| Sharing embedded Derby with other plugins [message #57407] |
Tue, 21 July 2009 17:43  |
I am using OpenJPA, DTP and Derby in my Eclipse RCP app. Before I added
OpenJPA, I was using my own JDBC layer and obtained the JDBC connection
from DTP profile manager.
Now, when I use OepnJPA, I cannot connect to the database in the DSE and
navigate the tables, schemas, etc. Instead, I must stop the OpenJPA
processing, then I can connect to DSE. While DSE is connected, OpenJPA
cannot access the Derby instance.
Ideally, I could use OpenJPA and DSE simultaenously (ie, two
connections) without going Derby Client/Server. I currently use the
Derby embedded driver.
Is there a way two components such as these can access the same Derby
instance? I understand that only one can "boot" Derby.
Has anyone else come across this situation already?
chris
| Re: Sharing embedded Derby with other plugins [message #57432 is a reply to message #57407] |
Thu, 23 July 2009 10:24  |
Hi Chris...
One possible solution... Create two different driver definitions for the
Derby driver so each has its own classloader (ultimately this is the
limiting factor from what I remember). See if using one for OpenJPA and
one for the DSE makes a difference.
--Fitz
| Re: Sharing embedded Derby with other plugins [message #596115 is a reply to message #57407] |
Hi Chris...
--Fitz
FUDForum. Page generated in 0.04298 seconds
