Home » Archived » XML Schema Definition (XSD) » HTML 4.01 DTD validation problem
HTML 4.01 DTD validation problem [message #57620] Mon, 14 February 2005 03:07 Go to next message
Originally posted by: ushakov.int.com.ru
I suspect my problem is most likely a FAQ, but I still could not find an
answer...
I'm working on a schema that includes the HTML 4.01 DTD.
If I indicate 'http://www.w3.org/TR/html4/strict.dtd' as 'Schema location'
for the <import> directive, I get the following error:
http://www.w3.org/TR/html4/strict.dtd is an invalid XML schema file
If I make a local copy of this DTD and try to validate it, I get the
following error:
The declaration for the entity "ContentType" must end with '>'. ... line
81 ...
And line 81 contains a comment inside !ENTITY declaration.
I have added Xerces 2.6.2 to my configuration as prescribed by page
http://www.eclipse.org/webtools/wst/components/xml/xercesInf o.xml
I have Eclipse 3.1.0 Build id: 200412162000 on Windows.
My JVM: 1.5.0_01
My XSD: Version: 2.1.0 Build id: 200502100800
My EMF: Version: 2.1.0 Build id: 200502100800
Any ideas?
Sergey
Re: HTML 4.01 DTD validation problem [message #57646 is a reply to message #57620] Mon, 14 February 2005 06:20 Go to previous messageGo to next message
Sergey,
A .dtd is not a .xsd and won't even parse as XML. You will need to find
the .xsd rather than the .dtd.
Ushakov, Sergey wrote:
>Hi,
>answer...
>following error:
>81 ...
>My JVM: 1.5.0_01
>Any ideas?
>Thanks,
>Sergey
Re: HTML 4.01 DTD validation problem [message #57679 is a reply to message #57646] Mon, 14 February 2005 09:39 Go to previous message
Thanks Ed,
it's honey to my soul to know that nothing seems to be wrong with my config
Sergey
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:cuq1h5$g7$1@www.eclipse.org...
Sergey,
>Hi,
>answer...
>following error:
line
>81 ...
>My JVM: 1.5.0_01
>Any ideas?
>Thanks,
>Sergey
Re: HTML 4.01 DTD validation problem [message #593948 is a reply to message #57620] Mon, 14 February 2005 06:20 Go to previous message
Sergey,
>Hi,
>answer...
>following error:
>81 ...
>My JVM: 1.5.0_01
>Any ideas?
>Thanks,
>Sergey
Re: HTML 4.01 DTD validation problem [message #593973 is a reply to message #57646] Mon, 14 February 2005 09:39 Go to previous message
Thanks Ed,
Sergey
Sergey,
>Hi,
>answer...
>following error:
line
>81 ...
>My JVM: 1.5.0_01
>Any ideas?
>Thanks,
>Sergey
Previous Topic:HTML 4.01 DTD validation problem
Next Topic:Suitability of XSD for particular task
Current Time: Thu Nov 06 14:08:16 EST 2025
Powered by FUDForum. Page generated in 0.04657 seconds
