Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » teneo - persisting the ecore itself (FAQ)
Re: teneo - persisting the ecore itself (FAQ) [message #57856 is a reply to message #57832] |
Mon, 16 October 2006 22:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Andre,
Yeah, Martin has done a great job, hasn't he! ;-)
Andre Pareis wrote:
> I'm really impressed. I just gave it a try and it was absolutely no
> problem to persist the ecore itself plus my own packages. Martin, this
> is really really a great piece of work that you've created for us
> here... :)
> Andre Pareis schrieb:
>> Hi Martin (and others),
>> I know that this or similar have been asked before. But just out of
>> curiosity, is persisting of the ecore itself fully supported now?
>> I'm asking because I just experimentally added an association from my
>> domain model to the EClass and added the EcorePackage.eINSTANCE to
>> the EPackages to be mapped to hibernate and surprisingly it worked!
>> At least, ecore related tables have been created in the DB, like
>> "EClass", "EPackage" and others. Will those be fully working or with
>> restrictions? Has anybody tested this already?
>> I'm asking because the architecture of the application that I am
>> going to build kind of depends on those capabilities. If this is not
>> an option, I would have to help myself with EClass IDs which I had to
>> resolve in a derived association for instance. If teneo already had
>> the capabilities, I could use them directly! That would make it very
>> much easier...
>> Regards
>> Andre
Re: teneo - persisting the ecore itself (FAQ) [message #57878 is a reply to message #57856] |
Tue, 17 October 2006 09:37 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Martin Taal![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=mtaal%40springsite.com) Messages: 5468 Registered: July 2009 |
Thanks for the kudos :-)!
I actually tested this before and on mysql 4.1 I got an exception because hibernate tried to do a
join with 61 tables which it apparently was not able to handle. So the queries may not be that
efficient. On the other hand model data is normally very small (in database terms).
With microsoft sql server my test (storing and retrieving the library ecore model) worked fine.
When I tested it it also stored the ecore model itself in the database (as the ecore model is
represented in ecore also).
gr. Martin
Ed Merks wrote:
> Andre,
>> here... :)
>>> much easier...
>>> Regards
>>> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - persisting the ecore itself (FAQ) [message #594178 is a reply to message #57832] |
Mon, 16 October 2006 22:54 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Ed Merks![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=ed.merks%40gmail.com) Messages: 33184 Registered: July 2009 |
Andre,
> here... :)
>> much easier...
>> Regards
>> Andre
Ed Merks
Re: teneo - persisting the ecore itself (FAQ) [message #594192 is a reply to message #57856] |
gr. Martin
Ed Merks wrote:
> Andre,
>> here... :)
>>> much easier...
>>> Regards
>>> Andre
The Netherlands
Current Time: Fri Jul 19 05:19:14 GMT 2024
Powered by FUDForum. Page generated in 0.04021 seconds
