Home » Language IDEs » PHP Development Tools (PDT) » XDebug error on 2nd launch
XDebug error on 2nd launch [message #57493] Tue, 09 October 2007 13:03 Go to next message
Originally posted by: eclipse.davidenko.net
I have this error alert when I debug for the SECOND time a php script :
"web launch already running"
The first debugging session is correct and well-terminated (launched
directly by script, or by my web server).
I try with the zend debugger server extension too (I have two apache/php
configs), and there isn't any pb. But I'll like to test and use xdebug
possibilities.
Thank you for your help.
vd.
Re: XDebug error on 2nd launch [message #57517 is a reply to message #57493] Tue, 09 October 2007 15:14 Go to previous messageGo to next message
You can only have a single xdebug web launch active at any one time. When
your web script terminates, the web launch remains active until you terminate it
so you cannot relaunch a debug session.
For more info please see
http://www.eclipse.org/pdt/documents/XDebugGuide.pdf
Dave Kelsey
> possibilities.
> vd.
Re: XDebug error on 2nd launch [message #57670 is a reply to message #57517] Wed, 10 October 2007 06:13 Go to previous message
Thank you,
I read this doc before, but I haven't seen I must explicitly clic on
RemoteLauch to stop session (cookie removing) !!
> terminate it
> Dave Kelsey
>> apache/php configs), and there isn't any pb. But I'll like to test and
>> use xdebug possibilities.
>> vd.
Previous Topic:PDT Open Declaration opens in read only mode
Next Topic:Eclipse and PHP
Current Time: Wed Oct 29 17:11:18 EDT 2025
Powered by FUDForum. Page generated in 0.24579 seconds
