C++ Make [message #57324] |
Wed, 08 January 2003 21:54 ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mcgahan.huntsville.sparta.com
I am having difficulty getting the "Make" to work in the C++ project. I
notice a box flashes on the screen rather rapidly stating "invoking
command: c:\cgwin\bin\make". Unfortunately my cygwin is installed in the
c:\cygwin path. Yes, I can rename the path and it works, but I would like
to now how to change the path eclipse is searching for make.
thanks,
mike
Re: C++ Make [message #57504 is a reply to message #57324] |
Thu, 09 January 2003 12:50 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Originally posted by: mhu.gft.com
You have to change the Build Command.
Right click your project -> Properties -> C/C++ project -> Build Settings
Now insert in the Build Command Box c:\cygwin\bin\make -f makefile
Greetings Martin
> thanks,
> mike
Re: C++ Make - Thanks [message #57529 is a reply to message #57504] |
Thu, 09 January 2003 13:18 ![Go to previous message Go to previous message](theme/Solstice/images/up.png) ![Go to next message Go to next message](theme/Solstice/images/down.png) |
Looked every where, so I thought. Thanks for the help. Your response
solved my problem.
thanks,
mike
> Greetings Martin
> > thanks,
> > mike
FUDForum. Page generated in 0.03121 seconds
