Re: Integration Build 20040825 available [message #57616 is a reply to message #57519] |
Thu, 26 August 2004 14:04 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) |
Peter Walker![Friend of Eclipse Friend](/donate/web-api/friends_decorator.php?email=walkerp%40us.ibm.com) Messages: 124 Registered: July 2009 |
This integration build is based on what is in the cvs HEAD for VEP. So if you
are setting up your development workspace, I would recommend going to the build
sites for Eclipse, EMF, and GEF... and getting their SDKs instead of the
runtimes for the build level in this VE driver. On the VE download page, their
is a link to each of these you can select to get to the respective build sites.
Regards...
Peter Walker
snpe wrote:
> What are requests for eclipse,emf and gef when download VEP from cvs HEAD ?
> regards
> Peter Walker wrote:
>>This driver is now available at
> http://download.eclipse.org/tools/ve/downloads/drops/I-I2004 0825-200408251837/index.html
>>I just want to make everyone aware that this driver (and subsequent
>>drivers) will be built based on fairly recent Eclipse, EMF, and GEF
>>maintenance drivers. So please pay particular attention to the
>>Requirements list on the download page for each driver to ensure you
>>install the correct driver levels. The VE downloads page points directly
>>to the zips you will need. For example, in this driver you will need:
>>- Eclipse M20040818
>>- EMF M200408190924
>>- GEF M20040809
>>Also VE has changed to use EMF APIs that are in the latest EMF
>>maintenance driver and therefore will not work on previous EMF drivers.
>>The VE M2 (milestone 2) driver is still available for those that wish to
>> stay on Eclipse 3.0, EMF 2.0, and GEF 3.0.
>>Regards...
>>Peter Walker
>>Visual Editor Development
Re: Integration Build 20040825 available [message #597807 is a reply to message #57519] |
Regards...
Peter Walker
> regards
>>- Eclipse M20040818
>>- EMF M200408190924
>>- GEF M20040809
>>Regards...
>>Peter Walker
FUDForum. Page generated in 0.03016 seconds
