Re: Theming questions (buttontext/viewtab) [message #58055 is a reply to message #57934] |
Tue, 06 November 2007 22:17 |
Originally posted by: rsternberg.innoopract.com
Hi Magnus,
Magnus Konze schrieb:
> 1) Text color of buttons
> The comment in the template says, button.foreground changes the color of
> "PUSH and TOGGLE buttons". But in my application radio buttons are
> affected too. This is a problem, because i have white text on a red
> background (PUSH button), but RADIO buttons should have black text on
> white background (now i have white text on white background). Is it
> possible to achieve this via theming?
> By the way, button.CHECK.background seems to have no effect.
You're absolutely right in both cases. I opened a bug on this:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=208958
> 2) Color of View tabs
> I figured out, that i can change the backgroundcolor of the active View
> tab with list.selection.background. But the next properties (foreground,
> unfocused.foreground, unfocused.background) don't change anything on the
> tabs. Is this intention or is this the wrong property?
The property list.selection.background manipulates the SWT system color
SWT.COLOR_LIST_BACKGROUND which is used by Lists, Tree etc.
The CTabFolder widget uses the SWT colors SWT.COLOR_LIST_FOREGROUND and
SWT.COLOR_LIST_BACKGROUND as default selection colors.
The workbench also customizes the colors of its CTabFolders using the
workbench theming which is not yet implemented in RAP.
Ralf
FUDForum. Page generated in 0.04498 seconds
