Home » Archived » XML Schema Definition (XSD) » using the prefix of the qname to identify namespaces
using the prefix of the qname to identify namespaces [message #57322] |
Tue, 08 February 2005 06:10 |
Francis Upton IV Messages: 472 Registered: July 2009 Location: Oakland, CA |
I'm trying to process xsd files whose schema element contains imports.
What I want to do is identify each target namespace with it's prefix for
the purpose of naming my internal data structures. I need to do this
before I process the body of the schema, as this affects how I name
components of the schema. I need to do this for all of the types,
elements, etc defined in the schema and in the imported schemas.
For the schema that I'm directly importing, this is no problem, as I
process the attributes on the xsd:schema element and can get the prefix
value for each namespace URI (of course I'm not considering the case
where the namespace prefix/URI is defined on the non-schema element, but
I'm not worried about that for the time being).
Since imports are resolved only on demand, I can't see how I can process
the imports before I process the body of the schema (the elements, types
etc).
What I (think I) want to do is force the resolution of each of the
imports and then reach into the imported document to grab it's
prefix/namespace URI definitions.
Is there a way to do this?
Francis
Platform UI Committer for Common Navigator
http://wiki.eclipse.org/index.php/Common_Navigator_Framework
http://help.eclipse.org/galileo/topic/org.eclipse.platform.d oc.isv/guide/cnf.htm
Re: using the prefix of the qname to identify namespaces [message #57348 is a reply to message #57322] |
Tue, 08 February 2005 11:21 |
--------------080002040008070703030105
Francis,
The XSDEcoreBuilder forces imports to resolve like this:
protected void validate(XSDSchema xsdSchema)
for (Iterator i = xsdSchema.getContents().iterator(); i.hasNext(); )
Object content = i.next();
if (content instanceof XSDImport)
XSDImport xsdImport = (XSDImport)content;
xsdImport.resolveTypeDefinition(xsdImport.getNamespace(), "");
But this is only to force imports to resolve that otherwise wouldn't
resolve because they aren't used. All the used imports will already be
resolved by the time an instance of an XSDSchema has been loaded.
Remember too that a schema can be defined across multiple included files
and each file may use a different prefix for the target namespace.
> for the purpose of naming my internal data structures. I need to do
> this before I process the body of the schema, as this affects how I
> name components of the schema. I need to do this for all of the
> types, elements, etc defined in the schema and in the imported schemas.
> prefix value for each namespace URI (of course I'm not considering the
> case where the namespace prefix/URI is defined on the non-schema
> element, but I'm not worried about that for the time being).
> process the imports before I process the body of the schema (the
> elements, types etc).
> Francis
<html>
<head>
</head>
Francis,<br>
<br>
The XSDEcoreBuilder forces imports to resolve like this:<br>
<blockquote> protected void validate(XSDSchema xsdSchema)<br>
{<br>
for (Iterator i = xsdSchema.getContents().iterator(); i.hasNext(); )<br>
{<br>
Object content = i.next();<br>
if (content instanceof XSDImport)<br>
{<br>
XSDImport xsdImport = (XSDImport)content;<br>
xsdImport.resolveTypeDefinition(xsdImport.getNamespace(), "");<br>
}<br>
}<br>
</blockquote>
be resolved by the time an instance of an XSDSchema has been loaded.
files and each file may use a different prefix for the target namespace.<br>
<br>
<br>
<blockquote cite="midcu9l4o$ho5$1@www.eclipse.org" type="cite">I'm
<br>
<br>
name components of the schema. I need to do this for all of the types,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Francis
<br>
</blockquote>
<br>
</body>
</html>
--------------080002040008070703030105--
Re: using the prefix of the qname to identify namespaces [message #57373 is a reply to message #57348] |
Tue, 08 February 2005 15:11 |
Thanks Ed, I think I might made been barking up the wrong tree a little.
Since all of the imports have been resolved, I really don't need to
force their resolution.
So my question is, how do I get to the elements of the imported
document? I want to process any xmlns attributes to get the namespace
prefixes (and yes, I do understand that there might be multiple prefixes
defined for the same name, but this does not matter as I just need to
pick one).
Francis
Ed Merks wrote:
> Francis,
>> Thanks,
>> Francis
Re: using the prefix of the qname to identify namespaces [message #57397 is a reply to message #57373] |
Tue, 08 February 2005 15:28 |
--------------020707020709060000060402
Francis,
Something like this should do the trick:
XSDSchema xsdSchema = xsdImport.getResolvedSchema();
String prefix =
XSDConstants.lookupQualifier(xsdSchema.getElement(),
xsdSchema.getTargetNamespace());
Note that prefix may be null, i.e., no xmlns is declared, a null string,
i.e., xmlns="<targetNamespace>", or an non-empty string, i.e.,
xmlns:xyz="<targetNamespace>".
> little. Since all of the imports have been resolved, I really don't
> need to force their resolution.
> prefixes defined for the same name, but this does not matter as I just
> need to pick one).
> Francis
> Ed Merks wrote:
>> Francis,
>> i.hasNext(); )
>>> the case where the namespace prefix/URI is defined on the non-schema
>>> Thanks,
>>> Francis
<html>
<head>
</head>
Francis,<br>
<br>
Something like this should do the trick:<br>
<blockquote> XSDSchema xsdSchema = xsdImport.getResolvedSchema();<br>
String prefix = XSDConstants.lookupQualifier(xsdSchema.getElement(),
xsdSchema.getTargetNamespace());<br>
</blockquote>
string, i.e., xmlns="<targetNamespace>", or an non-empty string,
i.e., xmlns:xyz="<targetNamespace>".<br>
<br>
<br>
<blockquote cite="midcuakrs$2lc$1@www.eclipse.org" type="cite">Thanks
<br>
<br>
need to pick one).
<br>
<br>
<br>
<br>
Francis
<br>
<br>
Ed Merks wrote:
<br>
<blockquote type="cite">Francis,
<br>
<br>
<br>
<br>
<br>
<br>
i.hasNext(); )
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
namespace.
<br>
<br>
<br>
<br>
<br>
<blockquote type="cite">I'm trying to process xsd files whose
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Francis
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
--------------020707020709060000060402--
Re: using the prefix of the qname to identify namespaces [message #57422 is a reply to message #57397] |
Wed, 09 February 2005 22:50 |
Thanks Ed, this is exactly what I needed. I'm importing complex schemas
and it's handy to be able to identify their parts with the prefix (which
of course refers to the NS URI). Even if the prefixes are used
inconsistently between the files, it's still more convenient to just
pick one and use that to identify the full NS.
Also, just want to say how much I appreciate using your XSD stuff. It's
amazingly solid and very well thought out and organized. I have not
found any problems with it at all. And a personal thanks to you for the
support you have been doing on this newsgroup. It's always very helpful.
Best,
Francis
Ed Merks wrote:
> Francis,
> String prefix =
>> need to pick one).
>> Thanks,
>> Francis
>> Ed Merks wrote:
>>> Francis,
>>> i.hasNext(); )
>>>> Thanks,
>>>> Francis
Re: using the prefix of the qname to identify namespaces [message #593731 is a reply to message #57322] |
Ed Merks Messages: 33188 Registered: July 2009 |
Francis,
> Francis
<html>
<head>
</head>
Francis,<br>
<br>
{<br>
{<br>
{<br>
}<br>
}<br>
</blockquote>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Francis
<br>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: using the prefix of the qname to identify namespaces [message #593747 is a reply to message #57348] |
pick one).
Francis
Ed Merks wrote:
> Francis,
>> Thanks,
>> Francis
Re: using the prefix of the qname to identify namespaces [message #593762 is a reply to message #57373] |
Francis,
String prefix =
> need to pick one).
> Francis
> Ed Merks wrote:
>> Francis,
>> i.hasNext(); )
>>> Thanks,
>>> Francis
<html>
<head>
</head>
Francis,<br>
<br>
</blockquote>
<br>
<br>
<br>
<br>
need to pick one).
<br>
<br>
<br>
<br>
Francis
<br>
<br>
Ed Merks wrote:
<br>
<br>
<br>
<br>
<br>
<br>
<br>
i.hasNext(); )
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
namespace.
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
Francis
<br>
</blockquote>
<br>
<br>
</blockquote>
</blockquote>
<br>
</body>
</html>
Ed Merks
Re: using the prefix of the qname to identify namespaces [message #593773 is a reply to message #57397] |
Best,
Francis
Ed Merks wrote:
> Francis,
> String prefix =
>> need to pick one).
>> Thanks,
>> Francis
>> Ed Merks wrote:
>>> Francis,
>>> i.hasNext(); )
>>>> Thanks,
>>>> Francis
Current Time: Sat Jul 27 16:11:15 GMT 2024
Powered by FUDForum. Page generated in 0.04474 seconds
