Home » Eclipse Projects » Nebula » OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer?
OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #57255] Wed, 06 August 2008 09:47 Go to next message
I'm trying to custom draw some things within the cells of the
Grid/Gridviewer using the OwnerDrawLabelProvider but it seems that paint
events doesn't get triggered for the label provider. The same applies to
SWT.paintItem on the Grid. Are these intended to be included or is there
another way of doing it?
With regards
Tommy
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #57279 is a reply to message #57255] Wed, 06 August 2008 09:49 Go to previous messageGo to next message
Now owner draw is a concept only part of native swt controls because
nebula grid is completely custom drawn you can simply replace the
cell-renderer if you need some custom drawing.
The concept of owner draw can't work in nebula grid.
Tom
Tommy schrieb:
> Hi
> With regards
> Tommy
B e s t S o l u t i o n . at
Tom Schindl JFace-Committer
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #494924 is a reply to message #57279] Tue, 03 November 2009 04:46 Go to previous messageGo to next message
why don't you use the same concept for the grid as well as for the native controls. I ran into the same problem. It should be possible to use the same labelprovider for the grid as well as for a SWT-backended JFace table.
Enrico
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #494939 is a reply to message #494924] Tue, 03 November 2009 05:20 Go to previous messageGo to next message
Well Grid simply works different and you can't apply the concept without
investing time into it.
Naturally we could add callbacks into our draw CellRenders callback to
PaintItem, MeasureItem, ... but frankly at the moment this is not on our
list of things so the only possibility is to experiment with writing
your own renderer.
Please log a feature request so that we don't miss this feature.
Tom
> JFace table.
> Enrico
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #494940 is a reply to message #494939] Tue, 03 November 2009 05:34 Go to previous message
done ...
https://bugs.eclipse.org/bugs/show_bug.cgi?id=294035
Enrico
"Tom Schindl" <tom.schindl@bestsolution.at> schrieb im Newsbeitrag
news:hcp05l$qb$1@build.eclipse.org...
> your own renderer.
> Tom
>> JFace table.
>> Regards,
>> Enrico
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #591549 is a reply to message #57255] Wed, 06 August 2008 09:49 Go to previous message
Tom
Tommy schrieb:
> Hi
> With regards
> Tommy
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #598570 is a reply to message #57279] Tue, 03 November 2009 04:46 Go to previous message
Enrico
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #598572 is a reply to message #494924] Tue, 03 November 2009 05:20 Go to previous message
your own renderer.
Tom
> JFace table.
> Enrico
Re: OwnerDrawLabelProvider and PaintItem events for Grid/GridViewer? [message #598578 is a reply to message #494939] Tue, 03 November 2009 05:34 Go to previous message
done ...
Enrico
> your own renderer.
> Tom
>> JFace table.
>> Regards,
>> Enrico
Previous Topic:Date/Calendar widgets - any validation support?
Next Topic:Date/Calendar widgets - any validation support?
Current Time: Sun Oct 19 04:19:20 EDT 2025
Powered by FUDForum. Page generated in 0.05396 seconds
