Headless RCP Product Export [message #57460] |
Tue, 21 April 2009 19:11 |
I have managed to get a headless build working using many online
references. The output is not what I get when I use the Eclipse Product
Export Wizard manually inside the Eclipse SDK.
How do I get the same shippable product in a headless way?
Thanks!
Re: Headless RCP Product Export [message #57508 is a reply to message #57460] |
Tue, 21 April 2009 19:31 |
On Tue, 21 Apr 2009 19:11:50 +0000, Dilton McGowan II wrote:
> Thanks!
Never mind, I just noticed the I.TestBuild directory. The zipped versions
of the product are located there.
Re: Headless RCP Product Export [message #57585 is a reply to message #57534] |
Tue, 21 April 2009 23:47 |
Originally posted by: n.n.nnn
>> versions of the product are located there.
>> Thanks
> For reference, it is named I.TestBuild because by default, the location
> of the resulting archives is ${buildDirectory}/${buildLabel}. If you
> look at the build.properties for your builder you will see the default
> value:
> buildLabel = ${buildType}.${buildId}
> buildType=I
> buildId=TestBuild
I'd not edited that part from the original and overlooked it.
Thanks for pointing it out Andrew.
Re: Headless RCP Product Export [message #596030 is a reply to message #57460] |
> Thanks!
Re: Headless RCP Product Export [message #596057 is a reply to message #57534] |
>> Thanks
> value:
> buildType=I
> buildId=TestBuild
FUDForum. Page generated in 0.03596 seconds
