Home » Archived » M2M (model-to-model transformation) » [ATL] Model checking with ATL
[ATL] Model checking with ATL [message #58117] |
Fri, 17 August 2007 11:03 |
Originally posted by: kernheiko.gmx.de
I would like to use ATL for checking models. An approach for this is
described in [1]. Examples are given in [2] and [3].
I wrote the following two rules for checking my models:
rule SetOfEventsNotEmpty {
from i : Aris!Model(i.getSymbols()
->collect(symbol|symbol.oclIsTypeOf(Aris!S_Ereignis_1))
->isEmpty())
to o : Problem!Problem (
description <- 'No event exists.',
severity <- #error,
location <- 'model name: ' + i.name + '--- id: ' + i.id )
rule SetOfFunctionsNotEmpty {
->collect(symbol|symbol.oclIsTypeOf(Aris!S_Funktion_335))
->isEmpty())
description <- 'No function exists.',
severity <- #error,
location <- 'model name: ' + i.name + ' --- id: ' + i.id )
During the execution ATL prints the following stack trace message:
****** BEGIN Stack Trace
message: trying to register several rules as default for element
IN!Kein_Ereignis_und_keine_Funktion: 'SetOfEventsNotEmpty' and
'SetOfFunctionsNotEmpty'
A.main() : ??#22 null
local variables = {self=epk_check : ASMModule}
local stack = []
A.__matcher__() : ??#3 null
local stack = []
A.__matchSetOfFunctionsNotEmpty() : ??#50 null
local variables = {i=IN!Kein_Ereignis_und_keine_Funktion,
local stack = []
NativeOperation public static void
org.atl.engine.vm.nativelib.ASMTransientLinkSet.addLink(org. atl.engine.vm.StackFrame,org.
atl.engine.vm.nativelib.ASMTransientLinkSet,org.atl.engine.v m.nativelib.ASMTransientLink)
args = [TransientLinkSet {TransientLink {rule =
'SetOfEventsNotEmpty', sourceElements = {i =
IN!Kein_Ereignis_und_keine_Funktion}, targetElements = {o =
OUT!<unnamed>}, variables = {}}}, TransientLink {rule =
'SetOfFunctionsNotEmpty', sourceElements = {i =
OUT!<unnamed>}, variables = {}}]
****** END Stack Trace
Execution terminated due to error (see launch configuration to allow
continuation after errors).
I think the problem is that ATL cannot apply several rules to one
Aris!Model. Is that right? Is there an alternative to describe my rules?
Heiko
[1]: Bézivin and Jouault: Using ATL for Checking Models. Workshop on
Graph and Model Transformation (GraMoT). 2005.
[2]: http://www.eclipse.org/m2m/atl/atlTransformations/#KM32Probl em
[3]: http://www.eclipse.org/m2m/atl/atlTransformations/#ATL2Probl em
Re: [ATL] Model checking with ATL [message #58544 is a reply to message #58117] |
Fri, 17 August 2007 20:53 |
Frédéric Jouault Messages: 572 Registered: July 2009 |
You correctly diagnosed the problem.
By default, standard rules register "default" traceability links.
Obviously, only one such link can exist for a given source.
You may prefix the rule definitions with the "nodefault" keyword to
prevent standard rules from registering "default" traceability links.
Note that you may need to switch to the latest version of ATL (2.0RC2)
available from:
http://www.eclipse.org/m2m/atl/download/
Frédéric Jouault
Heiko Kern wrote:
> Hello,
> ->isEmpty())
> severity <- #error,
> ->isEmpty())
> severity <- #error,
> local stack = []
> local stack = []
> local stack = []
> Heiko
Re: [ATL] Model checking with ATL [message #58742 is a reply to message #58544] |
Mon, 20 August 2007 09:58 |
I marked the rules with the keyword "nodefault", but ATL (ATL_Bundle_2.0.0RC2_Windows) printed the
same error message plus an exception. I don't know why?
My changed rules:
nodefault rule SetOfEventsNotEmpty {
->collect(symbol|symbol.oclIsTypeOf(Aris!S_Ereignis_1))->isEmpty())
severity <- #error,
nodefault rule SetOfFunctionsNotEmpty {
->collect(symbol|symbol.oclIsTypeOf(Aris!S_Funktion_335))->isEmpty())
severity <- #error,
Error Message:
SCHWERWIEGEND: ****** BEGIN Stack Trace
SCHWERWIEGEND: message: trying to register several rules as default for element
IN!Kein_Ereignis_und_keine_Funktion: 'SetOfEventsNotEmpty' and 'SetOfFunctionsNotEmpty'
SCHWERWIEGEND: A.main() : ??#22 null
SCHWERWIEGEND: local variables = {self=epk_check : ASMModule}
SCHWERWIEGEND: local stack = []
SCHWERWIEGEND: A.__matcher__() : ??#3 null
SCHWERWIEGEND: A.__matchSetOfFunctionsNotEmpty() : ??#50 null
SCHWERWIEGEND: local variables = {null=IN!<unnamed>, i=IN!Kein_Ereignis_und_keine_Funktion,
SCHWERWIEGEND: NativeOperation public static void
org.eclipse.m2m.atl.engine.vm.nativelib.ASMTransientLinkSet. addLink(org.eclipse.m2m.atl.engine.vm.StackFrame,org.eclipse .m2m.atl.engine.vm.nativelib.ASMTransientLinkSet,org.eclipse .m2m.atl.engine.vm.nativelib.ASMTransientLink)
SCHWERWIEGEND: args = [TransientLinkSet {TransientLink {rule = 'SetOfEventsNotEmpty',
sourceElements = {i = IN!Kein_Ereignis_und_keine_Funktion}, targetElements = {o = OUT!<unnamed>},
variables = {}}}, TransientLink {rule = 'SetOfFunctionsNotEmpty', sourceElements = {i =
IN!Kein_Ereignis_und_keine_Funktion}, targetElements = {o = OUT!<unnamed>}, variables = {}}]
SCHWERWIEGEND: ****** END Stack Trace
INFO: Execution terminated due to error (see launch configuration to allow continuation after errors).
SCHWERWIEGEND: java.lang.reflect.InvocationTargetException cannot be cast to java.lang.RuntimeException
java.lang.ClassCastException: java.lang.reflect.InvocationTargetException cannot be cast to
at org.eclipse.m2m.atl.engine.vm.SimpleDebugger.error(SimpleDeb ugger.java:162)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:85)
at org.eclipse.m2m.atl.engine.vm.StackFrame.printStackTrace(Sta ckFrame.java:77)
at org.eclipse.m2m.atl.engine.vm.ClassNativeOperation.exec(Clas sNativeOperation.java:67)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:133)
at org.eclipse.m2m.atl.engine.vm.nativelib.ASMOclAny.invoke(ASM OclAny.java:91)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:230)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.realExec(ASMOpera tion.java:325)
at org.eclipse.m2m.atl.engine.vm.ASMOperation.exec(ASMOperation .java:161)
at org.eclipse.m2m.atl.engine.vm.ASMInterpreter.<init>(ASMInterpreter.java:289)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:155)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:105)
at org.eclipse.m2m.atl.engine.AtlLauncher.launch(AtlLauncher.ja va:81)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:351)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.runAtlLaunche r(AtlRegularVM.java:453)
at org.eclipse.m2m.atl.adt.launching.AtlRegularVM.launch(AtlReg ularVM.java:425)
org.eclipse.m2m.atl.adt.launching.AtlLaunchConfigurationDele gate.launch(AtlLaunchConfigurationDelegate.java:35)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:766)
at org.eclipse.debug.internal.core.LaunchConfiguration.launch(L aunchConfiguration.java:608)
at org.eclipse.debug.internal.ui.DebugUIPlugin.buildAndLaunch(D ebugUIPlugin.java:899)
at org.eclipse.debug.internal.ui.DebugUIPlugin$7.run(DebugUIPlu gin.java:1102)
In order to solve my problem, I rewrote my rules as follows:
from i : Aris!Model
do {
if( i.getSymbols()->collect(symbol|symbol.oclIsTypeOf(Aris!S_Ereignis_1))
->isEmpty() ) {
thisModule.CreateProblem( 'No event exists', 'error' ,
'model name: ' + i.name + ' --- id: ' + i.id );
if( i.getSymbols()->collect(symbol|symbol.oclIsTypeOf(Aris!S_Funktion_335))
->isEmpty() ) {
thisModule.CreateProblem( 'No function exists', 'error',
rule CreateProblem( desc : String, sev : String , loc : String ) {
to
o : Problem!Problem(
description <- desc,
severity <-
if sev = 'warning'
then #warning
else if sev = 'critic'
then #critic
else #error
endif
endif,
location <- loc)
This variant works fine, but I am interested in the "nodefault-variant", because I find it better to
separate every check criterion in one ATL-rule.
Heiko
Frédéric Jouault schrieb:
> available from:
> Frédéric Jouault
> Heiko Kern wrote:
>> Hello,
>> ->isEmpty())
>> severity <- #error,
>> ->isEmpty())
>> severity <- #error,
>> local stack = []
>> local stack = []
>> local stack = []
>> Thanks,
>> Heiko
Re: [ATL] Model checking with ATL [message #59178 is a reply to message #58742] |
Thu, 23 August 2007 18:35 |
Sorry, I forgot to say that you must use ATL 2006 for "nodefault" to be
actually recognized.
Frédéric Jouault
Heiko Kern wrote:
> Hello,
> My changed rules:
> severity <- #error,
> severity <- #error,
> Error Message:
> for element
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)
> from i : Aris!Model
> do {
> if(
> ->isEmpty() ) {
> if(
> ->isEmpty() ) {
> to
> severity <-
> if sev = 'warning'
> then #warning
> then #critic
> else #error
> endif
> endif,
> location <- loc)
> because I find it better to separate every check criterion in one ATL-rule.
> Heiko
>> available from:
>> Regards,
>> Frédéric Jouault
>> Heiko Kern wrote:
>>> Hello,
>>> ->isEmpty())
>>> severity <- #error,
>>> ->isEmpty())
>>> severity <- #error,
>>> local stack = []
>>> local stack = []
>>> local stack = []
>>> Thanks,
>>> Heiko
Re: [ATL] Model checking with ATL [message #59657 is a reply to message #59178] |
Tue, 28 August 2007 08:40 |
Thanks for the information. It works.
Here are my two example rules:
--@atlcompiler atl2006
nodefault rule NoEvent {
from
i : Aris!M_EPK_13(i.getAllEventSymbols()->isEmpty())
to
severity <- #error,
+ i.name + ' --- model id: ' + i.id)
nodefault rule NoFunction {
from
i : Aris!M_EPK_13(i.getAllFunctionSymbols()->isEmpty())
to
severity <- #error,
Heiko
> Hello,
> Frédéric Jouault
> Heiko Kern wrote:
>> Hello,
>> My changed rules:
>> severity <- #error,
>> severity <- #error,
>> Error Message:
>> default for element
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> from i : Aris!Model
>> do {
>> if(
>> ->isEmpty() ) {
>> 'error' ,
>> if(
>> ->isEmpty() ) {
>> 'error',
>> to
>> severity <-
>> if sev = 'warning'
>> then #warning
>> then #critic
>> else #error
>> endif
>> endif,
>> location <- loc)
>> "nodefault-variant", because I find it better to separate every check
>> Thanks,
>> Heiko
>>> Hi,
>>> (2.0RC2) available from:
>>> Regards,
>>> Frédéric Jouault
>>> Heiko Kern wrote:
>>>> Hello,
>>>> ->isEmpty())
>>>> severity <- #error,
>>>> ->isEmpty())
>>>> severity <- #error,
>>>> local stack = []
>>>> local stack = []
>>>> local stack = []
>>>> rules?
>>>> Thanks,
>>>> Heiko
Re: [ATL] Model checking with ATL [message #59730 is a reply to message #58544] |
Wed, 29 August 2007 08:23 |
Originally posted by: r.c.ladan.tue.nl
so if I understand the 'nodefault' keyword correctly, it can be used to tell
the ATL engine to use this rule instead of another one in case there are
conflicting input patterns.
E.g., in a.atl :
rule A {
from mm!Elem
to mm!Elem(...)
and b.atl, which references a.atl by superimposition:
nodefault rule B {
from mm!Elem(condition)
to mm!Elem(...)
Normally rule A and B conflict (because rule B does not extend rule A), but using
the 'nodefault' keyword seems to tell the ATL engine to use rule B in this case.
Is this correct?
Rene
Frédéric Jouault wrote:
> available from:
> Frédéric Jouault
> Heiko Kern wrote:
>> Hello,
>> ->isEmpty())
>> severity <- #error,
>> ->isEmpty())
>> severity <- #error,
>> local stack = []
>> local stack = []
>> local stack = []
>> Thanks,
>> Heiko
Current Time: Thu Oct 10 23:20:40 GMT 2024
Powered by FUDForum. Page generated in 0.04997 seconds
