Hibernate and Jetty and Plugin [message #58105] |
Wed, 07 November 2007 03:53 |
Originally posted by: m.n.com
Anyone know how to get to the web.xml (or whatever is being used) in the
RAP Plugin? I need to put some things in it to init Hibernate.
Re: Hibernate and Jetty and Plugin [message #59589 is a reply to message #58105] |
Wed, 14 November 2007 09:30 |
Originally posted by: fappel.innoopract.com
RAP uses an OSGi Http Service implementation as underlying servlet runtime
for development mode. The implementation uses an embbeded Jetty engine.
Unfortunately there is no possibility yet to use a web.xml (or a complete
replacement mechanism) for configuration in this mode. For more information
about the infrastructure used by RAP you may have a look at
http://www.eclipse.org/equinox/server/.
However using the Embedding Equinox in a Servlet Container mode
(http://www.eclipse.org/equinox/server/http_in_container.php) with RAP (see
also the deployment threads in this newsgroup) the whole application is
deployed as a standard web application using a web.xml. Maybe this could be
useful for you.
Ciao
Frank
"Mark" <m@n.com> schrieb im Newsbeitrag
news:fgrctb$o90$1@build.eclipse.org...
Re: Hibernate and Jetty and Plugin [message #59923 is a reply to message #59589] |
Wed, 14 November 2007 23:33 |
Thanks Frank. I knew about the servlet container embedding for
deployment and my plan was to do that on deployment. But I was hoping to
not have to hack something up during development and then change it on
deployment. But I guess I have no choice. I do have the hacked up
stuff working. Not a big deal. For now.
Frank Appel wrote:
> useful for you.
> Ciao
> Frank
Re: Hibernate and Jetty and Plugin [message #59944 is a reply to message #59923] |
Thu, 15 November 2007 10:31 |
Originally posted by: benedikt.arnold.beyondsoft.de
Hi!
I use system properties to configure hibernate. For development I put them
as arguments in the launch configuration like this: -Dhibernate.dialect=...
And for deployment I put them the same way into the web.xml file. This is
done at the same place as the -console argument.
Greetings,
Benedikt
Re: Hibernate and Jetty and Plugin [message #59990 is a reply to message #59944] |
Thu, 15 November 2007 10:40 |
I fogot to mention that you have to read the properties form bundle
context and put them manually into the Hibernate configuration object.
Re: Hibernate and Jetty and Plugin [message #60128 is a reply to message #59990] |
Fri, 16 November 2007 00:56 |
Thanks. Thats a good idea. But I guess I forgot to mention I was using
Spring too, so I won't be able to do that.
FUDForum. Page generated in 0.03891 seconds
