Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » teneo - PersistenceOptions.SQL_CASE_STRATEGY = "none" has no effect
Re: teneo - PersistenceOptions.SQL_CASE_STRATEGY = "none" has no effect [message #57759 is a reply to message #57734] |
Mon, 16 October 2006 19:19 |
Andre Pareis Messages: 113 Registered: July 2009 |
Hi Martin,
Thanks for updating me regarding the discrepancy between ZIP and the UM.
I was getting more and more paranoid as you kept telling me that your
callisto was fine and I had no explaination why mine behaved completely
different. BTW I always had to unselect the documentation plugin,
because if I didn't then the whole update failed with a general error -
can you confirm that this is normal or not?
And here is a patch about my changes in the DefaultAnnotator against the
CVS head. I did these changes quite quickly without checking what the
code does, solely based on the stack trace in the debugger when calls to
None.convert() happened. So the changes might be specific to my model
which does not use FeatureMaps and other more advanced ecore stuff.
Andre
### Eclipse Workspace Patch 1.0
#P org.eclipse.emf.teneo.annotations
Index: src/org/eclipse/emf/teneo/annotations/mapper/DefaultAnnotato r.java
RCS file:
/cvsroot/technology/org.eclipse.emft/teneo/plugins/org.eclip se.emf.teneo.annotations/src/org/eclipse/emf/teneo/annotatio ns/mapper/DefaultAnnotator.java,v
retrieving revision 1.6
diff -u -r1.6 DefaultAnnotator.java
--- src/org/eclipse/emf/teneo/annotations/mapper/DefaultAnnotato r.java
29 Sep 2006 12:46:33 -0000 1.6
+++ src/org/eclipse/emf/teneo/annotations/mapper/DefaultAnnotato r.java
16 Oct 2006 19:11:24 -0000
@@ -296,7 +296,7 @@
final String idFeature = (String) it.next();
final PrimaryKeyJoinColumn pkjc =
aFactory.createPrimaryKeyJoinColumn();
final String colName = superClass.getName() + "_" + idFeature;
- pkjc.setName(trunc(colName.toUpperCase(), true));
+ pkjc.setName(trunc(colName, true));
aClass.getPrimaryKeyJoinColumns().add(pkjc);
@@ -308,10 +308,10 @@
.equals(InheritanceType.JOINED_LITERAL)))) {
final Table table = aFactory.createTable();
table.setEModelElement(eclass);
- table.setName(trunc(eclass.getName().toUpperCase(), false));
+ table.setName(trunc(eclass.getName(), false));
aClass.setTable(table);
} else if (aClass.getTable() != null && aClass.getTable().getName()
== null) {
- aClass.getTable().setName(trunc(eclass.getName().toUpperCase (), false));
+ aClass.getTable().setName(trunc(eclass.getName(), false));
// if the strategy is all classes of one hierarchy in one table and
this is not the superclass
@@ -1067,7 +1067,7 @@
} else {
jcName = aClass.getAnnotatedEClass().getName() + "_" + name;
- jc.setName(trunc(jcName.toUpperCase(), true));
+ jc.setName(trunc(jcName, true));
jc.setNullable(optional);
jc.setUpdatable(isUpdateInsertable);
jc.setInsertable(isUpdateInsertable);
Martin Taal schrieb:
> Hi Andre,
> Thanks for letting me know. In which places did you remove the
> toUpperCase()?
> Btw, related to the other exception you got (with the
> log4j.PropertyConfigurator). I can now reproduce it.
> There appears to be a difference between the builds distributed through
> the update manager (which fail with this error) and the directly
> downloadable zip files (which work).
> I have entered a bugzilla for this exception.
> gr. Martin
> Andre R. Pareis wrote:
>> if I set the persistence option "none" to SQL_CASE_STRATEGY, then all
>> table and column names are create in capitals. I have debugged and
>> have seen that at the relevant code pieces a .toUppercase() always
>> takes place.
>> I have removed the toUppercase() calls and then the "none" option
>> worked for me.
>> Regards,
>> Andre
Re: teneo - PersistenceOptions.SQL_CASE_STRATEGY = "none" has no effect [message #57783 is a reply to message #57759] |
Mon, 16 October 2006 19:51 |
Martin Taal Messages: 5468 Registered: July 2009 |
Hi Andre,
Thanks for the patch your changes seem logical. I have also removed some other toUpperCases and
committed the change.
Yes the issue with the documentation plugin is correct. The error is actually that the documentation
plugin is not present on the update manager site (it is a basic http 404 error). Currently it is
unclear for me why the eclipse emft build does not pick it up and I do not know why the update
manager lists it while the jar file is not there. I (we) are looking at it though.
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Thanks
> Andre
> RCS file:
> @@ -296,7 +296,7 @@
> idFeature;
> aClass.getTable().getName() == null) {
> and this is not the superclass
> } else {
> name;
>> Hi Andre,
>> toUpperCase()?
>> through the update manager (which fail with this error) and the
>> directly downloadable zip files (which work).
>> gr. Martin
>>> Hi,
>>> takes place.
>>> worked for me.
>>> Regards,
>>> Andre
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo - PersistenceOptions.SQL_CASE_STRATEGY = "none" has no effect [message #594135 is a reply to message #57734] |
Hi Martin,
Andre
RCS file:
@@ -296,7 +296,7 @@
== null) {
} else {
> Hi Andre,
> toUpperCase()?
> gr. Martin
>> takes place.
>> worked for me.
>> Regards,
>> Andre
Re: teneo - PersistenceOptions.SQL_CASE_STRATEGY = "none" has no effect [message #594142 is a reply to message #57759] |
Hi Andre,
gr. Martin
Andre Pareis wrote:
> Hi Martin,
> Thanks
> Andre
> RCS file:
> @@ -296,7 +296,7 @@
> idFeature;
> } else {
> name;
>> Hi Andre,
>> toUpperCase()?
>> gr. Martin
>>> Hi,
>>> takes place.
>>> worked for me.
>>> Regards,
>>> Andre
The Netherlands
Current Time: Sat Oct 19 11:04:52 GMT 2024
Powered by FUDForum. Page generated in 0.03895 seconds
