Re: AspectJ 5 M4 [message #57709 is a reply to message #57596] |
Mon, 17 October 2005 15:37 |
Eugene Kuleshov Messages: 504 Registered: July 2009 |
Sian,
I did delete previous AJDT plugins and features before installing
this one and this plugin was the only AJDT verion I had at that point.
Unfortunately I can't afford to reinstall Eclipse or even use
different workspace, which means that I have to stay on Eclipse 3.2M1.
Too bad. :-(
By the way, it would be easier if all these different AJDT streams
would have the same update site. I believe Mylar's update site is done
this way.
regards,
Eugene
Sian January wrote:
> Hi Eugene,
> There will be an update site available for Eclipse 3.2 in the not too
> distant future but it will be after our 1.2.1 and 1.3 AJDT releases,
> which are both due in the next month or so.
> I have sometimes seen the problem you described below. You might want
> to try deleting all the AJDT plug-ins and the AspectJ feature from the
> plugins and features directories respectively and then re-installing
> them. Otherwise a fresh install of Eclipse may work.
> Sian
> Eugene Kuleshov wrote:
>> Matt,
>> Is there are any plans to provide an update site for this branch?
>> I've tried to manually install one of the latest builds on 3.2M2 but
>> it didn't worked. Feature appeared in the about dialog, but none of
>> the ajdt actions and menus are there.
>> regards,
>> Eugene
>> Matt Chapman wrote:
>>> AspectJ 5 M4 is now also included in the early development build for
>>> Eclipse 3.2M2:
>>> http://www.eclipse.org/ajdt/downloads/#dev
>>> The build id is: "1.3.0.20051013194900 for Eclipse 3.2M2" (zip file
>>> only).
>>> Regards,
>>> Matt.
Re: AspectJ 5 M4 [message #590542 is a reply to message #57596] |
Sian,
Too bad. :-(
this way.
regards,
Eugene
Sian January wrote:
> Hi Eugene,
> Sian
>> Matt,
>> regards,
>> Eugene
>>> Eclipse 3.2M2:
>>> only).
>>> Regards,
>>> Matt.
FUDForum. Page generated in 0.04402 seconds
