common.notify.impl.NotifyingListImpl.addAllU nique(NotifyingListImpl.java:396)
> at org.eclipse.emf.common.util.BasicEList.addAll(BasicEList.jav a:688)
> at org.eclipse.emf.edit.command.AddCommand.doExecute(AddCommand .java:400)
> at
org.eclipse.emf.edit.command.AbstractOverrideableCommand.exe cute(AbstractOverrideableCommand.java:128)
> at
org.eclipse.emf.workspace.EMFCommandOperation.doExecute(EMFC ommandOperation.java:116)
> at
org.eclipse.emf.workspace.AbstractEMFOperation.execute(Abstr actEMFOperation.java:130)
> at
org.eclipse.core.commands.operations.DefaultOperationHistory .execute(DefaultOperationHistory.java:509)
> at
org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.exe cute(WorkspaceCommandStackImpl.java:147)
> at
org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl.exe cute(WorkspaceCommandStackImpl.java:183)
> This is piece of code that makes me mad:
> PrimitiveType type = UML2ModelUtil.UML_FACTORY.createPrimitiveType();
> type.setName(propertyType);
> type.setVisibility(VisibilityKind.PRIVATE_LITERAL);
> Property newProperty = UML2ModelUtil.UML_FACTORY.createProperty();
> newProperty.setVisibility(VisibilityKind.PRIVATE_LITERAL);
> newProperty.setName(propertyName);
> newProperty.setType(type);
> EStructuralFeature eStructuralFeature=
> UMLPackage.eINSTANCE.getStructuredClassifier_OwnedAttribute( );
> Collection commandCollection=new ArrayList();
> commandCollection.add(newProperty);
> CommandParameter commandParameter = new
> CommandParameter(umlClass,eStructuralFeature,commandCollecti on);
> TransactionalEditingDomain editingDomain =
TransactionalEditingDomain.Registry.INSTANCE.getEditingDomai n(EDITING_DOMAIN_ID);
> Command command =
> editingDomain.createCommand(AddCommand.class,commandParamete r);
> try {
> commandStack.execute(command);
> } catch (Exception exception) {
> // Here I catch java.lang.IllegalStateException
> What am I missing? Something specific to TransactionalEditingDomain like
> "start transaction" method?
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58328 is a reply to message #58250] |
Thu, 19 October 2006 14:17 |
Hi, Marcin,
Perhaps, then, what is happening is that the umlClass object is in a
different resource set than the one associated with your editing domain?
It seems clear that the TransactionalEditingDomain in which the command
execution is starting a transaction is different from the one that is
throwing the IllegalStateException, because it has no active transaction.
With a breakpoint on the throwing of the IllegalStateException, can you
confirm whether the TransactionalEditingDomain associated with the change
recorder is the same as or different from the one associated with the
WorkspaceCommandStackImpl farther down the execution stack?
Christian
ciukes wrote:
> Christian W. Damus wrote:
>> Hi, Marcin,
>> command
>> well. It is the transactional editing domain's stack that creates the
> This is extacly how I get command stack.
> editingDomain is
org.eclipse.gmf.runtime.diagram.core.DiagramEditingDomainFac tory$DiagramEditingDomain
> which extends TransactionalEditingDomainImpl
> editingDomain.getCommandStack() is
> org.eclipse.emf.workspace.impl.WorkspaceCommandStackImpl which
> implements InternalTransactionalCommandStack
> and InternalTransactionalCommandStack extends TransactionalCommandStack
> I've found that EMF command is wrapped by
> WorkspaceCommandStackImpl.execute(Command)
> in EMFCommandOperation
> according to EMFCommandOperation's javadoc:
> * An operation that wraps an EMF {@link Command} to execute it in a
> read/write
> * transaction on an {@link IOperationHistory}. This class may be
> created * explicitly by a client of the operation history, or it may be
> used
> implicitly
> * by executing a command on the {@link TransactionalCommandStack}.
> * @author Christian W. Damus (cdamus)
> I'm almost sure I should use
> TransactionalCommandStack.execute(Command,Map) and pass transaction
> options.
> What do you think? Do I follow right path?
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58374 is a reply to message #58351] |
Thu, 19 October 2006 19:47 |
Hi, Marcin,
I'm glad it's working for you, now!
What you have observed is that a TransactionalEditingDomain, once a resource
or object enters into its sphere of influence, "owns" that resource or
object and will not share it with other editing domains. The EMFT
Transaction world-view of editing domains is that they are closed universes
and that they do not communicate, as is commonly accepted (though not
proven) in cosmology.
That said, there is supposed to be a way to dispose of a
TransactionalEditingDomain that would "free" the resources and objects
within it. There are limitations to this that are tracked by
https://bugs.eclipse.org/bugs/show_bug.cgi?id=161169.
Christian
ciukes wrote:
> Silly me:) Mystery is revealed.
> I used different Editing Domain instance when reading resource. At that
> moment Editing Domain is attached to the model and consumes
> notifications. When command was executed with different Editing Domain
> instance I got this problem. Different instance was executing command
> from that one consuming notification. Obviously they don't share
> transaction informations. So when it comes to TransactionChangeRecorder
> it has no knowledge about transaction used to execute command (see
> stacktrace). Simple change in one line fixed problem.
> Solution is: Make sure you are using same Editing Domain for everything
> not only for execution:)
> Thanks for all of you for supporting me!:)
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #58417 is a reply to message #58374] |
Fri, 20 October 2006 10:09 |
ciukes Messages: 19 Registered: July 2009 |
Junior Member |
> Hi, Marcin,
> Cheers,
> Christian
That helps me with my first steps in EMFT Trans world.
Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594342 is a reply to message #58122] |
Hi, Marcin,
HTH,
Christian
> such execptions:
> write transaction
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Command command =
> try {
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594403 is a reply to message #58250] |
Hi, Marcin,
Christian
>> Hi, Marcin,
>> command
> editingDomain is
> read/write
> used
> implicitly
> options.
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594422 is a reply to message #58351] |
Hi, Marcin,
Christian
> Marcin.
Re: EMFT Transaction 1.0.1: Cannot modify resource set without a write transaction [message #594441 is a reply to message #58374] |
Junior Member |
> Hi, Marcin,
> Cheers,
> Christian
Marcin.
Current Time: Sat Oct 19 11:29:48 GMT 2024
Powered by FUDForum. Page generated in 0.03593 seconds
