Home » Eclipse Projects » Nebula » GridTableViewer - JFace Databinding - Dates
Re: GridTableViewer - JFace Databinding - Dates [message #57637 is a reply to message #57612] |
Mon, 11 August 2008 17:28 |
Emil Crumhorn Messages: 169 Registered: July 2009 |
Hope you don't mind a little thread hijack (Peter said it was ok ;) ),
Tom, do you know the status on the GridViewer in SWT.VIRTUAL? I see the
source has a bunch of TODO's listed for it. I'm not sure what's involved,
but as the grid seems to work really well in normal SWT.VIRTUAL without a
viewer, it seems it's almost there (?). I would really love a virtual
viewer!
Any ideas?
Emil
"Peter Pfeifer" <peter.pfeifer@mic-cust.com> wrote in message
news:g7p403$gh2$1@build.eclipse.org...
> Hi.
> That's good news. I eagerly waiting for it.
> Thanks for all your work!
> Peter
> Tom Schindl schrieb:
>> Hi Peter,
>> No not yet. I'm currently maintaining a fork locally until I've finished
>> my work completely (I was only holiday the last 4 weeks) and then merge
>> it back to nebula. There are still some minor issues with the
>> Header-Controls.
>> I'll post a message when the sources are available.
>> Tom
>> Peter Pfeifer schrieb:
>>> Hi Tom.
>>> Thanks that helped me a lot!
>>> Are there any new changes on the grid/gridviewer itself? You posted a
>>> very cool screenshot a few weeks ago. Are these changes on the
>>> grid/gridviewer?
>>> Peter
>>>> Sorry i didn't read the header correctly you are using an
>>>> ObservableLabelProvider right? Which automatically does a toString().
>>>> I've written custom ones who are using MessageFormat. You can fetch
>>>> them from:
>>>> http://publicsvn.bestsolution.at/repos/java/at.bestsolution. dataforms/trunk/src/at/bestsolution/dataforms/util/viewers/
>>>> With this you can write something like this:
>>>> new GenericObservableMapCellLabelProvider(obsMap,"{0,short,date} ");
>>>> If you are using EMF I've written even better ones who also support
>>>> .-notation when you want to access nested attribute (but it depends on
>>>> org.apache.lang and the use of EObject):
>>>> http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.common/src/at/bestsolutio n/soccer/ui/common/viewers/ObservableColumnLabelProvider.jav a
>>>> new ObservableColumnLabelProvider(map,"${0} (${1.name})
>>>> See
>>>> http://publicsvn.bestsolution.at/repos/java/examples/EMF-Dat abinding/at.bestsolution.soccer.ui.associationadmin/src/at/b estsolution/soccer/ui/associationadmin/AssociationAdministra tionViewPart.java
>>>> Method: createTreeViewer how to use it you could easily customize it to
>>>> use JavaBean lookup.
>>>> Tom
>>>>> You need to set your own ColumnLabelProvider#getText(Object) or
>>>>> ITableLabelProvider#getText(int,Object) and check the instance for
>>>>> Date and use SimpleDateFormat. The default LabelProvider always simply
>>>>> calls the given objects toString method.
>>>>> Tom
>>>>>> Hello there.
>>>>>> Is there a way to change the display format of a Date or Calendar
>>>>>> object in the GridTableViewer. Right now it seems that a
>>>>>> date.toString() is done.
>>>>>> How can this value be displayed in a locale specific format?
>>>>>> Thanks in advance.
>>>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #57680 is a reply to message #57637] |
Mon, 11 August 2008 19:24 |
Thomas Schindl Messages: 6651 Registered: July 2009 |
Hi Emil,
Frankly I don't know when I finished my current work (with the
header/footer stuff) I can take a look into it. I'd also like to
introduce a feature to pool images and dispose them for rows not visible
this should make it possible for the Grid to deal with thousands of
different images.
Tom
> viewer!
> Any ideas?
> Emil
>> Hi.
>> Peter
>>> Hi Peter,
>>> Header-Controls.
>>> Tom
>>>> Hi Tom.
>>>> grid/gridviewer?
>>>> Peter
>>>>> them from:
>>>>> See
>>>>> Tom
>>>>>> Tom
>>>>>>> Hello there.
>>>>>>> Thanks in advance.
>>>>>>> Peter
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: GridTableViewer - JFace Databinding - Dates [message #591669 is a reply to message #57612] |
viewer!
Any ideas?
Emil
> Hi.
> Peter
>> Hi Peter,
>> Header-Controls.
>> Tom
>>> Hi Tom.
>>> grid/gridviewer?
>>> Peter
>>>> them from:
>>>> See
>>>> Tom
>>>>> Tom
>>>>>> Hello there.
>>>>>> Thanks in advance.
>>>>>> Peter
Re: GridTableViewer - JFace Databinding - Dates [message #591676 is a reply to message #57637] |
Hi Emil,
different images.
Tom
> viewer!
> Any ideas?
> Emil
>> Hi.
>> Peter
>>> Hi Peter,
>>> Header-Controls.
>>> Tom
>>>> Hi Tom.
>>>> grid/gridviewer?
>>>> Peter
>>>>> them from:
>>>>> See
>>>>> Tom
>>>>>> Tom
>>>>>>> Hello there.
>>>>>>> Thanks in advance.
>>>>>>> Peter
Current Time: Sat Oct 19 05:10:57 GMT 2024
Powered by FUDForum. Page generated in 0.10153 seconds
