NullPointerException thrown in JavaElementContainmentAdapter [message #57264] |
Fri, 13 June 2003 18:23  |
I think I came across a bug in
"org.eclipse.jdt.internal.ui.JavaElementContainmentAdapter"
I couldn't find a bug report for it but I've never had much luck
searching with bugzilla. Is this a known issue?
The following code is copied from method contains(Object, Object, int),
and fails if element is an IJavaElement not contained in the
workingSetElement of type IJavaElement.PACKAGE_FRAGMENT:
IResource resource= null;
IJavaElement jElement= null;
if (element instanceof IJavaElement) {
jElement= (IJavaElement)element;
} else {
if (element instanceof IAdaptable) {
resource=
(IResource)((IAdaptable)element).getAdapter(IResource.class) ;
if (resource != null) {
if (fJavaModel.contains(resource)) {
jElement= JavaCore.create(resource);
if (jElement != null && !jElement.exists())
jElement= null;
if (jElement != null) {
if (contains(workingSetJavaElement, jElement, flags))
return true;
if (workingSetJavaElement.getElementType() ==
IJavaElement.PACKAGE_FRAGMENT &&
//***THE FOLLOWING THROWS AN NPE, "resource" IS NULL***
resource.getType() == IResource.FOLDER && checkIfDescendant(flags))
return isChild(workingSetJavaElement, resource);
Re: NullPointerException thrown in JavaElementContainmentAdapter [message #58353 is a reply to message #57264] |
Mon, 16 June 2003 05:32  |
Originally posted by: daniel.megert.gmx.net
Ryan Wannop wrote:
>Hi,
Since you could not find it in bugzilla you should file the bug
yourself. It really looks like a problem.
Dani
FUDForum. Page generated in 0.04132 seconds
