Re: PRB with Example under Linux/GTK [message #58215 is a reply to message #57800] |
Mon, 27 January 2003 14:16 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: hudsonr.us.i_b_m.com
SWT/GTK does not support native drag-and-drop in 2.0.2.
"contus" <contus@web.de> wrote in message news:b0qvlb$kcp$1@rogue.oti.com...
> I've got a problem with the logic example using Eclipse 2.0.2 (stable) and
> GEF I20030121 under Linux/GTK2: I can't add new components from the
palette
> (but I can perfectly move around existing components on the editor - once
> brought onto the editor via the 4bit-adder wizard).
> Did I miss something or did I run into a bug?
> Thanks in advance,
> Flo
Re: PRB with Example under Linux/GTK [message #62583 is a reply to message #62513] |
Thu, 06 February 2003 14:35 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
"contus" <contus@web.de> wrote in message news:b1tqa2$t4t$2@rogue.oti.com...
> Is it a difference between dragging and dropping an item from the palette
> (which does not work) and dragging and dropping an item within the editor
> (which works perfectly)?
Yes, inside the editor is a single SWT Canvas. We use mouse listeners to
drag the items. If we used native DND inside the editor, we would not be
able to control the Cursor.
> Flo
> >> and GEF I20030121 under Linux/GTK2: I can't add new components from the
> > palette
once
> >> Thanks in advance,
> >> Flo
FUDForum. Page generated in 0.01866 seconds
