PHP IDE [message #58038] |
Sat, 13 October 2007 06:58 |
Originally posted by: rafi.yachoua.gmail.com
Hello Everyone,
I'm new to Eclipse.
I downloaded pdt-all-in-one-1.0-R20070917-linux-gtk.tar.
When I run eclipse, there is no PHP view.
I tried to do Software Update, Find and install.
I tried to add a remote site
(http://download.eclipse.org/tools/php/updates/) as specified in this
document.
But I do not think it is actually downloading the PHP IDE and installing
it.
What site can I use to add the feature?
Any help would be much appreciated.
Rafi.
Re: PHP IDE [message #58062 is a reply to message #58038] |
Sat, 13 October 2007 07:16 |
They're calling it a "perspective". Terminal terminology definition
dysfunction. heh.
Open Perspective should be one of the menu items available under
"Window". There should be at least "PHP" and "PHP Debug" available.
Earl Cooley III (shiva@io.com)
Re: PHP IDE [message #58087 is a reply to message #58038] |
Sat, 13 October 2007 14:10 |
Originally posted by: news.kasimir-k.fi
Rafi scribeva in 13/10/2007 6:58:
If you downloaded the all-in-one, then PDT is there, no need to get it
again through update.
Check you have supported java version (1.5+).
..k
Re: PHP IDE [message #58136 is a reply to message #58087] |
Sat, 13 October 2007 15:16 |
thank you k.
Java version1.5+ was the problem. I had 1.4.2
r.
Re: PHP IDE [message #59047 is a reply to message #58087] |
Thu, 18 October 2007 12:35 |
This is getting real FAQ; isn't it possible for PDT to detect that a <
1.5 VM is being used and warn the user about it?
Daniel Serodio
FUDForum. Page generated in 0.03950 seconds
